mfsw problem
sbhoy17 May 15, 2010
  1. sbhoy17
    sbhoy17 Member
    49
    hi guys
    well got my mfsw for my 07 S3 on wed and gave the car to my mate who works for Seat to fit it, got it back last night to be told there is no multifunction. He said the power steering was not working until he got a code off his mate at audi. His mate tried to give him the code for multifunction but it would not accept it and he thinks it will need to be coded at audi. I thought it was a straight swap once i had all the parts ie new ecu part no: 8PO 953 549 F and slipring 1KO 959 549 D which turns out i did not need so if anyone is looking for one send me a PM any info on this would be appreciated before i head over to audi next week
  2. Ash187
    7,478
    735
    Mate you need to get it coded properly, the power steering wheel comes up with an error after you change over the steering wheel if you disconnect the battery. Either clear the fault and take it for a little drive and fully turn and lock the steering wheel left and then right (did this in the car park down the street) and it should disappear. Or go on to this site and look up the coding fix you need to do to get the car to recognise the steering assist properly:
    http://wiki.ross-tech.com/wiki/index.php/Audi_A3_(8P)_Steering_Assist
    you also need to code the steering ECU to multifunction which is very easy! You need to get in contact with anyone on the site that has a VCDS so that they can code it for you, i wouldn't mind but you are on the other side of the country...
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    If its just a coding issue I can help you. After swapping the ECU module & slipring there is some coding that needs done or your steering will be like lead & wont self centre over an above the need to code the wheel controls. I'm just down the road from Glasgow if you want to PM me.
  4. NHN
    29,328
    1,708
    I have asked Khufu if he can help, maybe he will be along shortly. :beerchug:
    Ok he beat me to it, piff puff pooof da da, magic lmfao
  5. sbhoy17
    sbhoy17 Member
    49
    Thanks guys I will get in contact with Khufu begining of week
