Got a quote from All German Parts for the complete set for £350 which seems like a good price. Has anyone seen the set cheaper anywhere else?
I thought so too. I bet the kit makes one hell of a difference. Any particular points to bear in mind when fitting it all?
You fitting yourself or garage?
Local garage. I've heard there's a procedure for torquing up as the car is lowered back onto it's wheels, if you know what I mean?
Do all b6 have two upper ones on each side or is it just the s4?
they all have two top arms.
That's £405
Who's fitting it AGP
Yeah looking above two sets with different part numbers
How do you know if you need the16mm or 20mm kit?
I would highly advise not to use anything but Lemforder control arm components.
Lemforder produce these OE for Audi on B5/B6/B7 etc.
By using non genuine components such as Meyle, you will actually pre-load the rest of the arms in the system, and cause premature failure of the other components.
You can purchase the OE Lemforder set for a very competitive rate!
For example, B6 S-Line kit for front end:
AGP have access to purchase these as well, just ask for Lemforder components.
If anyone would like further info just reply/PM.
Surely fitting a COMPLETE set of Meyle for example is fine as there are no other arms in the suspension to pre-load as I replaced all of them, and all the ancillary parts like rod ends and drops to the FARB? I could understand it if you did a part replacement.....
Thats for a b5 audi a4.
This is the cheapest ive found b6 arms
AUDI A4 8E FRONT TOP BOTTOM REAR SUSPENSION WISHBONE ARMS LINK TRACK TIE ROD END | eBay
You're right!!
That's a good find above. About as cheap as you'll get I'd say.
