measuring blocks for boost and afm on passat?
@udi A3 May 17, 2013
  1. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,802
    192
    I know its not Audi but a guy round the corner from me is having limp mode issues possibly boost related. Ive logged 3 10 and 11, I think I can see requested boost graphs but lazy actual boost, however the labelling isnt great. Car is a y reg 1.9dt 100bhp passat
    Also the afm values, I think im seeing expected value topping out at 850mg but the other reading never really makes it there.
    Again im not 100% im reading blocks correctly. Yesterday the car felt flat all the time no turbo, n75 actuates in output tests. Today he Mr muscled and was a clear different but still limp mode.
    There were a couple of fault codes
    00741 brake pedal monitoring implausible signal
    00575 intake manifold pressure 17-10 control difference intermittent
    Any ideas?
    thanks tom
  2. christof71
    christof71 Member
    60
    write engine code:-}
  3. @udi A3
    1,802
    192
    Sorry just pulled the log off my other machine.
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    Mileage: 362470km/225228miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 028 906 021 GL
    Component: 1,9l R4 EDC 00SG 1446
    Coding: 00002
    Shop #: WSC 05314
    VCID: 5FCD1DB7DD29DDE0786
    3 Faults Found:
    00741 - Brake Pedal Monitoring
    27-00 - Implausible Signal
    00575 - Intake Manifold Pressure
    17-10 - Control Difference - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 -
    Readiness: N/A
  4. christof71
    christof71 Member
    60
    I mean engine code {for example, ANZ}
    [TABLE="width: 100%"]
    [TR]
    [TD]Self diagnosis
    Fault table
    Notes:
    • [SIZE=-1]◆ [/SIZE]The fault table is listed according to the 5 digit fault code on the left.
    • [SIZE=-1]◆ [/SIZE]Before renewing components indicated as being faulty, check the wiring and connectors to these components as well as the earth connections using current flow diagram. This is particularly relevant if faults are output as "occurring sporadically" (SP).
    [TABLE]
    [TR]
    [TD="colspan: 2, align: left"]V.A.G 1551 print-out
    [/TD]
    [TD="align: left"]Possible causes of fault
    [/TD]
    [TD="align: left"]Possible effects
    [/TD]
    [TD="align: left"]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00513
    [/TD]
    [TD="align: left"] [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Engine speed sender -G28
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]implausible signal
    [/TD]
    [TD="align: left"]- G28 defective
    - Distance speed sender/sender wheel too large
    - Metal swarf on G28 or mounting pedestal loose
    [/TD]
    [TD="align: left"]- Fault lamp lights up
    - Increased idling speed
    - Poor starting
    - Engine runs rough
    - Reduced output
    - No indication on rev-counter
    [/TD]
    [TD="align: left"]- Check G28
    =>Page 23-36
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]no signal
    [/TD]
    - Wiring open or short circuit
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00519
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Intake manifold pressure sender -G71
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Charge pressure control solenoid valve (N75) defective
    - Control unit defective
    - Hose connections interchanged, not connected
    [/TD]
    [TD="align: left"]- Reduced output
    - Increased emission figures
    [/TD]
    [TD="align: left"]- Check N75
    =>Page 23-37
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Short to positive
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Short to earth
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00522
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Coolant temperature sender -G62
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- G62 defective
    - Wiring short to earth
    [/TD]
    [TD="align: left"]- Black exhaust when starting
    - Engine pre-heating not operating
    - Glow period always approx. 20 sec.
    [/TD]
    [TD="align: left"]- Check G62
    =>Page 23-43
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Open circuit/ short to positive
    [/TD]
    - Wiring open circuit or short to positive
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Output on V.A.G 1551 printer
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00527
    [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Intake manifold temperature sender -G72
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- G72 defective
    - Wire has short to earth
    [/TD]
    [TD="align: left"]- Engine pre-heating not operating
    [/TD]
    [TD="align: left"]- Check G72
    =>Page 23-51
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Open circuit/short to positive
    [/TD]
    - Open circuit or short to positive
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00528
    [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Altitude sender -F96
    [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Open circuit/short to earth
    [/TD]
    [TD="align: left"]- F96 defective
    - Wiring open circuit or short to earth
    [/TD]
    [TD="align: left"]- Black exhaust at altitude
    [/TD]
    [TD="align: left"]- Check F96 => Page 23-40
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00532
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Current supply
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Current supply relay terminal 30 (J317) defective
    [/TD]
    [TD="align: left"]- Various running problems including engine will not start
    [/TD]
    [TD="align: left"]- Check current supply for Diesel direct injection system control unit
    =>Page 23-51
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00539
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Fuel temperature sender -G81
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- G81 defective
    [/TD]
    [TD="align: left"]- Increased emission figures
    [/TD]
    [TD="align: left"]- Check G81
    => Page 23-56
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00542
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Needle lift sender -G80
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Input open
    [/TD]
    [TD="align: left"]- G80 defective
    [/TD]
    - Engine runs rough
    - Reduced output
    [/TD]
    [TD="align: left"]- Check G80
    => Page 23-63
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Injection system wiring to 3rd cylinder not OK.
    - Fuel shortage
    - Air in fuel system
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00550
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Commencement of injection control
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Control difference
    [/TD]
    [TD="align: left"]- Commencement of injection valve (N108) defective
    - Needle lift sender (G80) defective
    - Fuel tank empty
    - Fuel supply not OK., fuel shortage
    - Start of delivery not OK
    [/TD]
    [TD="align: left"]- Engine runs rough
    - Reduced output
    - Poor cold start characteristics
    [/TD]
    [TD="align: left"]- Check N108
    =>Page 23-24
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00553
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Air mass meter -G70
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- G70 defective
    [/TD]
    - Black exhaust
    [/TD]
    [TD="align: left"]- Check exhaust gas recirculation and air mass meter function
    =>Page 23-83
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00575
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Solenoid valve for charge pressure control (N75) defective
    [/TD]
    [/TD]
    =>Page 23-67
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00625
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Speed signal
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- With electrical speedometer: no signal from speedometer (G21) / speedometer sender (G22)
    - With mechanical speedometer: no signal from speed sender (G54)
    [/TD]
    [TD="align: left"]- Indicated speed incorrect
    [/TD]
    [TD="align: left"]- Check signal from G21, G22 or G54
    =>Page 23-86
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00626
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Glow period warning lamp -K29
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Wiring open circuit
    - Bulb defective
    [/TD]
    [TD="align: left"]- Glow period warning lamp not functioning
    [/TD]
    [TD="align: left"]- Check glow period warning lamp -K29
    => Current flow diagrams, Electrical fault finding and Fitting locations binder
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]- Short to earth
    [/TD]
    [TD="align: left"]- Glow period warning lamp permanently on
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Short to positive
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Ouput on V.A.G 1551 printer
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00668
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Vehicle current terminal 30
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Signal too small
    [/TD]
    [/TD]
    [TD="align: left"]- Engine will not start
    [/TD]
    [TD="align: left"]- Check Diesel direct injection system control unit current supply
    =>Page 23-51
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00671
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]CCS Switch -E45
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]undefined switch position
    [/TD]
    [TD="align: left"]- E45 defective
    - Wiring open/short circuit
    [/TD]
    [TD="align: left"]- Cruise control system switched off
    [/TD]
    [TD="align: left"]- Check cruise control system
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00741
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Brake pedal monitoring
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Brake light switch (F) defective
    - Brake pedal switch (F47) defective
    - Both switch positions not synchronised
    [/TD]
    - Brake light defective
    [/TD]
    [TD="align: left"]- Check F and F47
    =>Page 23-47
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00765
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Modulating piston movement sender -G149
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]- Injection pump defective
    [/TD]
    - Engine stops
    [/TD]
    [TD="align: left"]- Check G149
    => Page 23-59
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]00777
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Accelerator position sender -G79
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- G79 defective
    - G79 incorrectly set
    [/TD]
    [/TD]
    [TD="align: left"]- Check G79
    => Page 23-18
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Wiring short to positive
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01028
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Fan relay -J323
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Relay defective
    [/TD]
    [TD="align: left"]- Fan run-on not functioning
    [/TD]
    [TD="align: left"]- Check J323
    =>Page 01-35, final control diagnosis
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Fan runs permanently
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01044
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Control unit incorrectly coded
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD="align: left"]- Invalid control unit coding
    [/TD]
    [TD="align: left"]- Code control unit
    =>Page 23-92
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01117
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Load signal for alternator terminal DF
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Alternator defective
    - Voltage regulator defective
    [/TD]
    [/TD]
    [TD="align: left"]- Check alternator
    => Current flow diagram, Electrical fault finding and Fitting locations binder
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01180
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Engine/air conditioner cut-off electrical connection
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Short in the wiring
    [/TD]
    [TD="align: left"]- Vehicle acceleration reduced, when air conditioner is switched on
    [/TD]
    [TD="align: left"]- Check air conditioner compressor cut-in
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01193
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Low heat output relay -J359
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Low heat output relay -J359 or high output relay -J360 defective
    [/TD]
    [TD="align: left"]- Engine preheating not functioning
    [/TD]
    [TD="align: left"]- Check J359 or J360
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]
    - Short to earth
    [/TD]
    [TD="align: left"]- Engine preheating permanently on
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01237
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Fuel cut-off valve -N109
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]mechanical fault
    [/TD]
    [TD="align: left"]- N109 defective, leaking or sticking
    [/TD]
    - Engine stops
    [/TD]
    [TD="align: left"]- Check N109
    =>Page 01-35, Final control diagnosis
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Open/short circuit to earth
    [/TD]
    - Wiring open circuit/short to earth
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01242
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Control unit output stages
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Open/short to positive
    [/TD]
    [TD="align: left"]- All components activated by final control diagnosis
    [/TD]
    - Engine stops
    [/TD]
    [TD="align: left"]- Carry out final control diagnosis =>Page 01-35
    Check wiring connections to control elements
    Control unit defective if control elements OK.
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01262
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Charge pressure control solenoid valve -N75
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Solenoid valve defective
    [/TD]
    - Charge pressure too low
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Charge pressure too high
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01265
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Exhaust gas recirculation valve -N18
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Exhaust gas recirculation valve defective
    [/TD]
    [TD="align: left"]- No exhaust gas recirculation
    [/TD]
    [TD="align: left"]- Check N18
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Too much exhaust gas recirculation
    - Reduced output, black smoke
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01266
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Glow plug relay -J52
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Glow plug relay defective
    [/TD]
    [TD="align: left"]- Glow plug system not working
    [/TD]
    [TD="align: left"]- Check J52
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Glow plug system permanently on
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01268
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Quantity adjuster -N146
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    - Engine stops
    [/TD]
    [TD="align: left"]- Check N146
    =>Page 23-61
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Lower limit value
    [/TD]
    [TD="align: left"]- Quantity adjuster incorrectly set
    [/TD]
    [TD="align: left"]- Black smoke
    - Rough idling
    [/TD]
    [/TR]
    [TR]
    [TD="align: left"]Upper limit value
    [/TD]
    [/TD]
    [TD="align: left"]- Jerking, poor performance
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]01269
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Commencement of injection valve -N108
    [/TD]
    [/TR]
    [TR]
    [/TD]
    - Commencement of injection valve defective
    [/TD]
    [TD="align: left"]- Engine knocks at idling, because commencement of injection is constantly "advanced"
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [TD="align: left"]- Poor performance, because commencement of injection is constantly "retarded"
    [/TD]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]17978
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Engine control unit blocked
    [/TD]
    [TD="align: left"]- Immobilizer control unit defective/missing
    [/TD]
    [/TD]
    [TD="align: left"]- Match engine electronic control unit to the electronic immobilizer => Page 23-98
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD="align: left"]- Short in the communication wire
    [/TD]
    [TD] [/TD]
    [TD]- Check electronic immobilizer:
    => Repair group 96; Servicing electronic immobilizer
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD="align: left"]- Incorrect coding
    [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD="align: left"]- Attempted manipulation
    [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]65535
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: left"]Control unit -J248 defective
    [/TD]
    [TD="align: left"]- Control unit internally defective
    [/TD]
    - Engine stops
    [/TD]
    [TD="align: left"]- Replace J248
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
  5. christof71
    christof71 Member
    60
    [TR]
    [TD]Self diagnosis
    Evaluating measured value blocks, engine code AFN
    Display group 07 with ignition switched on (engine cold and not running)
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]→ Indicated on display[/TD]
    [TD][TABLE="class: displ, width: 100%"]
    [TR]
    [TD]Read measured value block 7 ⇒[/TD]
    [/TR]
    [TR]
    [TD]15.4 5C 15.9 5C 16.7 5C[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [TD="align: left"]Display zone
    [/TD]
    [TD]Display on V.A.G 1551/1552
    [/TD]
    [TD]Possible cause(s) of fault
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Fuel temperature
    [/TD]
    [TD]Approx. ambient temperature1)
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]-5.6 °C
    [/TD]
    [TD="align: left"]Short circuit or fuel temperature sender -G81 defective
    [/TD]
    [TD="align: left"]- Check G81 => Page 23-56
    In case of fault the measured value block indicates a fuel temperature of -5.6 °C
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    No display
    [/TD]
    [TD]---
    [/TD]
    [TD]---
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    Intake air temperature
    [/TD]
    [TD]
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]Approx. 136.8 °C
    [/TD]
    [TD="align: left"]Intake manifold temperature sender -G72 defective
    [/TD]
    [TD="align: left"]- Check G72 => Page 23-51
    In case of fault the measured value block indicates a constant intake manifold temperature of
    ca.136.8 °C
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Coolant temperature
    [/TD]
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Large deviation from ambient temperature
    [/TD]
    [TD="align: left"]Short circuit or coolant temperature sender -G62 defective
    [/TD]
    [TD="align: left"]- Check G62 => Page 23-43
    In case of fault the fuel temperature is shown alternately
    [/TD]
    [/TR]
    [/TABLE]
    1) Details of temperature specifications are not possible. When the engine is cold the fuel, intake air and coolant temperatures must equate approximately to ambient temperature. If a temperature deviates noticeably then the relevant sender must be checked.
    Display group 00 at idling speed (engine warm, coolant temperature not below 80 °C)
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]→ Indicated on display:[/TD]
    [TR]
    [TD]Read measured value block 0 ⇒[/TD]
    [/TR]
    [TR]
    [TD]43 56 0 24 90 204 59 155 154 116[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]41...45
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    [/TD]
    [TD]0...88
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 88
    [/TD]
    [TD="align: left"]- Continue with check in display group 04, => Page 01-87
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    Accelerator pedal position
    [/TD]
    [TD][/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 0
    [/TD]
    [TD="align: left"]- Continue with check in display group 02, display zone 2 => Page 01-83
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Quantity injected
    [/TD]
    [TD]11...45
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 11 or
    above 45
    [/TD]
    [TD="align: left"]- Continue with check in display group 01, => Page 01-81
    [/TD]
    [/TR]
    [TR]
    [TD]5 =
    [/TD]
    [TD]No specification1)
    [/TD]
    [TD]---
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]6 =
    Atmospheric pressure
    [/TD]
    [/TD]
    [TD]---
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]7 =
    Coolant temperature
    [/TD]
    [TD]35...80
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 80
    [/TD]
    [TD="align: left"]Engine too cold
    [/TD]
    [TD="align: left"]- Run engine at increased speed to warm up and repeat check.
    Continue with check in display group 07, display zone 4 => Page 01-76
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [TD]Possible cause(s) if fault
    [/TD]
    [TD]Fault elimination
    [/TD]
    [/TR]
    [TR]
    [TD]8 =
    [/TD]
    [TD]50...182
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]Below 50 or
    above 182
    [/TD]
    [TD] [/TD]
    [TD="align: left"]- Continue with check in display group 07, display zone 3 => Page 01-76
    [/TD]
    [/TR]
    [TR]
    [TD]9 =
    Fuel temperature
    [/TD]
    [TD]91...201
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 91 or
    above 201
    [/TD]
    [TD="align: left"]- Continue with check in display group 07, display zone 1 => Page 01-76
    [/TD]
    [/TR]
    [TR]
    [TD]10 =
    Mass of air drawn in2)
    [/TD]
    [TD]69...135
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 69 or
    above 135
    [/TD]
    [TD="align: left"]- Continue with check in display group 03 => Page 01-84
    [/TD]
    [/TR]
    [/TABLE]
    1) Displays in display zones 5 and 6 must approximately be the same.
    2) The measured values require the exhaust gas recirculation (EGR) to be switched on. The EGR is switched off after approx. 10 or 2 minutes at idling speed, therefore give burst on throttle or restart engine.
    Display group 01 at idling speed (engine warm, coolant temperature not below 80 °C)
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 1 "[/TD]
    [/TR]
    [TR]
    [TD] 840 rpm 6.5 mg/H 1.480 V 87.3 5C[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]861...945 rpm
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    Quantity injected
    [/TD]
    [TD]2.2...9 mg/H
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 2.2 mg/H
    [/TD]
    [TD="align: left"]Injection pump too rich
    [/TD]
    [TD="align: left"]- Renew injection pump => Page 23-19
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 9 mg/H
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Injection pump too lean
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    Voltage from slide valve sender
    [/TD]
    [TD]1.45...1.90 V
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 1.45 V
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 1.90 V
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Coolant temperature
    [/TD]
    [TD]80...110 °C
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 80 °C
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    Display group 02 at idling speed (engine warm, coolant temperature not below 80 °C)
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]→ Indicated on Display[/TD]
    [TR]
    [TD]Read measured value block 2 ⇒[/TD]
    [/TR]
    [TR]
    [TD]840 rpm 0.0 % 0 1 0 88.4 5C[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]861...945 rpm
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    [/TD]
    [TD]0 %
    [/TD]
    [TD="align: left"]Accelerator pedal not operated: OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]1...100 %
    [/TD]
    [TD="align: left"]Accelerator pedal position sender -G79 incorrectly adjusted or defective
    [/TD]
    [TD="align: left"]- Check G-79 and adjust if necessary
    => Page 23-87
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Wiring open circuit to G79
    [/TD]
    [TD="align: left"]- Check wiring connections to G79
    => Page 23-89
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    Operating condition
    [/TD]
    [TD]010
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]111
    [/TD]
    [TD="align: left"]Air conditioning switched on
    [/TD]
    [TD="align: left"]- Air conditioning switched off
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Coolant temperature
    [/TD]
    [TD]85...110 °C
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    Display group 03 at idling speed (engine warm, coolant temperature not below 80 °C)
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 3 "[/TD]
    [/TR]
    [TR]
    [TD] 840 rpm 290 mg/H 308 mg/H 54 %[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]861...945/min
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    Mass of air drawn in (specified)
    [/TD]
    [TD]230...450 mg/H
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 450 mg/H
    [/TD]
    [/TD]
    [TD="align: left"]- Run engine at increased speed, to warm up and repeat check.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    [/TD]
    [TD]230...450 mg/H
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]Mass of air drawn in (actual)1)
    [/TD]
    [TD]Below 230 mg/H
    [/TD]
    [TD="align: left"]Excessive exhaust gas recirculation
    [/TD]
    [TD="align: left"]- Check exhaust gas recirculation and air mass meter function => Page 23-79
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Unmetered air
    [/TD]
    [TD="align: left"]- Check intake air system for leaks.
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 450 mg/H
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Insufficient exhaust gas recirculation
    [/TD]
    [TD="align: left"]- Engine running at idling speed for 10 min., give burst on throttle.
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD="align: left"]Air mass meter -G70 defective
    [/TD]
    [TD="align: left"]- Check exhaust gas recirculation and air mass meter => Page 23-79
    In case of fault the measured value block shows a constant air mass value of approx. 555 mg/H over the complete speed and throttle range.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Duty cycle from exhaust gas recirculation valve
    [/TD]
    [TD]10...90 %
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    1) The measured values require the exhaust gas recirculation (EGR) to be switched on. The EGR is switched off after approx.10 or 2 minutes at idling speed, therefore give burst on throttle or restart engine.
    Display group 04 at idling speed (engine warm, coolant temperature not below 80 °C)
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 4 ⇒[/TD]
    [/TR]
    [TR]
    [TD]900 rpm 0.95 BTDC 1.25 BTDC 4 %[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]861...945 rpm
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    Commencement of injection (specified)
    [/TD]
    [TD]2° ATDC...
    4° BTDC
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 4° BTDC
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    Commencement of injection (actual)
    [/TD]
    [TD]2° ATDC...
    4° BTDC
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 4° BTDC
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Injection pump positioned "early"
    [/TD]
    [TD="align: left"]- Check and adjust commencement of injection dynamically => Page 23-24
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Commencement of injection valve -N108 defective
    [/TD]
    [TD="align: left"]- Check -N 108 => Page 01-35, final control diagnosis
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Retarded 2° ATDC
    [/TD]
    [TD="align: left"]Injection pump positioned extremely "retarded"
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Injection adjustment blocked
    [/TD]
    [TD="align: left"]- Check -N108 => Page 01-35, final control diagnosis
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Duty cycle from commencement of injection valve
    [/TD]
    [TD]2...95 %
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    Display group 13 at idling speed (engine warm, coolant temperature not below 80 °C)
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 13 ⇒[/TD]
    [/TR]
    [TR]
    [TD]0.82mg/H -0.12mg/H 0.49mg/H[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD]
    • The injection system is equipped with an idling speed smooth running control. There may be power differences between the individual cylinders (component tolerances, jet drillings, compressions etc.) which are recognised and equalized via selective injected quantities.
      Recognition at idling speed is via the signal from the engine speed sender which delivers four signals per crankshaft revolution to the control unit. If the signals are delivered at the same rhythm then all cylinders work the same. If one cylinder is weaker then the crankshaft takes longer for the next half revolution. Conversely a more powerful cylinder accelerates the crankshaft so less time is taken.
      If the control unit recognises a difference, then the relevant cylinder is given more or less fuel, until the engine runs evenly again.
      The measured value block displays the injected quantity differences of the individual cylinders compared with No. 3 cylinder that is required to ensure an even engine idling speed.
      +... mg/H: The relevant cylinder is less powerful than No. 3 cylinder and is therefore supplied with more fuel.
      -... mg/H: The relevant cylinder is more powerful than No. 3 cylinder and is therefore supplied with less fuel.
    Display group 00 at full throttle (test drive in 3rd gear, coolant temperature not below 80 °C)
    Notes:
    • [SIZE=-1]◆ [/SIZE]When testing, accelerate vehicle at full throttle.
    • [SIZE=-1]◆ [/SIZE]The measured values must be printed out or read (2nd person required) when the revolutions reach 3,000 rpm.
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [/TR]
    [TR]
    [TD]148 157 255 123 91 205 68 151 157 154[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]136...150
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 190
    [/TD]
    [TD="align: left"]Revolutions too high, engine governed
    [/TD]
    [TD]--
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    [/TD]
    [TD]138...188
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 138
    [/TD]
    [TD="align: left"]- Continue with check in display group 04, => Page 01-93
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    [/TD]
    [TD]255
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 255
    [/TD]
    [TD="align: left"]Not at full throttle
    [/TD]
    [TD="align: left"]- Repeat check at full throttle.
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Quantity injected
    [/TD]
    [TD]192...215
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 192
    [/TD]
    [TD="align: left"]- Continue with check in display group 08, => Page 01-95
    [/TD]
    [/TR]
    [TR]
    [TD]5 =
    [/TD]
    [TD]180...245
    [/TD]
    [TD]OK
    [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 180 or
    above 245
    [/TD]
    [TD="align: left"]- Continue with check in display group 11, => Page 01-99
    [/TD]
    [/TR]
    [TR]
    [TD]6 =
    [/TD]
    [/TD]
    [TD]---
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]7 =
    Coolant temperature
    [/TD]
    [TD]35...80
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 80
    [/TD]
    [/TD]
    [TD="align: left"]- Continue with check in display group 07, display zone 4 =>Page 01-76
    [/TD]
    [/TR]
    [TR]
    [TD]8 =
    [/TD]
    [TD]50...182
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 50 or
    above 182
    [/TD]
    [TD] [/TD]
    [TD="align: left"]- Continue with check in display group 07, display zone 3 =>Page 01-76
    [/TD]
    [/TR]
    [TR]
    [TD]9 =
    Fuel temperature
    [/TD]
    [TD]91...201
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 91 or
    above 201
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD]10 =
    [/TD]
    [TD]225...255
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 225
    [/TD]
    [TD="align: left"]- Continue with check in display group 10, display zone 1 => Page 01-97
    [/TD]
    [/TR]
    [/TABLE]
    Display group 04 at full throttle (test drive in 3rd gear, coolant temperature not below 80 °C)
    Notes:
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 4 "[/TD]
    [/TR]
    [TR]
    [TD] 3100 rpm 105 BTDC 105 BTDC 80 %[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]2850...3150/min
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    [/TD]
    [TD]8...12 ° BTDC
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    [/TD]
    [TD]Approx. commencement of injection (specified)
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]For large differences between specified and actual (approx. 5 ° crank angle)
    [/TD]
    Injection pump positioned incorrectly
    Air in fuel system
    [/TD]
    [TD="align: left"]- Check -N108 => Page 23-24
    Check fuel supply system
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    [/TD]
    [TD]60...98 %
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 60 or
    above 98 %
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    Display group 08 at full throttle (test drive in 3rd gear, coolant temperature not below 80 °C)
    Notes:
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 8 ⇒[/TD]
    [/TR]
    [TR]
    [TD]3290 rpm 38.4 mg/H 35.2 mg/H 35.7 mg/H[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]2850...3150 rpm
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    Quantity injected (driver's requirement)
    [/TD]
    [TD]43...45 mg/H
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 43 mg/H
    [/TD]
    [TD="align: left"]Not full throttle
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [/TD]
    [TD="align: left"]- Check G-79 and if necessary adjust
    => Page 23-87
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    Quantity injected (torque map)
    [/TD]
    [TD]40...42 mg/H
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 40 mg/H
    [/TD]
    [TD="align: left"]Speed too high or too low
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Quantity injected (opacity map)
    [/TD]
    [TD]38.5...44 mg/H
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 38.5 mg/H
    [/TD]
    [TD="align: left"]Mass of air drawn in too low
    [/TD]
    => Page 23-79
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Quantity of exhaust gas recirculated
    [/TD]
    => Page 23-79
    [/TD]
    [/TR]
    [/TABLE]
    Display group10 at full throttle (test drive in 3rd gear, coolant temperature not below 80 °C)
    Notes:
    • [SIZE=-1]◆ [/SIZE]When testing, accelerate the vehicle at full throttle.
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 10 "[/TD]
    [/TR]
    [TR]
    [TD] 830 mg/H 1030 mbar 1850 mbar 100 % [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    [/TD]
    [TD]850...1050 mg/H
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 850 mg/H
    [/TD]
    [TD="align: left"]Speed too low or too high
    [/TD]
    [TD="align: left"]- Read off specification at 3000 rpm.
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Charge pressure too low
    [/TD]
    [TD="align: left"]- Check charge pressure control
    => Page 23-67
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Air mass meter defective
    [/TD]
    => Page 23-79
    In case of fault the measured value block shows a constant air mass value of about 550 mg/H over complete speed and throttle range
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    Atmospheric pressure (air pressure)
    [/TD]
    [/TD]
    [TD]---
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    [/TD]
    [TD]1700...2500 mbar
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]Intake manifold pressure (charge pressure)
    [/TD]
    [TD]Below 1700 mbar
    [/TD]
    [TD="align: left"]Charge pressure control defective
    [/TD]
    => Page 23-67
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD="align: left"]Turbocharger defective
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 2500 mbar
    [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]4 =
    [/TD]
    [TD]100 %
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]Accelerator pedal position
    [/TD]
    [TD]Below 100 %
    [/TD]
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [/TD]
    => Page 23-87
    [/TD]
    [/TR]
    [/TABLE]
    Display group 11 at full throttle (test drive in 3rd gear, coolant temperature not below 80 °C)
    Notes:
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Read measured value block 11 "[/TD]
    [/TR]
    [TR]
    [TD] 3340 rpm 1830 mbar 1850 mbar 68 % [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD][TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed
    [/TD]
    [TD]2850...3150 rpm
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD]2 =
    Charge pressure (specified)
    [/TD]
    [TD]1900...2000 mbar
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TH][/TH]
    [/TR]
    [TR]
    [/TD]
    [/TD]
    [/TD]
    [TD]Fault remedy
    [/TD]
    [/TR]
    [TR]
    [TD]3 =
    Charge pressure (actual)
    [/TD]
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Below 1700 mbar
    [/TD]
    [/TD]
    => Page 23-67
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD="align: left"]Charge pressure hose not connected to control unit
    [/TD]
    [TD="align: left"]- Connect charge pressure hose
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]Above 2500 mbar
    [/TD]
    [/TD]
    => Page 23-67
    [/TD]
    [/TR]
    [TR]
    [TD]4 =
    Duty cycle from charge pressure control valve
    [/TD]
    [TD]45...94 %
    [/TD]
    [TD]OK
    [/TD]
    [TD]---
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
  6. christof71
    christof71 Member
    60
    Check charge pressure control:
    When the charge pressure is measured during a test drive, a second person is required, for reasons of safety, to operate the fault reader!!!
    • select engine electronics control unit (address word 01); selection is carried out with engine idling
    • [SIZE=-1] [/SIZE]Input 08 for "Read measured value block" function
    • [SIZE=-1] [/SIZE]Press keys 0, 1 and 1 for Display Group 11
    • [TABLE="class: displ, width: 100%"]
      [TR]
      [/TR]
      [TR]
      [TD] 840 rpm 938 mbar 978 mbar 92 %
      Accelerate vehicle in 3rd gear from about 1500 rpm using full throttle{test drive ,you need driver!!!}
      [TR]
      [/TR]
      [TR]
      [TD] 3090 rpm 1866 mbar 1917 mbar 62 % [/TD]
      [/TR]
      [/TABLE]
      [/TD]
      [/TR]
      [/TABLE]
  7. @udi A3
    1,802
    192
    This is what i did, the mbar figures though, which is actual boost and which is requested? In my graphs the first figure appears to be the requested, and the figures are always a lot higher, peeking out to a flat line, and the second set when plotted would suggest a very lazy turbo. Maybe the N75, but it was activating ok with output tests. Maybe the pipework.
    Im not sure on the engine code sorry. its the older style 1.9 tdi though doesnt look like a PD engine.
  8. christof71
    christof71 Member
    60
    [TABLE="class: cms_table_displ, width: 100%"]
    [TR]
    [TD]value block 11 "[/TD]
    [/TR]
    [TR]
    [TD]3340 rpm 1830 mbar 1850 mbar 68 %[/TD]
    [/TR]
    [/TABLE]
    [TABLE="class: cms_table"]
    [TR]
    [TH="align: center"][/TH]
    [/TR]
    [TR]
    [TD="align: left"]Display zone[/TD]
    [TD]Display on V.A.G 1551/1552[/TD]
    [TD]Possible cause(s) of fault[/TD]
    [TD]Fault remedy[/TD]
    [/TR]
    [TR]
    [TD]1 =
    Engine speed[/TD]
    [TD]2850...3150 rpm[/TD]
    [TD]OK[/TD]
    [TD]---[/TD]
    [/TR]
    [TR]
    [TD]2 =
    Charge pressure (specified)[/TD]
    [TD]1900...2000 mbar[/TD]
    [TD]OK[/TD]
    [TD]---[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [TD]3 =
    Charge pressure (actual)[/TD]
    [TD]1700...2500 mbar[/TD]
    [TD]OK[/TD]
    [TD]---[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Below 1700 mbar[/TD]
    [TD="align: left"]Charge pressure control defective[/TD]
    => Page 23-67[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD="align: left"]Turbocharger defective[/TD]
    [TD="align: left"][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: left"]Charge pressure hose not connected to control unit[/TD]
    [TD="align: left"]- Connect charge pressure hose[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Above 2500 mbar[/TD]
    => Page 23-67[/TD]
    [/TR]
    [TR]
    [TD]4 =
    All you have here are: -}
    3 =
    take a test drive as mentioned above, and save the logs value block 11[/TD]
    [TD]45...94 %[/TD]
    [TD]OK[/TD]
    [TD]---[/TD]
    [/TR]
    [/TABLE]
    your engine code is AFN
  9. @udi A3
    1,802
    192
    I dont suppose you have details of these pages? I just assumed the N75 was working with output tests I hear it clicking.
    Thanks tom
  10. christof71
    christof71 Member
    60
    check the boost pressure when driving in the channel 11, on the 3rd gear at engine speeds around 3200 rpm.{ Attache}
    Also chanel 10 {air mass meter }
    Replace the stop light sensor, it can also cause a loss of power.
    boost pressure and air flow meter is measured during the driving gear 3, as defined above.
    Measurements at idle do not make sense, because the motor is not loaded.
    is the n75 valve clicks that does not mean that it is good. N75 breaks down in such a way that closes after some time while driving, mostly as the coil heats up.
    It is not possible to verify it 100 percent , but for sure you can swap from the car in which there is no problem with loss of power
