ME7 Uni setting - HELP
S3 TAM Sep 1, 2010
  1. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Hi all,
    Downloaded this today but not really sure if i should me messing around with the settings without knowing what i'm doing!!!
    http://www.unitronic-chipped.com/main/en/tuning/uni_setting.html
    has anyone found a guide or even better has anyone used this before.
    I'm having a guess you read the ecu first then save a copy of what it reads then do what you need to do then and write to ecu. at least then i'll have a back up of the current state.
    what will i gain from changing the settings? any power???
  2. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    What on earth is it?? I've never seen that before and it looks kinda scary to use!
  3. jdas03
    jdas03 Member
    603
    If I read that right it allows you to essentially adjust values on the car to increase performance? So essentially remapping the car yourself?
    Sounds dodgy to me! Surely if you didn't know the limits and had done alot of research you could really do some damage!
    If you want more power get it remapped by a proper company, much safer and there maps are within known limitation
  4. jdas03
    jdas03 Member
    603
  5. S3 TAM
    624
    10
    Yeah thats what i think as well. I've already had my car remapped. just bored on the web found this. but like you say i'm scared as well last thing i want todo is f$#k the ecu.
    think im gonna leave it alone becuase not sure what this will do!!!
  6. Westy
    Westy Well-Known Member
    17,443
    1,103
    Mate you really are a nightmare sometimes haha. If you do a search on here I did a thread when I first got my S3 about the possibilities of remapping your own car and I had a load of software too (I think I spoke to you about it because you offered you golf as a guinea pig).
  7. <tuffty/>
    20,904
    3,713
    Word of warning... any changes made using Uni Settings should be logged... before and after!!!! if you start playing silly buggers with ECU settings and you don't know what you are doing or what could result from it then don't try it...
    There are plenty of guides on the web, Uni Settings is popular in the US... try VW Vortex and Audizine for starters...
    Enjoy :thumbsup:
  8. badger5
    9,405
    1,945
    play blind at your peril
    boost cannot be turned up with this only down..
    ign can be turned up - WARNING - too much will result in engine damage
    if its mapped and running properly now, you are just likely to **** things up and make it worse..
    do you know how to log?
    would you know what you are looking at from a log?
    if no to both - resist the temptation to mess your car up
    surmen over
  9. S3 TAM
    624
    10
    Yeah i agree tuffty, i think im gonna leave this alone.
    Westle i remember now.
    Leave this to the pro's!!!!
  10. S3 TAM
    624
    10
    Badger i've had vag com for about a month. So still learning. I have been loggin. But i can't say i know it inside out. no i dont really know what im looking at aswell. I'm not going to touch it becuase she is running sweet. Im not looking to damage my car.
    Thanks for the posts im glad i put this thread up before plug my car in.
  11. <tuffty/>
    20,904
    3,713
