Meh problems
Stu-pid Sep 15, 2013
  1. Stu-pid
    Stu-pid Member
    84
    Right then this weekend I fitted my new control arms and hid's in the process I found my plenum had some water in but not alot so I took out the grommets. Now when I turn my headlights on I get my dash looking like a Christmas tree. The abs light comes on flashing brake on the dis traction control light on. But all ok until I turn the lights on. It still drives fine. Any ideas or do I need to get it on vag com to have a look at it
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,202
    160
    Lift the passenger carpet and check for water.
  3. benjie
    benjie Well-Known Member
    1,223
    304
    The warning lights are a well documented issue. It's the ballasts on you your HIDs. I can't rememember the reason they cause it, but do a search on google or this forum for it and you'll find loads of threads.
  4. Stu-pid
    Stu-pid Member
    84
    That sounds more like because if I turn the lights on then start the engine I get no lights at all
  5. hades-
    9,481
    646
    its the ballast
    either cheap ****
    or its to close to the abs unit on the passanger side
  6. Stu-pid
    Stu-pid Member
    84
    Probably cheap, I've got them mounted under the headlight.
  7. quattrojames
    14,050
    576
    Move them back up near the bulkhead, that often helps.
  8. Stu-pid
    Stu-pid Member
    84
    It was the passenger side one that was causing problems as I tested them as I was removing them from the car. Sold them to a mate at work for his mondy st
