mfsw advice please
gas-man Oct 29, 2012
  1. gas-man
    gas-man Member
    215
    hi everyone
    doing a deal on a3 spoke mfsw steering wheel with airbag from a 09 a3 to fit on my 2005 avant which as a 4 spoke mfsw
    will this work and if yes will it need coding
    many thanks in advance
    ps did do a quick search but the deal is to go ahead in a little while so just trying to make sure
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    116
    It will work but it will need coding and will also need a Highline Steering ECU, which you probably wont have.
  3. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Is that true? - since gas-man says he already has an MFSW (a 4-spoke one) won't his SCSM already work with the A3 MFSW?
  4. gas-man
    gas-man Member
    215
    thanks for your replies guys
    really hopeing this is just an easy straight swap out
    so if anyone can give me the answer i dont want to be :banghead:
  5. s8craig
    1,750
    55
    2005 is it a B6 or B7 you have, B6 use single stage airbag wheels with buttons. The A3 will be a dual stage airbag. That may be your first issue.
    If you have a B7, then I don't see any problems except making up the correct airbag loom.
  6. gas-man
    gas-man Member
    215
    thanks graig it is a b7 not sure i understand about the loom?
  7. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Straight swap no coding needed as you already have a MFSW.
    Only issue may be the airbag loom connector to the slip ring as it may be slightly different to that of the A3. You can always test first and if does not fit, then swap the loom from your 4 spoke airbag.
