Max Boost Safe Boost Pressure Rating?????
R31LLY Oct 29, 2009
  1. R31LLY
    R31LLY New Member
    hello every1 im new, i hope your all well!!
    i have bought a boost controler for my audi a4 1.9 tdi 130bhp 6 speed avant and im needing to know my Max Safe Boost Pressure Rating
    can any body answer this or let me know how or where id find my answer
    many thanks in advance Reillly
    ill look forward to talkin to you all :detective2:
  2. Marc1
    Marc1 Member
    728
    Be careful with that, you need to alter the fueling as well as the boost. You don't want to go over 1.4bar, but bear in mind that the higher the boost the faster the thrust bearing will wear. Just get a remap to alter the boost and fueling more safely and have better results, there's a lot of forum deals around.
  3. BILKO1
    BILKO1 Member
    301
    I don't think it will work mate, as soon as the ecu sees to much boost it will go into limp mode (shut turbo down). On old skool turbo charged engines which used a map sensor connected via a rubber pipe you could use a bleed off valve but risky if not setup 100%.
  4. Marc1
    Marc1 Member
    728
    Good point there, I forgot to mention the limit would also need raising, doh!
    Don't do it, get a remap!
  5. quattrojames
    14,050
    578
    Oooh scary! Rather you than me! :ermm:
