Measuring blocks??
Lee Goodall Sep 5, 2008
  1. Lee Goodall
    Lee Goodall Active Member
    2,279
    On my 1996 A4 (AEB engine) I can't find a measuring block 32 in engine electrics?
    I can read from block 0 to 28 (around 28?) but no higher.. is this due to the older type ECU that the 96 A4 used and if so which block is the equivalent to 32/fuel trim?
    Cheers.
  2. Longman
    Longman vassdignostics.co.uk
    Have you got a genuine cable? If its not, you can't register it and you will be limited to which blocks you can use.
    30 - 32 are to do with fuel trim. I don't know why you would have trouble connecting if its genuine
  3. Lee Goodall
    2,279
    I'm using a hand held VAG scanner (not a cheap one) and all the other functions work fine? It has most of the features that VAG.COM has.
    I can read all of the other measuring blocks ok.
    How are the figures displayed for fuel trim?
    Cheers.
  4. Longman
  5. Lee Goodall
    2,279
    I'll have another look to see if I can figure it out and report back.
    Thanks a lot for your help.
  6. Broken Byzan
    13,237
    466
    Only later cars have all the listed blocks, as the requested and actual boost figures are often refered to and we cant use any of those features
    http://www.ross-tech.com/vag-com/m_blocks/
    States from 1999 and up
  7. Lee Goodall
    2,279
    Nice one.. cheers mate.
  8. Sebastian
    Sebastian Member
    286
    The factory repair manual does give you a list of supported measuring blocks as well as a description of their meaning. Current versions of VCDS also come with proper label files displaying the same type of information in the software right when looking at the individual data. As Byzan already wrote, the AEB does not use the standardized measuring block scheme known from later models.
