May be a stupid question but is there such a thing as a Strut brace that will fit 8p?
SneakaFreaka83 Aug 27, 2010
  1. SneakaFreaka83
    SneakaFreaka83 ASN is hazardous 2 your wallet
    348
    as above guys..... may get mixed answers and comments on this as know my car is not the quickest but anyone know if there are any strut braces that will actually fit my car .. apart from the uprated looks is the handling alot better and can anyone comment? this may be a straight forward answer of no there is no point or that there are no products that fit.. either way your comments would be useful.. cheers dudes...:p
  2. smudge_don
    smudge_don Active Member
    2,944
    Isn't an ARB and a strut brace basically the same thing? Apart from 1 is underneath the car and 1 goes on top in either the engine bay or the boot?
  3. JohnS3
    JohnS3 Active Member
    3,032
  4. SneakaFreaka83
    348
    ahh really didnt know that...:think: thanks mate.... thought that the strut would give you extra support but if not the case I guess it may be better just to go for ARB's... the struts just a cheaper option then or has other benifits?..
  5. SneakaFreaka83
    348
  6. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    strut braces connect top mounts of suspension... they make a huge difference!! i had this beast on my Cooper S... GT TUNING PERFORMANCE Brakes/Suspensions etc
    it made a huge difference on front end grip... i dont know how much difference it would make on a A3... ive always thought the A3/S3 engine bay was too tight :uhm:
  7. SneakaFreaka83
    348
    now that is a beast indeed haha... yeh I know the bay is tight like a tiger but wanted to know if it was worth doing as not very costly and if it is a improvement then may be up for it mate,....
  8. S3RYE
    3,448
    70
    yeh and it only weighed about 5KG.. if they were a good fit i think there would be a lot more for sale from manufacturers.. i.e forge etc...
  9. SneakaFreaka83
    348
    yeh I guess your right... May spend the 70 quid and have a tinker to see how it goes... if its poop then no massive loss i guess but think I may give it ago and take pics and let ya all know... that is incase someone else has tried it and went pete tong....
  10. S3RYE
    3,448
    70
    the last line of that link!!! :sadlike:
  11. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Also in some cases you will need to drill the bodywork.
    Chicken
  12. Broken Byzan
    13,237
    465
    An ARB and a strut brace are two different things.
    The strut brace, does as it says, braces the struts to prevent the chassis flex from pushing the struts together under cornering. Don't get me wrong it's not a lot of flex, but it can be detected. Usually you will induce some understeer when adding a front strut brace
    An ARB uses the downward motion of the inside wheel of a corner to help to push the outside one back down to level the car out a bit and prevent body roll.
    Obviously these are simplified terms and my own opinions, but close enough for practical purposes.
  13. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    Strut brace stops the strut tops from flexing in & out.
    ARB/sway-bar adds resistance to INDEPENDANT vertical wheel-movement.
    COMPLETELY different. NO connection whatsoever.
    My Porsche has uprated sway bars (anti-roll bars) front and back, AND racing Dynamics strut brace in the front, and a bar-brace in the back. The Roll-cage also helps stiffen the rear in particular. They do ENTIRELY different jobs.
    Keith
  14. VWAddict
    656
    9
    I don't think that will fit an 8P.
    It depends on what...
    ...means.
    If it means "Up to 03" then it's not for the 8P A3, it's for the 8L.
    If it means "greater than 03" (as in the proper mathematical notation) then it would fit...
    But I honestly doubt he's using correct mathematical notation.
  15. micasb
    micasb Member
    327
    I think there aren't Strut braces compatible with the 8P... yet...
    I've seen some people applying homemade ones....
    Regards.
  16. Broken Byzan
    13,237
    465
    Doesnt the S3 have one? Can't this be adapted to the normal models?
  17. micasb
    micasb Member
    327
    I don't think so...
  18. SneakaFreaka83
    348
    Thanks all... this is what I actually first thought as I did searching and couldnt find anyone with a strut brace... think I will hold off for the moment to see what exactly may come out.. if any.. cheers again...
  19. micasb
    micasb Member
    327
    I realy think that it won't come anything for the 8P. There's almost no room for a Strut brace...
  20. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Without cutting metal body panel joins around the strut tower or removing the wiper mechanism there is no way of fitting a strut brace to an A3 8P.
  21. micasb
    micasb Member
    327
    You said everything... That's why there isn't any brand producing for the 8P...
  22. LWNY
    LWNY Member
    161
    There is likely less need for a strut brace on the A3 due to the extreme FWD layout of the engine, forcing the wheel/strut location to be right in front of the firewall. The close proximity to that solid sheet of iron causes that sheet to act as a large vertical strut bar, making it structurally much stiffer than the mid-front engine designs where the strut tower are sitting in the middle of the engine bay, flapping back and forth to the wind and direction of travel.
  23. durtytdi140
    durtytdi140 Member
    66
    s3rye please pm me as i am a new member with your number i want to buy your brake kit if its still for sale buddy ?
    so has anyone actually got a strut brace for there a3 8P model im after one as well car doesnt go round corners as well as my bimma use to,
  24. S3Alex
    10,803
    4,805
    It won't turn in as well as the previous car,as from your signature,I'm guessing you have a FWD TDi,and that does understeer pretty heavily.
    Changing the suspension,and uprating the roll bars will make some difference,and certainly with a 4WD(Quattro) you can largely eliminate this tendency,but it's less easy to dial it out on a nose heavy FWD diesel.
  25. brough74
    brough74 Member
    423
    22
    As mention strut braces keep the wheels more upright during cornering thus giving more grip etc.
    Ive used them in all sorts of cars nissans, vw, subarus etc and most of the time they are are good investment and work well but to my knowledge there are none on the market for the 8p.
  26. S3RYE
    3,448
    70
    PM'd my number
  27. S3Alex
    10,803
    4,805
    Perhaps also worth mentioning that whilst I am sure a strut brace would be the icing on the cake so to speak,the 8P chassis is a lot more rigid than an equivalent car even 5 or 10 years ago,and with the sort of power that some of us have been putting through it,chassis rigidity or lack of,doesn't seem to have been a problem.
  28. S3RYE
    3,448
    70
    i agree.. The 8p is a very solid chassis.
  29. S3Alex
    10,803
    4,805
    Mind you,at 1500kgs,it should be!
  30. S3RYE
    3,448
    70
    this is true, is that the next route of attack for you Al!? weight saving :anbet:
  31. S3Alex
    10,803
    4,805
    If I lost some myself maybe....!
    If I put the car on a diet and removed the back seats,there'd be trouble,as I've had one previous car with a full cage and no back seats,and the ball and chain loathed it with a vengeance.....I'll not repeat that experience,so just keep adding a few more bhp instead.
  32. ryanstewart9
    ryanstewart9 Member
    494
    I've heard the Whiteline Anti-Lift Kit works well with FWD cars.
  33. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'd wondered about it but couldn't find any reviews that seemed unbiased.
  34. S3Alex
    10,803
    4,805
    You'll find a few people have used this over at VAGOC with good results.
