MFSW lead help needed please
Shane. Aug 21, 2011
  1. Shane.
    Shane. Member
    486
    Right after thinking we finally had everything needed yesterday went to finally get the MFSW working then realised yet again TPS has sent us the wrong lead (was from an A4) basically I have a 2010 A3 mfsw and need the lead that goes inside from slip ring to dual stage airbag to mfsw controls. As far as we know that is the final problem that needs sorting and it should all work.
    Also something else that confused us the slipring has 8 pins, yet the steering ECU only has 6 inputs out of the 8, the steering ecu shows it being the correct model and is the same as a MK5 Golf R32 steering ecu which has MFSW as standard.
  2. Shane.
    Shane. Member
    486
    Bump, really getting desperate now. TPS sent us the wrong lead yet again (think that's the 6th time) this time part number started with 8E basically I need the lead that sits inside the steering wheel that goes Slipring>Steering controls>Dual stage air bag. Everyone we have had so far has single stage airbag and a block connector (4 pin slots on top 4 on bottom) for steering controls, mine is a narrow style (only single row has 3 pins at one end) )
    Shane
  3. Ash187
    7,478
    735
    i think the part number that you need is 8P0 971 589 Q
    im pretty sure thats the part number i used when i ordered by MFSW harness from stoke audi last year
  4. mike foster
    3,967
    That's the one I used when I fitted mfsw !
  5. paddy
    paddy Audi=No fault code, no idea
    5,168
    136
    When i fitted a duel stage airbag to a single stage car the plug/socket was the same
    This was the single stage wheel and the airbag connection (yellow) pluged straight in on the single and duel airbag to the corresponding yellow plug on the steering column .
  6. Shane.
    Shane. Member
    486
    Cheers mate will have a look at that, is that dual stage?
    The yellow plug will be the same, but I should have 2 airbag plugs one purple and one orange iirc plus the one to plug into the steering controls. For some annoying reason I bought the bag and steering wheel together but the guy took the leads off of it :S
    Shane
  7. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    116
    8P0 971 589 Q is the part you need for a dual-stage (sheild style) airbag. I've fitted to plenty using this part.
    Thanks to Mike who told me originally ;)
  8. Shane.
    Shane. Member
    486
    Ordered one of them now, Thanks for the advice :)
