MFSW Retrofic (So Confused)
Matuh Apr 22, 2013
  1. Matuh
    Matuh Member
    49
    Hi Everyone, i have a A3 SB 2006 With the 4 spoke Steering Wheel Without Multi fuction.
    Someone said that only i need the MFSW and the Airbag harness and others said that i need to replace de steeering wheel module.
    What is the true???
  2. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    DSG or manual?
  3. Matuh
    Matuh Member
    49
    Sorry, It's DSG.
  4. leeds2592
    1,399
    222
    Chances are you won't need to replace the steering control module. A scan with VCDS would confirm though.
    Also something to note, if you're going from a 4 spoke steering wheel to a 3 spoke, your old airbag won't fit then new wheel.
  5. Matuh
    Matuh Member
    49
    I Will Buy a 4 spoke, because if a change to 3 spoke a need too the slip ring.
    How can i know scaning with VCDS?? it said the model of the Steering Control module??
    And the airbag hadness it the same for the 4 spoke and the 3 spoke?? i found in ebay this: 8P0971589L and in ECS 8J0971589B.
  6. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Hi Matuh, don't worry about checking with vcds, you do not need a new steering module or harness or slip ring! As you already have a DSG wheel, you already have everything in place. All you need is a new wheel and airbag if changing to a 3 spoke. Again if you want to go for a 3 spoke you already have all the right modules and harness in place.
    It will however need coding once installed.
    I am in London mate so can do the install if interested.
  7. Matuh
    Matuh Member
    49
    My car dont have paddle shift, I dont chenge to 3 spoke, i ll buy a 4 spoke with MF.
    You said that i dont need the new hadness? i take out the airbag and i ll found the cable for the paddle shift and the MF??
  8. Dannykn9
    1,123
    56
    Ok so you don't have the paddle shift wheel, you should have made that clear. In that case, then you will need a new steering module, and a new airbag harness. Your current slip ring will be fine.
  9. Dannykn9
    1,123
    56
    You may as well upgrade to the paddleshift wheel as you can get this to work to as you have the DSG gear box.
  10. Matuh
    Matuh Member
    49
    I need to change a lot of parts...
    The module the new modulo is for the paddle shift only?? the MF will work with my actual module?? or i need to change it too?
  11. Dannykn9
    1,123
    56
    You need to change the module if upgrading to a MFSW but that same new module will allow you to use the paddle shift too. The part number you need is 8P0953549F.
  12. Matuh
    Matuh Member
    49
    A ask to a friend that works in VW, and i give to him mi VIN and... my car have the correct module :)
  13. Dannykn9
    1,123
    56
    I very much doubt you have the correct module mate. VW/Audi will list the most upto date module for your car which does not mean you have that module.
    Best thing is to get it scanned by someone close by to determine what module you have. If around North London, I will be happy to check this for you.
    But for now mate, no point giving any more advice until we determine what module you actually have.
    Being you have a basic non paddleshift wheel or MFSW, I can almost garuntee 99.9% you will not have the correct module.
  14. Matuh
    Matuh Member
    49
    Thanks you but i soooooo fur!, i'm in argentina!.
    I will scan the car to make sure.
    Thanks!
  15. Dannykn9
    1,123
    56
    Argentina!! My grandfather and uncle live in Argentina, they come from Buenos Aires. Beautiful country!
  16. Matuh
    Matuh Member
    49
    :D thanks!! Im live in Buenos Aires too!
  17. Matuh
    Matuh Member
    49
    Hi again!! Finaly i scan the car and the module is :1K0953549AH it is not that appears in EDKA :( its not work with this module.
  18. Dannykn9
    1,123
    56
    Only cruise control will work with that module.
  19. Matuh
    Matuh Member
    49
    Hi! Somebody have the part number of the Airbag harness for the MFSW??
    The 3 spoke and the 4 spoke have the same hardness??
    Because a will buy a module and the person for U$S20 sell to me the cable but it is of a 3 spoke and mi steering is 4 spoke.
    Thanks!!
  20. Matuh
    Matuh Member
    49
    Finally i bought the steering wheel and the module. I need if it posible to modify my steering wheel hardness, because i see and it is the same, it only have a conector with 3 pins.
  21. B120WNY
    B120WNY Member
    67
    Good thread!
    I too am looking to upgrade soon.
    Ive a 2006 v6 sport back Sline, with dsg paddles. Id like to upgrade to the flat bottom mfsw but unsure as to which one will work. I understand there are two types of airbag on those steering wheels?
    Think Il do a scan to see what module I have as Id also like to fir cruise aswell.
    Oh the joys..!
  22. Matuh
    Matuh Member
    49
    If you got Paddle Shift you have the correct module.
    You need only a new steering Wheel (the same you have, 3 spoke o 4 spoke)
  23. fangio
    fangio Well-Known Member
    1,480
    175
    I have a 2005 and a fbmfsw with paddles; it was a straight swap.
  24. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,208
    389
    So my dsg wheels air bag can fit others? If so how do i know which?
    How many different types of air bag is there?
    I want to do the MFSW and DSG, plenty of steering wheels on ebay but no air bag with them.
  25. B120WNY
    B120WNY Member
    67
    Great!
    So when you say straight for, you mean:
    bolts on and plugs into module
    Once plugged in it connects to rnse with no further mods or cables
    just needs coded to work
    Wasnt there two types of airbag with the flat bottom steering wheels?
  26. fangio
    1,480
    175
    Yes, just needed coding; there are two types of airbag. Make sure you get the right one! A good buy here;-
    Audi TT/S3 Flat Bottom Steering DSG Paddle Shift Plus Airbag Mint! | eBay
  27. B120WNY
    B120WNY Member
    67
    Cool, thanks!
    How do I know what is the "right one"?
  28. fangio
    1,480
    175
