MFSW issues - Help needed on programming
mattandrew Mar 4, 2008
  1. mattandrew
    mattandrew Member
    977
    21
    Vehicle and options
    Audi A3 2004
    Concert head unit
    Audi navigation – the one which comes up in the DIS and controls in the centre console
    MFSW – out of a 2008 sline with scroll wheels
    Audi bluetooth phone prep
    DSG
    DIS
    Cruise
    Problems
    The right scroll wheel controls the volume OK
    The right button works the bluetooth OK
    The MODE button works the phone prep
    BUT the left scroll wheel does not skip to the next track when palying a CD
    I know there are limited functions available but I believe it should skip the track
    I have the following coding:
    16 – Steering wheel 0013142
    77 – Telephone 0011422
    56 – Radio 0000231
    Is there any other coding which should be done or I have got wrong, can’t find much info on 56 – Radio so this could need changing
    Thanks in advance
  2. GeoffT
    GeoffT Member
    267
    Which version of concert Head unit is it? If it is a Concert II I think you need to add 4 to the last digit to add MFSW. ie code it 0000235 in your case.
  3. mattandrew
    mattandrew Member
    977
    21
    how do I check the version? If I change the last letter will that not alter something else?
  4. marms
    marms Member
    833
    Matt,
    You need to add 2 to channel 7 coding of the radio enable CAN based Multi-function steering wheel support.
    More info here if you need it.
    Hope that helps.
  5. GeoffT
    GeoffT Member
    267
    Actually Matt, having re-read your post I'm confused. You say you have Concert headunit AND Audi Navigation. You can only have one or the other surely? If you have the Audi NAVplus (RNS-E) navigation, marms is correct, if you have a concert II head unit my suggestion is correct.
  6. mattandrew
    mattandrew Member
    977
    21
    Just checked it the concert II
    I have tried in 56 - Radio 0000235 but no joy
  7. mattandrew
    mattandrew Member
    977
    21
    I have the concert II and the Audi Navigation System with single colour display, its the simple version which displays in the DIS.
    I gona have a look at marms post now
  8. GeoffT
    GeoffT Member
    267
  9. mattandrew
    mattandrew Member
    977
    21
  10. mattandrew
    mattandrew Member
    977
    21
    Thanks for that but channel 7 is not available in the radio, and when reading the link that is for the navigation which is working ok.
    Ill get there in the end
