Mcgard locking wheel bolts
Serberus Jul 9, 2007
  1. Serberus
    Serberus Member
    I've recently fitted some new RS4 alloys to my A3 and am in need of some locking bolts.
    I've found some 30mm shank length tapered ones on eBay (27181) but the rest of my bolts measure 28.5mm (27222) - wondered if the 30mm ones will fit?
    :think:
    Mcgard product specs: http://mcgard-europe.de/englisch/subolzen.htm
  2. jasaudi
    jasaudi Member
    144
    right, easy way to find out.
    Take off wheel and put existing bolt through hole in wheel so you see how much thread is sticking out. Mark or measure this protruding length
    Then mark another 2 mm on the bolt and put the bolt into the hub and wind in to the 2nd mark, this will equate to a longer bolt. Check the hub rotates without interference
    If it does then you should be fine
  3. Serberus
    Serberus Member
    Good thinking, ta.
  4. d3fy
    d3fy Active Member
    1,412
