MFSW retrofit- apologies in advance!
~RS~ May 3, 2009
  1. ~RS~
    ~RS~ Active Member
    1,466
    22
    I know this subject has been hashed out to death, but I must be getting duller as I age because for the 20 or so thread I just read on fitting an MFSW I am still no nearer to understnading what is needed!
    So, please bear with me and explain in 'for dummies' format what is required if I want to swap my steering wheel which looks like this:
    to one like this:
    (but S-line, chrome button surround version).
    The shape looks the same to me so I am hoping that I won't need a new airbag... but how do I find out if I need a new slip ring and ecu or not?
    I have a 54 plate 2005 sportback sport. No Bluetooth, RNS-E or phone prep that I am aware of.
    Damn! My head hurts reading about adding a MFSW!!!:readit::think::sos:
  2. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Have you got cruise control?
    I believe if you have this it may mean you have the correct steering ecu and slip ring
    The best way to check will be to contact your local dealer and give them your vin number and they will be able totell what ecu and slip ring are fitted to your car. Then post em on here and somebody will confirm if they are correct or not for mf
    You're airbag should be ok as it is a 3 spoke one and the mf is 3 spoke also.
    You will also need vag.com to enable the mf function on your car when fitted
    Oh, and i may have a sline mf wheel for sale if you arte interested.
    It doesnt have the chrome though. It is from a 2007 car
  3. ~RS~
    ~RS~ Active Member
    1,466
    22
    Thank you very much mate.... That post did what an aspirin failed to! :)
    I do not have cruise control, I did read something to this effect but the thread died off so never got resolved. I will check with dealers on Tue... pm ya shortly
  4. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    you got any pics of yours rs i want to see your wheels how they look on your car ...are they 19"
  5. N8
    17,163
    719
    Why don't you just get a flat bottom man?
  6. Bugsy_27
    Bugsy_27 Vorsprung Durch Technik
    653
    :iagree:
  7. scottie123
    1,972
    Is that your preferance?
    I didnt know men came with differant styles of bottoms? :whistle2:
  8. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    how much are you asking for it scottie, im after changing mine as i have the older one in my b6 cab and want to upgrade.
    do you have an airbag for sale too ?
  9. 10blazin
    3,301
    how do you get the airbags off in order to get the wheel off if there screws where are they .....??????
  10. ~RS~
    ~RS~ Active Member
    1,466
    22
    Yes mate they are 19's my pic taking skills are in the category of rank amateur, they never seem to come out how the car looks! If that makes any sense or maybe it looks alot better in my minds eye :)
    How do you use this multi quote thing! It's doing my head in!!
    I want the RNS-E, bluetooth and wheel mod. Flat wheel costs are too prohibitive right now... maybe another time, I usually like things done all together and would have to wait a while longer to do flat wheel at the same time.
  11. ~RS~
    ~RS~ Active Member
    1,466
    22
    Good question!
    How easy is it to swap wheels over? Is it a DIY or something I need to pay for :)
  12. scottie123
    1,972
    if you look behind the wheel, there is 2 plastic covers about the size of a 20p piece. They are on opposite sides to eac other. Flip these of and when you turn your wheel, you should see a torque bolt . 2 bolts to take out.
  13. scottie123
    1,972
    To remove the wheel you will need a m12 spline bit.
    Torque head ( not sure on size) to remove airbag.
    You will need vcds to code wheel to car if going from non mf to mf.
    If going from mf to mf , no need to code.
    Fairly easy to do, just make sure you dont move slip ring position when removing wheel , and all will be fine.
    havent actually done this yet!, but this is all info i have gathered from posts etc
    hope this helps
  14. pns2007
    pns2007 Moonstone Grey VCDS Map User
    689
    64
    As a matter of interest what does the slip ring look like, any pics ? please
  15. ~RS~
    ~RS~ Active Member
    1,466
    22
    Anybody have the part numbers and cost of the ecu and slip ring required for the sw pictured above... one on ebay at the mo...
  16. ~RS~
    ~RS~ Active Member
    1,466
    22
    Anybody know these part no's and rough cost?:shrug:
