max power on stock AAN motor
jevrem May 26, 2008
  1. jevrem
    jevrem Max speed
    Does anyone know how much power up can a stock AAN motor from URS4 take. I know that, with chip and some small changing can power up at 310PS. Is it safe to power up at 350PS?
  2. scotty33
    scotty33 Member
    155
    Hi
    Safe is a relative term, but generally speaking, the engine internals are good for 450 hp with good tuning, if there is a problem and detonation occurs, it can all go pear shaped at less hp
    You would need a bigger turbo and probably higher flowrate injectors to get to 350 hp as well as a chip/remap or standalone ecu?
    Have a look around 034 motorsport for ideas? (hp numbers will be taken at the wheels)
    http://www.motorgeek.com/phpBB2/viewtopic.php?t=21500
    motorgeek.com :: View topic - AAN chipset comparo extravaganza!!
  3. jevrem
    jevrem Max speed
    Thank you for you reply!
    I have already buy a FMIC, Sport exhaust manifold, downpipe 3", Bosch injectors 440cc, wastegate from rs2 with regulator. Next i plan to buy a fuel presure regulator, bigger turbo, chip/remap, new clutch, ...
  4. audi5e
    audi5e Member
    809
    I would do the brakes first... :)
  5. jevrem
    jevrem Max speed
    :yes: I will upgrade the brakes at front, to 330mm
  6. K7ERG
    K7ERG Member
    372
    Have a look on www.s2forum.com plenty of info on the AAN etc.
    I am building one at the moment to 450 to 500bhp. Give me a shout if you have any other questions.
    Craig
