MFSW Coding Help
Coling Feb 17, 2011
  1. Coling
    Coling Active Member Audi RS3
    211
    180
    43
    Looking for a bit of coding help.
    I have fitted a flat bottom steering wheel out of a TT to my 2005 A3 sportback, I also upgraded the slip ring (1K0 959 653 D) and steering ECU (8P0 953 549 F) after discussions with Mike Foster on here. thanks Mike.
    Anyway, I now have a few issues which I would assume are down to the lack of coding.
    Airbag light on, steering wheel light on, skidding car light on.
    The steering is now heavy, horn doesnt work, multi function doesnt work, illumination doesnt work.
    I have someone who has VCDS but he was asking what the codes would be.
    Thanks in advance.
  2. hollows wife
    hollows wife Well-Known Member
    1,404
    165
    sure it can be done with the long coding helper in vcds, steering wheel light and abs light will go off on there own after doing basic settings on them
  3. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    Yeah long coding helper should show you how to do it properly mate.
  4. gynads
    gynads Member
    314
    Did this sort it coling? Had the same issues
