metalic rattle squeak when let of accel intermittent?
JUS3IN Nov 23, 2013
  1. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    hey all, since ive had the s3 occassionally at very low speeds while turning, below 10mph iv had a weird squeak rattle noise that happened very occassionally.. thought nothing of it but today it got alot worse?
    if im driving at 30 then let of i get a rattly/squeaky/nut in camshaft kinda noise... its still intermittent btw but obviously annoying ?
    thinking maybe aux belt tensioner or aircon pump bearings???
    its a 1999 apy s3, with 144000 any help?
  2. ant schof
    ant schof Member
    163
    Hi Justarn ,
    Check out your alternator clutch pulley as mine made a similar screech noise before it went on my S3 . If you remove the multi v belt the alternator clutch pulley should only move one way , to do this you will need to lock the alternator from moving using a screwdriver or such . Hope this helps ,
    Ant
    JUS3IN likes this.
  3. JUS3IN
    1,159
    102
    hey ant, thanks i'll have a look. it had a new alternator just before i got it apparrently, in april, but prob a crappy pattern part...
  4. JUS3IN
    1,159
    102
    been flat out at work, have a look the weekend.. anyone else had a similar experience when there alternator clutch gave up?
