MFSW with DSG and GSM Kit
granty578 May 1, 2013
  1. granty578
    granty578 Member
    133
    Hi Guys,
    I've read that a MFSW will be a straight swap for those with DSG. I have a 2005 DSG....
    However what I want to know mainly know, is will the phone function on the wheel work when I have the GSM kit that does allow bluetooth connection?
    Thanks,
    Granty
  2. mike foster
    3,967
    AFAIK phone function only works with OEM Bluetooth module fitted and coded properly.
    Don't know what GSM kit is so couldn't comment but would maybe need rewiring ?
  3. granty578
    granty578 Member
    133
    Thanks.
    It's the dash mounted cradle which has bluetooth built in.
    Everything comes up on the DIS already including contacts but as it stands I have no way to interface using the vehicle. I have to use the phone manually....so a MFSW would solve this :)
  4. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    If you have the oem Bluetooth which by your description you do, then yes mate, the MFSW will work with your phonebook.
