Metal or plastic impeller water pump? Which one is best?
Mk21147 Apr 11, 2011
  1. Mk21147
    Mk21147 New Member
    Thinking about doing the timing belt on the Rallye (1.8T 20 valve BAM engine)just wanting advice & recommendations on wether to use the metal impeller water pump from GSF or the standard plastic water pump from Audi? What do people think? Have the Audi water pumps been improved? I know the car is not an S3, but I am running an S3 engine, so thought this would be a good place to ask.
    Richard
  2. Sandip
    2,456
    99
    Metal :)
  3. MURRAYS444
    MURRAYS444 Member
    790
    Metal impeller is the best for the water pump as its stronger and the plastic one shreds away also VW and Audi don't stock it!
  4. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Im running metal in mine and did in my mk2 20vt also. No problems at all
  5. S3Steve
    S3Steve Active Member
    1,621
    20
    Personally had mine changed to metal impeller when i had my cambelt done, the plastic ones are a known weak point.
  6. audi-tk
    audi-tk Member
    441
    ive just had mine done with a plastoc impeller. should have got z metal one but was saving on cash hope it will be ok lol
  7. Steveo_A3_1.8t
    Steveo_A3_1.8t Member
    197
    Does anyone know if ALL ages of 8L 1.8t a3's have plastic impellers?? Or did they sort the later ones out?? I have a 2002
  8. jojo
    28,995
    3,640
    I'm running a metal one too, but apparently, a new plastic one is update and won't break apart like the early ones.
  9. aragorn
    18,579
    868
    TBH as long as the pumps are changed reasonably regularly (ie with the timing belt) you'll never have a problem with a plastic impeller pump.
  10. DenCar
    DenCar Member
    404
    My wifes A3 is 2002 and when we had the Cam Belt done and the Water Pump changed last year, the plastic impellar had broken in half, the new pump has the metal impellar, dont think you can get a plastic one from Audi now.
    DC
  11. DavidW
    DavidW Member
    211
    On the flip side I pulled mine a few weeks ago which I assume had been in there since new and it was intact, 10 year old car.
    I still replaced it with a metal one for peace of mind though.
  12. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    im running metal now also after changing from a damage plastic one
  13. <tuffty/>
    21,798
    4,170
    I would personally just use a VAG one with a plastic impeller... the metal ones I have seen while not breaking apart have leaked through the shaft seals...
  14. aragorn
    18,579
    868
    yeh i'd rather have a quality part with a plastic impeller than a **** part with a metal one.
    The Valeo pump i baught for this BAM rebuild has a plastic impeller.
  15. Steveo_A3_1.8t
    197
    Yeah your right there mate, I know every one thinks it's a common fault but if you do it with the cambelt it's ok. I know I'm hijacking this thread abit (sorry) but does anyone know prices of VAG cambelt, tensioner and waterpump??
    Steve
  16. aragorn
    18,579
    868
    I baught mine from Jason at AllGermanParts
    From memory the belt and tensioner was about 70quid, and the water pump was about 20.
    Drop Jason an email and get the correct prices for your engine.
  17. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    mine is beeing change for another plastic one when spoke to awesome they said they are getting problems with the metal one leaking at the seals and non from the plastic one so im sticking with genuine audi parts
  18. Nilz
    11,364
    903
    I have a metal one on mine as well, had all the work done at Midland VW.
    You can get the kits for cheap from ECP or GSF, but average price to get it done at a local independant would be between £250-£350.
  19. Mk21147
    Mk21147 New Member
    Thanks for the replys, I think I am going for a VAG plastic impeller one.
