Mayonaise on oil cap - diagnostic help please.
Rex16 Nov 17, 2011
  1. Rex16
    Rex16 Member
    31
    Hi, I've a 2006 2.0T, a couple of weeks ago I noticed a white film on the inside of the oil cap, I wiped it off and after approx 1k miles I've re-checked, there is the beginnings of another thin white layer of oil/water mayonaise. There isn't very much and I haven't noticed the coolant drop, but it is definately building up again.
    I've read several posts on this forum and it sppears it could be the headgasket or the oil cooler, is there an easy way to diagnose what the problem is?
    Thanks.
  2. LukeTripod87
    LukeTripod87 Active Member
    373
    52
    that is a possible cause or do you do lots of short journeys as that can cause it? my trip to work in the morning is only 3 miles so im always wiping that creamy **** off of my cap!
  3. Rex16
    Rex16 Member
    31
    Yeah, I mainly do short trips. How do short trips get water into the oil?
  4. Jonay
    Jonay Member
    274
    Yeah its the coolant/water getting into the engine. A pressure/compression test I guess is the only way to find out!
  5. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    Short journeys mean car doesn't warm up properly and I had a similar issue. Catch can cured it. but for general running around I wouldn't recommend one. Try and take it for a good run once a week.
  6. Farhan
    Farhan Active Member
    1,234
    57
    yer read up on the 2.0T engines you should try and give it a good thrashing occasionally. Also if you are unable to try and drive at a constant speed at 3000RPM so it stops carbon build up.
    Monitor it so it doesnt get worse but try and do a few longer journeys.
  7. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    my misses old seat leon 1.8t 20v use to do the same and its still running fine 2 years on.
  8. marknjayne
    marknjayne Member
    425
    its more than likely condensation in the oil as you dont get it to full temp on short journeys,go give it a good run ;)
  9. Rex16
    Rex16 Member
    31
    Thanks for the info guys, I'll keep a close eye on it and make sure I do a few longer journeys :yes:, Think I'll also get the cylinder compression tested for peace of mind.
  10. VeeDubDan
    VeeDubDan Active Member Team Monsoon
    264
    70
    It a common/normal thing really once the outside temps start to drop this time of year.
  11. audicruiser
    audicruiser Audi Heaven
    1,865
    Yeah mine does it with short runs... A good long weekend blast soon clears it!
  12. Audi-Rog
    Audi-Rog Six Audi's & Counting!
    258
    81
    Also check you have the right viscosity oil in your car, mine did it all the time during the winter. Then realised the garage had been putting the wrong oil in!:banghead: Then put the proper recommended (expensive) oil from Audi in, stopped doing it so badly.
    I remember when I first saw mayonaising in the filler cap, I thought I'd bought a car with a failing Head gasket! Then read the threads on here and breathed a huge sigh of relief!
    As said already just take your car out on a decent weekly run, that should help clear any moisture. (keep an eye on it though)
    :arco:
  13. gdbarratt
    gdbarratt A3 Sportback 2.0 T FSi
    67
    Just done a weekend clean up on my 2.0T FSi and when I checked the oil it was just at the half way point so thought I'd top her up. To my horror I found a large quantity of sludge on the oil filler cap, its a cream colour with a ting of green.
    Their is no loss of coolant, nothing on the dipstick.
    My journey to work is 10 miles, is this short enough not to clear the condensation?
    I was worried my head gasket might be going!
    How long do they last anyway? Mys car is an 05 with 63k on the clock.
    Car was serviced by Stoke Audi 5 weeks ago so would have thought they would have highlighted something.
    Thanks.
  14. audicruiser
    1,865
    10 miles isn't long enough especially in the winter. The car needs a good 50 mile constant drive to get to temperature to clear the sludge. It's normal at this time of year.
  15. marknjayne
    marknjayne Member
    425
    depends on how you drive,if you are stuck in traffic at 30 mph all the time then you will not get the condensation out and will build up the mayo
  16. gdbarratt
    67
    No it's quite a fast run with many sections at around 50 mph.
    I am off to Preston next weekend which is 56 miles away mainly down the M6 so I will see if this clears it - fingers crossed.
  17. marknjayne
    marknjayne Member
    425
    First thing I would do is drop the oil and get some fresh stuff in , as a matter of course I change mine every 3-4k miles
  18. gdbarratt
    67
    It was serviced at Stoke Audi 5 weeks ago so had an oil change then along with 60k spark plug change and MOT. Its on the annual Service Plan (rather than long life).
