MFSW problem
JDM82 May 25, 2012
  1. JDM82
    JDM82 Member
    328
    Im currently having a MFSW retrofitted to my 2005 A4. Im getting it done by a professional but we are having a problem. The lad fitting it is on the case but I thought id throw up the question, you never know........ Im sure the lad will come up with the solution but I still may aswell ask.
    The wheel fits perfect and the guy codes it in but the buttons don't work nor do they light up. I have the correct module ( 8E0953549Q) and slip ring (4E0953541) and I already have cruise control fitted.
    The module has been replaced to see if that was the problem, it wasn't.
    The guy checked the wheel in his car and it works fine.
    The next point of interest is the slip ring. The horn works and the air bag light doesn't come, two signs of a faulty/damaged slip ring i've been told.
    Im sure the guy will figure out whats wrong however if anyone on here has had the same problem or has any suggestions, that would be great.
    I'd rather go back to the guy with suggestions and see if anything works.
  2. Wrath
    Wrath Well-Known Member
    1,196
    42
    I assume you got a new airbag harness?
  3. JDM82
    JDM82 Member
    328
    Yeah, the guy did fit a new harness to the back of the airbag.
  4. Wrath
    1,196
    42
    In that case it does sound like the slip ring, you did get the right slip ring? From memory there should be a letter after the part number.
  5. Wrath
    1,196
    42
    Just checked and you need either 4E0953541A or B as they have the 12 pins.
  6. JDM82
    JDM82 Member
    328
    Cheers Nathan
  7. NHN
    29,551
    1,777
    Yeap cant be much more at fault tbh, only items I can think are slip ring & airbag loom, but if he's tested wheel/bag on his car then obviously the loom is fine, so must be ring with an issue.
  8. JDM82
    JDM82 Member
    328
    He suggested the slip ring so I think that's a good way to go......
    Cheers guys, as always a great help :icon_thumright:
