Merc wheels onto A4?
audinary Mar 1, 2010
  1. Geeman
    Geeman Low Life
    1,318
    It was a stolen image from Google... I can't take credit!
  2. aragorn
    18,677
    882
    Audi uses radius seat as standard, what do the merc rims have at the moment?
  3. Geeman
    Geeman Low Life
    1,318
    Do they? ****** me... I could have sworn all of mine are tapered. I'm going to have to check tonight now! lol
  4. aragorn
    18,677
    882
    Well both my original 16's and the 17" boleros have radius seats!
  5. Geeman
    Geeman Low Life
    1,318
    You got me worried now...
  6. audinary
    audinary Complete And Utter Member
    676
    Interestingly, both are radiused, about the same radius too, it turns out, and they both obviously have 17mm heads and similarly sized collars.
    The pic shows the orig. Merc bolt on the left, the Bolts from the car I got the RS4s from and the Bolts from my car (on the right, the niceset looking)
    I need radiused bolts with the length of the Merc ones but the diameter of the Audi ones. I Have no idea why the bolt in the middle (of a scrappage '96 A4 2.6) should be tapered!
    Good news that they are both radiused, though. Less machining required.
    Edit:- It turns out the bolts the RS4s are currently attached to my car with are wrong! I need to swap for the taperd bolts currently on the 2.6! Probably not an emergency....
  7. audinary
    676
    Don't panic, mate, if both our rims fall off we can start some kind of club...
  8. aragorn
    18,677
    882
    The replica RS4's will probably have the taper seat, because they arent genuine and taper is a bit more common.
    The genuine Audi wheels you had before were probably using the radius bolts.
  9. audinary
    676
    Yup. Guilty as charged, didn't think about the bolts when I swapped the wheels. Might swap them back today if I get the chance
  10. audinary
    676
    Bolts and spigots now ordered
  11. audinary
    676
    Snag:- Off to Machine Mart tomorrow to pick up a big drill bit which I can actually use with my drills.... (13mm chuck max)
  12. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    You need an adapter. You can buy them from B&Q.
  13. audinary
    676
    Rather have the bits. Machine Mart have a set of 6 from 13-22 mm for £20ish
  14. phoenixv6quattro
    1,396
    Thats pretty good! Cancel my last....
  15. audinary
    676
    For those of you following this exciting thread, the Spigots and Bolts have arrived. Just need to finish with this flipping hub bearing and they're ON!
  16. voteforpedro
    voteforpedro Member
    632
    DOOOOOOOO EEEEEEEEEEET.
    Interested to know final cost, with tyres and all bits. :)
  17. Foxmeister
    Foxmeister Fired Up!
    1,785
    9
    Sure it'll be worth the effort mate!:icon_thumright:
  18. audinary
    676
    An anonymous benefactor has gifted me the latest addition to the Audi Of Many Brands... a set of Brabus locking wheel bolts. Should be good for 10% across the rev range.
    Here the are along with my glorious red anodised spigots and shiny new wheelbolts.
  19. diesel-a4
    diesel-a4 Stoned As Fuk
    162
    here my setup from a few weeks ago,
    front one has been refurb since that photo and shes a little lower now
  20. audinary
    676
    Cool, yours is somewhat lower than mine...
  21. aragorn
    18,677
    882
    too low :(
  22. Geeman
    Geeman Low Life
    1,318
    Not low enough...!
  23. aragorn
    18,677
    882
    :asskicking:
    :w00t:
  24. Broken Byzan
    13,244
    468
    Don't get him started on tyre stretch/poke :respekt:
  25. Geeman
    Geeman Low Life
    1,318
    Naaaaah, no poke from me. It's all about the tuck! :laugh:
    It is too high though... you can still plainly see tread on the tyre in the arch... :whistle2:
  26. audinary
    676
    Saves a lot of wear and tear on the suspension when your car physically rests on the road surface...
  27. aragorn
    18,677
    882
    ROFL aye!
    Might be better rolling it onto its side though? or even the roof? That way theres no weight on the wheels to deform the rubber either!
  28. audinary
    676
    They're on!
    At 5 minutes past Simpsons tonight my Father and I went into the garage to embark on what could have been a fateful mission. I had in my possession a set of four AMG Mercedes wheels, of course set up for W202 fitment (10mm bolts). So, to get them on the A4 I would need to widen the holes, sticking to the 5x112 PCD and as accurately as possible.
    And we did it. Perfectly.
    I had played with various ways of getting the accuracy I needed, but we ended up using a modified table-top pillar drill, with the base plate turned upside down to sit flat on the wheel mounting surface. We would then manouever the bit until it was centred on the exsisting holes, gradually increasing the bit size.
    This was the apparatus we used. I measured the original holes to be around 13mm (which seemed wide for a 10mm bolt) so, working with that sort of tolerance I figured we'd go with a 15mm hole, so we started the drilling with a 14mm bit.
    Fortunately, assuming we lined up properly the bit pretty much auto-centred on the original hole as soon as it made contact with the the metal. After the first 5 holes were drilled, inspection of the prototype wheel (I chose the tattiest one for this) revealed our drilling to be absolutely bang on. Looking at the holes from the front, they are dead smack in the middle of the radiused parts of the original holes. I was chuffed.
    Similarly chuffworthy was the fact that the new wheel bolts were a perfect fit in the new holes, so we didn't need to go up to 15mm. A test fit of the first wheel onto the car showed that the holes lined up perfectly with the hub, the bolts went straight in with no interference. And the same went for the next 3 wheels, and the next 15 holes.
    Test drive revealed a bit of tyre noise (this should reduce after a bit of inflation) most noticable on deceleration. But nothing to fret about.
    Pics coming when car is clean. I love suspense!
  29. aragorn
    18,677
    882
    Lol you do love keeping us waiting!!!
    The tyre noise might just be down to the brands of tyre fitted, different tyres/tread patterns will make varying levels of noise.
    The Merc bolts will have been M12 not M10, and you've gone up to M14. The less metal removed the better though, perhaps running a 9/16th drill thru the hole just to clearance it out a little bit might help if your finding the bolts a little snug.
  30. Geeman
    Geeman Low Life
    1,318
    They're going to be chuffworthy!
  31. audinary
    676
    Yeah, you're right, they were M12 (user error) but the M14 Audi bolts aren't too snug. I greased the new bores with LM just for a little protection.
    First proper drive on them today, loads of tyre noise from the front but I'm putting that down to the Sunny (Who?!!!!1!1!1eleven) brand tyres. Rears are Kumhos. Loads of tread, fortunate 'cos I'm really not looking forward to buying the next pair...
    And I believe them to be chuffworthy indeed. But, Gee, My good man, it does need lowering.... I'm not planning to slam it on the deck, though, I have my back to worry about.
  32. audinary
    676
    So, pics then.
    I love them, really suits the age of the car, celebrating all that was hip with the late '90s.
    It could do with a little bit of lowering, maybe 20mm or so, but I quite like the stance. Looks quite tough from the rear 3/4. Shame it's FWD...
    Wheels and tyres:- £0.
    Mounting spigots:- £19.99 + £4 p+p
    Wheel bolts:- £19.99 + £4 p+p
    Drilling wheels to accept Audi bolts:- £0
    Total project cost:- £47.98.
    Most distinctive car at work:- £Priceless.
  33. aragorn
    18,677
    882
    Its certainly different!
    I think its a wheel that needs the car to be low to work well, but ye 20mm off the ride height would probably make all the difference, along with some facelift lights.
    For some reason it looks like theres a lot of rake? are the rear tyres larger diameter than the fronts or something?
  34. audinary
    676
    There might be a few mm in it, but nothing drastic. Fronts 225/45/17, rears 245/40/17. Different is good!
  35. ALPINE
    3,093
    slam it! lol
    you nutta drilling wheels!! well done tho nice write up too! :respekt:
  36. aragorn
    18,677
    882
    Ye your right, the front is actually slightly larger in diameter!
  37. phoenixv6quattro
    1,396
    Looks ok mate........Def needs lowering!!!
  38. audinary
    676
    Cheers guys, lowerage will occur in due course.
    My concerns about tyre noise seem well founded, according to teh internets public opinion is that "Sunny" tyres are the noisiest rubber in the entire world, and can be recognised by their humming, turbine like sound. Shat, in other words.
  39. Geeman
    Geeman Low Life
    1,318
    Sunny tyres are garbage! lol
  40. audinary
    676
    Mummy, they're laughing at me!
    (I think I'd do a better job of making my own tyres in the workshop out of licorice and mild steel)
