max %age tyre difference run on a quattro
jcb Oct 27, 2009
  1. jcb
    jcb Active Member
    4,132
    13
    just found a screw 1 inch from the side wall in my almost new F1's!!
    pain in the ass as they cost me £100 each and the tyre monkey says he can't plu it to repair them.
    £25 and a 10 day turn around to get them done by a vulcaniser repair guy (no not star trek!!)
    still doesn't help me ....
    I have 245/40/18's all round
    I also have two spare 235/40/18 (total diameter is 1.23% out).
    am I asking for trouble running them temporarily whilst my tyre is being fixed?
    anyone run similar differences?
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    if you werent doing loads of miles i would think it would be ok. no lsd anyway.
  3. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Give me your brakes and you can use my spare 17s?
    Sounds like a plan to me!
    I would just run the 1% difference you have. If it only a couple of weeks I am sure it will be fine.
  4. jcb
    jcb Active Member
    4,132
    13
    that is what I was thinking...
  5. aragorn
    18,606
    871
    If you calculate the diameter of both, you'll probably find the difference is similar to the difference between a new 235/40 and a nearly bald 235/40.
  6. jcb
    jcb Active Member
    4,132
    13
    probably.
    my worry is I will be nearly new 245 on the rear and part worn 235 on the front.
    likely to be closer to 2+% difference if I really think about it
  7. ian52
    1,199
    just pump the 235's up to 80psi and put the 245 to 25psi. that should even it out.
