Hi
I replaced my steering wheel with a 3-spoke MFSW (including a new control module ”highline” version).
Now the horn and the steering wheel buttons are not working (but the buttons are illuminated weakly) .
I did (hopefully) the correct coding through VCDS and there are no error codes at all.
(I'm aware of the different slip ring types, but the control module should should fit.)
Could there be a compatibility problem or a wiring issue? The only thing I did was to connect the small black plug on the airbag to the socket at the steering wheel and adding a fuse. Should any other cables be changed or added - or is this still a coding issue?
Thanks...
Best regards,
ksp
Thanks...
Best regards,
ksp
