metal on metal sound and rear wheel wobble
ScoobyA4 Apr 16, 2007
  1. ScoobyA4
    ScoobyA4 ding dang do
    185
    sorry for this chaps, but car are not my area of expertise! :D
    i got my 1997 1.9tdi 110 A4, it had done less than 6k miles in the 2yrs the last owner had (old bloke, whose wife drives everywhere!) and spent the rest of the time in garage being polished! it had it a major wheel wobble and a metal on metal clunking noise (front drivers side i think). i've had 3 of the top arms replaced as they needed it, with the final one (passenger side) yet to be done. the clunking is still there when you go over rough ground. apparently all the other bushes / arms are fine. any ideas?
    The wheel wobble was more than likely due to the front tires, which since i've replaced, has lessen the wobble. however, when i hit 70mph travelling up to 80mph there is a wobble which is most definately coming from the rear as the stearing wheel is stead throughout. I've yet to have tracking done due due to final arm being replaced, but i doubt that would cause the rear wobble. could this be the tires again? TBH i dont want to run out and pay £150+ to replace two legal tires to check if it is the tires. What can cause rear wheel (or percieved rear wheel) wobble? Should i just go replace the tires?
    Cheers for any help offered...
  2. MrJoshua
    MrJoshua '98 A4 2.4 SE
    104
    I'd suggest the rear wheel bearing needs replacing... Or at least looking at by a mechanic.
    When I got mine, the rear wheel was almost falling off!
    Replaced this (along with rear discs and pads) and had all 4 wheels balanced and we're good to go.
  3. ScoobyA4
    185
    Cheers, what cost did that get you for?
  4. MrJoshua
    104
    I'll tell you when I get the bill :crying:
  5. Phantom_A4
    Phantom_A4 Member
    563
    Yep sounds like a wheel bearing, or your wheel tracking!
    Bearings aren't expensive, neither is the tracking so it's not bad!
    Bearing from eurocarparts is about £20 for the kit. tracking varies on garage really :)
  6. joost
    joost Active Member
    1,169
    Could also be a buckled wheel, no amount of balancing or tracking will sort that though.
  7. ScoobyA4
    185
    is it a good bet then to have the tires changed regardless on the back? i would get the benefit out of them as i'm likely to do around 30-40k a year...
  8. scrupes
    scrupes bloody great extension bodger
    236
    Scooby.. yeah it would be a good idea to change the rears, just because they have tread dosen't mean the tyre is good! especially if the car has stood for any length of time.
  9. Lowlife
    Lowlife German Hardcore
    568
    Did you get to the bottom of this as I have the same problem?
  10. jcb
    jcb Active Member
    4,132
    13
    what wheels do you have?
  11. Lowlife
    568
    19" RS6 reps, have swapped wheels over to check they are not buckled. Its from the offside rear.
