MASSIVE problems with my Sport
CarbonBlack Jan 20, 2014
  1. CarbonBlack
    CarbonBlack Member
    Well I think my time with a A3 might be short lived! Iv'e had a little bit of a bad Idle problem for a few weeks but put it down to a torn PCV System, old Plug's etc. I've been building a pile of part's to put on but hadn't got around to changing anything over yet but now they might not even get a chance of going on lol!
    So, the Car was working fine apart from the rough Idle with rev's bouncing. Just lately it had got abit worse with the Car sometimes cutting out when coming to a hardish stop or going into reverse. Then all of a sudden the Car has now died. I nipped out the other day & parked up as normal when I got home. A few hours later when I went to start the Car it fired up straight away, I let it sit & Idle for a minute as usual & noticed that the bouncing seemed quite bad. I went to drive the Car &....... nothing!! Foot to the Floor with no Rev's/ acceleration! After various starts all I've found out is that the Car has a life of it's own! It will always start but sometimes will run really bad, sometimes not 'too' bad, will let me rev now & again but mostly now there is no accelaration at all.
    I've pulled codes again & again but they will randomly change!?! I will mostly get:
    PO012
    PO223
    PO638
    Also I get the EPC & Engine Management light on, I clear them but they soon come back!
    From hours of reading I've found out it could maybe be the Throttle Pedal, Throttle Body, Coil Pack's, Crank Sensor, Cam Sensor or a dreaded short in a O2 Sensor causing the ECU to blow something!!!
    Can anyone who knows these Engines in detail advise where to start as I haven't really got money to do the 'change each part for new until it's fixed' option & then end up having to buy another ECU!!!!!!
  2. <tuffty/>
    20,829
    3,670
    P0012 is
    16396/P0012/000018 - Ross-Tech Wiki
    16396/P0012/000018 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    Possible Symptoms
    Erratic Idle
    Possible Causes
    Intake Camshaft Adjuster tight/stuck
    Intake Camshaft Adjuster faulty
    Possible Solutions
    Check Intake Camshaft Adjuster
    When the Intake Camshaft Adjuster uses oil pressure to control the adjuster, check the oil pressure. The 1.8T is notorious for issues but any engine with low oil pressure or restrictions in the system could result in various timing DTC's such as 17748/P1340/004928.
    Use Output Test, Meas. Value Blocks (MVB) & Basic Setting
    Do you get a rattle on start up at all? this is related to the cam chain tensioner typically
    Not sure on the others... can you scan with VCDS?
    EDIT: the other two appear related to the throttle pedal... a scan with VCDS would be helpful I think as it will provide more detail...
  3. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    What he said ^^^
    A VCDS scan would be useful, it offers far more detail than P(ants) codes; and you can log stuff too.
    (I was just writing to suggest that some more specificity might not go amiss (details of engine/year etc.) - and a location configured in your profile might increase the likelihood of someone offering you a proper scan...)
    R
  4. CarbonBlack
    CarbonBlack Member
    Cheers mate, yeah I've looked up the codes & possible fixes etc. I'm quite handy with Car's etc but I think this Cam stuff will be above me if it is down to that! I was thinking that the Cam bit's might be to do with the Engine being all over the place due to either the Pedal/ TB not sending the right signal or at worst, the ECU being f**ked & sending/ receiving signals to various things at the wrong times etc! On my Torque App it's showing that I have -4s etc on my Timing! I've just bought S3 Bumper's, Wheel's, Hose's & all sorts of bit's as well :(
    Did you see my last Post to you in my other Thread Tuffty? (Incase it does ever work again!!)
  5. CarbonBlack
    CarbonBlack Member
    Nice one FactionOne :) I'll go update my Profile. I'm in Nottingham/ Derby if anyone reading this is near by!! Car is a 2001 AUM
  6. <tuffty/>
    20,829
    3,670
    Just replied to your other thread (assuming its the injector seals one)...
    Do a proper scan so we can see what VAG definitions come through... VAG have extended the fault codes from the base OBDII standard to allow for more flexible/precise fault diagnosis which is why you will hear everyone bang on about a VCDS scan rather than P codes from a generic device.. I have torque app too btw... very useful and love the dials but something like this needs VCDS really..
    VVT tensioner swap if this is the issue is a piece of cake mate... I posted on a thread this morning with links (http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/207807-aum-apy-heads-mix-match.html) and also have loads of pics in my build thread on doing this too
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Check all your earths too if the fault codes are erratic..
  8. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,794
    190
    As per pm, I could pop over tomorrow afternoon if you find nobody closer.
    VCDS will let me check the function and measured values of the sensors playing up. Should be able to get something conclusive from it.
    ECU's are easy to change if the worst happens, but being erratic id suspect a dodgy sender or wire.
  9. future
    future Scuderia Vittoria Edition 001
    371
    33
    As said before a vcds scan would be very helpful, but this sounds a lot like when josh had a short in his throttle body wiring, so may be worth your while checking and/or doing a throttle reset with vcds
    Hope you get it fixed fella!
  10. CarbonBlack
    CarbonBlack Member
    Nice one for all your input guy's! @udi A3 is going to come over shortly & see what we can figure out :) I have new Plug's going in, just bought TFSI Coilpacks & Adaptors (the OE 1s like yours Tuffty) I've also ripped out the SAI, N249 etc & all the **** that goes with it. I know it could of been left until after but the Cars just sat on the drive, I already had the bit's needed ready, it eliminates some things out of the equation & I've replaced some Vac Hoses with Silicone in the process so that's obs a good thing!
  11. CarbonBlack
    CarbonBlack Member
    Anyone know where to get a Coilpack Harness from? I asked Audi Main Dealer & although they have it listed he couldn't order it!?!
  12. s3dave
    10,110
    736
  13. CarbonBlack
    CarbonBlack Member
    Nice1 S3 Dave , cheers mate :)
    Now this might sound a little stupid but will I need the 1 with or without the Oil Level Sensor? Also it states "Unfortunately this loom is not suitable for the 210bhp / 225bhp / 240bhp 1.8 20v Turbo engines", is this because they do have a Oil Level Sensor or is their another reason these don't fit those engine's?
  14. s3dave
    10,110
    736
    You only need the coil pack loom bit, the rest is junk.. it fits fine ive done mine with it..
  15. CarbonBlack
    CarbonBlack Member
    Ignore this Post
  16. @udi A3
    1,794
    190
    Who scanned it? any logs of the measuring values? any attempt at TB adaption?
  17. CarbonBlack
    CarbonBlack Member
    I'm just having a little problem getting the Log's up mate, 1 min
  18. @udi A3
    1,794
    190
    Its ok i gotta go out now, was waiting for your call. now have another car to attend to :D
  19. CarbonBlack
    CarbonBlack Member
    O don't worry mate, you might still be getting THE call lololol. There's a guy on here called Dave who lives about 10 min away from me. I'd messaged him just before you just for the chance as he hadn't been on in over a year (which is why I then messaged you). He got in touch the day after you & said although he's not fully a 'Car tech' guy as he mainly does IT, he does have the Software etc, has done bit's on his Car with it & also helped members from here before & could nip round if needed to do a quick Scan. So he popped around today & even though the Car is not running at the min as I have some bit's off, he did a Scan, cleared thing's, scanned again, made some Log's etc.
    I'm hoping it is just my Throttle Body as it wouldn't even do the adaption!! He said he wouldn't know too much from the Log's as he's not a Vag/ Car guy, which is why I'm trying to get them up here lol. It seems that I have some kind of problem with my Alarm as well as it kept throwing up all sorts to do with it......... now I know why I've gone out in the morning to find my Windows down, hazard Lights flashing etc but no damage to the Car & no Alarm sound lolololololol
  20. @udi A3
    1,794
    190
    Stab in the dark. Try a new battery
  21. CarbonBlack
    CarbonBlack Member
    I did have the Battery properly tested with a machine that gives you a Print Out Receipt & it did come up as a little low on Volt's. I think it came out at around 12.5/ 13 instead of the 14.5ish but do you think that would be low enough to cause anything!?!
  22. CarbonBlack
    CarbonBlack Member
    VIN: WAUZZZ8LZ1A079522 License Plate: Y353OAJ
    Mileage: 14599 Repair Order:
    Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2003))
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 01: Engine Labels: 06A-906-032-AUM.lbl
    Part No: 06A 906 032 FC
    Component: 1.8L R4/5VT 0002
    Coding: 11500
    Shop #: WSC 12339
    VCID: 64CDA5D6F4C6D13E10B-5102
    WAUZZZ8LZ1A079522 AUZ7Z0Y1758290
    6 Faults Found:
    17967 - Throttle Body (J338)
    P1559 - 35-10 - Fault in basic settings - Intermittent
    17581 - Angle Sensor 2 for Throttle Actuator (G188) Signal too High
    P1173 - 35-10 - - Intermittent
    17950 - Angle Sensor 1 for Throttle Actuator (G187)
    P1542 - 35-10 - Implausible Signal - Intermittent
    17972 - Throttle Actuator (J338)
    P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
    16955 - Brake Switch (F)
    P0571 - 35-00 - Implausible Signal
    16725 - Camshaft Position Sensor (G40)
    P0341 - 35-10 - Implausible Signal - Intermittent
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 E
    Component: ESP FRONT MK60 0104
    Coding: 0019970
    Shop #: WSC 06435 000 00000
    VCID: 2C5D0DF68C96597E18B-5102
    2 Faults Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    01423 - Lateral Acceleration Sensor (G200)
    012 - Electrical Fault in Circuit
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 H
    Component: A3 KLIMAAUTOMAT 0101
    Coding: 00041
    Shop #: WSC 06435
    VCID: 2D5B00F2E78C50760F5-2592
    No fault code found.
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 4008
    Coding: 01104
    Shop #: WSC 06435
    VCID: 458B58525F3C8836E75-5102
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 E
    Component: AB-KOMBIINSTR. VDO D12
    Coding: 00444
    Shop #: WSC 00001
    VCID: 356B28920FDC18B6775-5102
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15178
    Shop #: WSC 06435
    VCID: 2F671AFAED8022663D9-4EB0
    11 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    49-00 - No Communications
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0C529C660DE4D1E743-4B18
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 8L0 035 186 A
    Component: Radio D05
    Coding: 00201
    Shop #: WSC 06435
    VCID: 2C5D0DF6DC96597E18B-4ACE
    1 Fault Found:
    00856 - Radio Antenna
    36-00 - Open Circuit
    End ---------------------------------------------------------------------
  23. CarbonBlack
    CarbonBlack Member
    That was the Scan before Codes were cleared.
    The next is after being cleared, remember though, the Car has still not been ran:
  24. CarbonBlack
    CarbonBlack Member
    Saturday,25,January,2014,12:31:09:40302
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: WAUZZZ8LZ1A079522 License Plate: 2
    Coding: 11500
    Shop #: WSC 12339
    VCID: 64CDA5D6F4C6D13E10B-5120
    Coding: 0019970
    1 Fault Found:
    Coding: 00041
    Shop #: WSC 06435
    Coding: 01104
    Shop #: WSC 06435
    Coding: 00444
    Shop #: WSC 00001
    Coding: 15178
    Shop #: WSC 06435
    Coding: 00001
    Shop #: WSC 00000
    Coding: 00201
    Shop #: WSC 06435
  25. CarbonBlack
    CarbonBlack Member
    cleared & scanned again gives:
  26. CarbonBlack
    CarbonBlack Member
    Saturday,25,January,2014,12:37:14:40302
    VIN: WAUZZZ8LZ1A079522 License Plate: 3
    Coding: 11500
    Shop #: WSC 12339
    Coding: 0019970
    1 Fault Found:
    Coding: 00041
    Shop #: WSC 06435
    Coding: 01104
    Shop #: WSC 06435
    Coding: 00444
    Shop #: WSC 00001
    Coding: 15178
    Shop #: WSC 06435
    1 Fault Found:
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0C529C660DE4D1E743-4B32
    Coding: 00201
    Shop #: WSC 06435
    VCID: 2C5D0DF6DC96597E18B-4AE6
  27. CarbonBlack
    CarbonBlack Member
    It seems that most of the Codes have gone but there's now a different 1 to do with the Alarm!?!
    If anyone can help with the Codes that did come up it would be a help but I suppose I need to run the Car again & get another Scan/ Log after that to see if anything returns!
    Underneath is a Log of when he tried to do a Throttle Adaption. The Laptop said go, the Throttle Body made some right weird sounds but didn't sound like it was actually moving anything inside & then the Laptop reports a 'Fail'
  28. CarbonBlack
    CarbonBlack Member
    Saturday,25,January,2014,12:44:17:40302,VCDS Version: Release 12.12.0 (x64),Data version: 20130910
    06A 906 032 FC,,1.8L R4/5VT 0002,
    ,Group A:,'060,,,,Group B:, Not Running,,,,Group C:, Not Running
    ,,Throttle Valve,Throttle Valve,Throttle Adaptation,Result,,,,,,,,,,
    ,TIME,Sensor 1 (G187),Sensor 2 (G188),Steps Counter,Throttle Valve Adp.,TIME,,,,,TIME,,,,
    Marker,STAMP, %, %,,,STAMP,,,,,STAMP,,,,
    ,0.01,13.7,78.1,6,ERROR,,,,,,,,,,
    ,0.30,13.7,77.7,6,ERROR,,,,,,,,,,
    ,0.60,13.7,78.1,6,ERROR,,,,,,,,,,
    ,0.90,13.7,77.7,6,ERROR,,,,,,,,,,
    ,1.21,13.7,77.7,6,ERROR,,,,,,,,,,
    ,1.51,13.7,78.1,6,ERROR,,,,,,,,,,
    ,1.81,13.7,77.7,6,ERROR,,,,,,,,,,
    ,2.11,13.7,78.1,6,ERROR,,,,,,,,,,
    ,2.41,13.7,77.7,6,ERROR,,,,,,,,,,
    ,2.71,13.7,78.1,6,ERROR,,,,,,,,,,
    ,3.02,13.7,77.7,6,ERROR,,,,,,,,,,
    ,3.32,13.7,77.7,6,ERROR,,,,,,,,,,
    ,3.62,13.7,78.1,6,ERROR,,,,,,,,,,
    ,3.92,13.7,77.7,6,ERROR,,,,,,,,,,
    ,4.22,13.7,78.1,6,ERROR,,,,,,,,,,
    ,4.52,13.7,78.1,6,ERROR,,,,,,,,,,
    ,4.83,13.7,78.1,6,ERROR,,,,,,,,,,
    ,5.13,13.7,78.1,6,ERROR,,,,,,,,,,
    ,5.43,13.7,77.7,6,ERROR,,,,,,,,,,
    ,5.73,13.7,78.1,6,ERROR,,,,,,,,,,
    ,6.03,13.7,77.7,6,ERROR,,,,,,,,,,
    ,6.33,13.7,77.7,6,ERROR,,,,,,,,,,
    ,6.64,13.7,77.7,6,ERROR,,,,,,,,,,
    ,6.94,13.7,78.1,6,ERROR,,,,,,,,,,
    ,7.24,13.7,77.7,6,ERROR,,,,,,,,,,
    ,7.54,13.7,77.7,6,ERROR,,,,,,,,,,
    ,7.84,13.7,78.1,6,ERROR,,,,,,,,,,
    ,8.14,13.7,77.7,6,ERROR,,,,,,,,,,
    ,8.45,13.7,77.7,6,ERROR,,,,,,,,,,
    ,8.75,13.7,77.7,6,ERROR,,,,,,,,,,
    ,9.05,13.7,78.1,6,ERROR,,,,,,,,,,
    ,9.35,13.7,77.7,6,ERROR,,,,,,,,,,
    ,9.65,13.7,77.7,6,ERROR,,,,,,,,,,
    ,9.95,13.7,77.7,6,ERROR,,,,,,,,,,
    ,10.26,13.7,77.7,6,ERROR,,,,,,,,,,
    ,10.56,13.7,77.7,6,ERROR,,,,,,,,,,
    ,10.86,13.7,77.7,6,ERROR,,,,,,,,,,
    ,11.16,13.7,77.7,6,ERROR,,,,,,,,,,
    ,11.46,13.7,77.7,6,ERROR,,,,,,,,,,
    ,11.76,13.7,77.7,6,ERROR,,,,,,,,,,
    ,12.07,13.7,78.1,6,ERROR,,,,,,,,,,
    ,12.37,13.7,78.1,6,ERROR,,,,,,,,,,
    ,12.67,13.7,77.7,6,ERROR,,,,,,,,,,
    ,12.97,13.7,77.7,6,ERROR,,,,,,,,,,
    ,13.27,13.7,77.7,6,ERROR,,,,,,,,,,
    ,13.57,13.7,77.7,6,ERROR,,,,,,,,,,
    ,13.88,13.7,77.7,6,ERROR,,,,,,,,,,
    ,14.18,13.7,77.7,6,ERROR,,,,,,,,,,
    ,14.48,13.7,77.7,6,ERROR,,,,,,,,,,
    ,14.78,13.7,77.7,6,ERROR,,,,,,,,,,
    ,15.08,13.7,77.7,6,ERROR,,,,,,,,,,
    ,15.39,13.7,77.7,6,ERROR,,,,,,,,,,
    ,15.69,13.7,77.7,6,ERROR,,,,,,,,,,
    ,15.99,13.7,77.7,6,ERROR,,,,,,,,,,
    ,16.29,13.7,77.7,6,ERROR,,,,,,,,,,
    ,16.59,13.7,78.1,6,ERROR,,,,,,,,,,
    ,16.89,13.7,78.1,6,ERROR,,,,,,,,,,
    ,17.20,13.7,78.1,6,ERROR,,,,,,,,,,
    ,17.50,13.7,77.7,6,ERROR,,,,,,,,,,
    ,17.80,13.7,77.7,6,ERROR,,,,,,,,,,
    ,18.10,13.7,77.7,6,ERROR,,,,,,,,,,
    ,18.40,13.7,77.7,6,ERROR,,,,,,,,,,
    ,18.70,13.7,78.1,6,ERROR,,,,,,,,,,
    ,19.01,13.7,77.7,6,ERROR,,,,,,,,,,
    ,19.31,13.7,77.7,6,ERROR,,,,,,,,,,
    ,19.61,13.7,77.7,6,ERROR,,,,,,,,,,
    ,19.91,13.7,77.7,6,ERROR,,,,,,,,,,
    ,20.21,13.7,77.7,6,ERROR,,,,,,,,,,
    ,20.51,13.7,77.7,6,ERROR,,,,,,,,,,
    ,20.82,13.7,77.7,6,ERROR,,,,,,,,,,
    ,21.12,13.7,77.7,6,ERROR,,,,,,,,,,
    ,21.42,13.7,77.7,6,ERROR,,,,,,,,,,
    ,21.72,13.7,77.7,6,ERROR,,,,,,,,,,
    ,22.02,13.7,77.7,6,ERROR,,,,,,,,,,
    ,22.32,13.7,77.7,6,ERROR,,,,,,,,,,
    ,22.63,13.7,77.7,6,ERROR,,,,,,,,,,
    ,22.93,13.7,77.7,6,ERROR,,,,,,,,,,
    ,23.23,13.7,77.7,6,ERROR,,,,,,,,,,
    ,23.53,13.7,77.7,6,ERROR,,,,,,,,,,
    ,23.83,13.7,77.7,6,ERROR,,,,,,,,,,
    ,24.14,13.7,77.7,6,ERROR,,,,,,,,,,
    ,24.44,13.7,77.7,6,ERROR,,,,,,,,,,
    ,24.74,13.7,77.7,6,ERROR,,,,,,,,,,
    ,25.04,13.7,77.7,6,ERROR,,,,,,,,,,
    ,25.34,13.7,77.7,6,ERROR,,,,,,,,,,
    ,25.64,13.7,77.7,6,ERROR,,,,,,,,,,
    ,25.95,13.7,77.7,6,ERROR,,,,,,,,,,
    ,26.25,13.7,77.7,6,ERROR,,,,,,,,,,
    ,26.55,13.7,77.7,6,ERROR,,,,,,,,,,
    ,26.85,13.7,77.7,6,ERROR,,,,,,,,,,
    ,27.15,13.7,77.7,6,ERROR,,,,,,,,,,
    ,27.45,13.7,77.7,6,ERROR,,,,,,,,,,
    ,27.76,13.7,77.7,6,ERROR,,,,,,,,,,
    ,28.06,13.7,77.7,6,ERROR,,,,,,,,,,
    ,28.36,13.7,77.7,6,ERROR,,,,,,,,,,
    ,28.66,13.7,77.7,6,ERROR,,,,,,,,,,
    ,28.96,13.7,77.7,6,ERROR,,,,,,,,,,
    ,29.26,13.7,77.7,6,ERROR,,,,,,,,,,
    ,29.57,13.7,77.7,6,ERROR,,,,,,,,,,
    ,29.87,13.7,77.7,6,ERROR,,,,,,,,,,
    ,30.17,13.7,77.7,6,ERROR,,,,,,,,,,
    ,30.47,13.7,77.7,6,ERROR,,,,,,,,,,
    ,30.77,13.7,77.7,6,ERROR,,,,,,,,,,
    ,31.07,13.7,77.7,6,ERROR,,,,,,,,,,
    ,31.38,13.7,77.7,6,ERROR,,,,,,,,,,
    ,31.68,13.7,77.7,6,ERROR,,,,,,,,,,
    ,31.98,13.7,77.7,6,ERROR,,,,,,,,,,
    ,32.28,13.7,77.7,6,ERROR,,,,,,,,,,
    ,32.58,13.7,77.7,6,ERROR,,,,,,,,,,
    ,32.89,13.7,77.7,6,ERROR,,,,,,,,,,
    ,33.19,13.7,77.7,6,ERROR,,,,,,,,,,
    ,33.49,13.7,77.7,6,ERROR,,,,,,,,,,
    ,33.79,13.7,77.7,6,ERROR,,,,,,,,,,
    ,34.09,13.7,77.7,6,ERROR,,,,,,,,,,
    ,34.40,13.7,77.7,6,ERROR,,,,,,,,,,
    ,34.70,13.7,78.1,6,ERROR,,,,,,,,,,
    ,35.00,13.7,77.7,6,ERROR,,,,,,,,,,
    ,35.30,13.7,77.7,6,ERROR,,,,,,,,,,
    ,35.60,13.7,77.7,6,ERROR,,,,,,,,,,
    ,35.90,13.7,77.7,6,ERROR,,,,,,,,,,
    ,36.21,13.7,77.7,6,ERROR,,,,,,,,,,
    ,36.51,13.7,77.7,6,ERROR,,,,,,,,,,
    ,36.81,13.7,78.1,6,ERROR,,,,,,,,,,
    ,37.11,13.7,77.7,6,ERROR,,,,,,,,,,
    ,37.41,13.7,78.1,6,ERROR,,,,,,,,,,
    ,37.71,13.7,77.7,6,ERROR,,,,,,,,,,
    ,38.01,13.7,78.1,6,ERROR,,,,,,,,,,
    ,38.32,13.7,78.1,6,ERROR,,,,,,,,,,
    ,38.62,13.7,78.1,6,ERROR,,,,,,,,,,
    ,38.92,13.7,78.1,6,ERROR,,,,,,,,,,
    ,39.22,13.7,78.1,6,ERROR,,,,,,,,,,
    ,39.52,13.7,78.1,6,ERROR,,,,,,,,,,
    ,39.82,13.7,78.1,6,ERROR,,,,,,,,,,
    ,40.13,13.7,77.7,6,ERROR,,,,,,,,,,
    ,40.43,13.7,78.1,6,ERROR,,,,,,,,,,
    ,40.73,13.7,78.1,6,ERROR,,,,,,,,,,
    ,41.03,13.7,78.1,6,ERROR,,,,,,,,,,
    ,41.33,13.7,77.7,6,ERROR,,,,,,,,,,
    ,41.63,13.7,78.1,6,ERROR,,,,,,,,,,
    ,41.94,13.7,78.1,6,ERROR,,,,,,,,,,
    ,42.24,13.7,78.1,6,ERROR,,,,,,,,,,
    ,42.54,13.7,77.7,6,ERROR,,,,,,,,,,
    ,42.84,13.7,78.1,6,ERROR,,,,,,,,,,
    ,43.14,13.7,77.7,6,ERROR,,,,,,,,,,
    ,43.49,13.7,78.1,6,ERROR,,,,,,,,,,
    ,43.75,13.7,77.7,6,ERROR,,,,,,,,,,
    ,44.06,13.7,77.7,6,ERROR,,,,,,,,,,
    ,44.35,13.7,77.7,6,ERROR,,,,,,,,,,
    ,44.65,13.7,77.7,6,ERROR,,,,,,,,,,
    ,44.95,13.7,77.7,6,ERROR,,,,,,,,,,
    ,45.26,13.7,77.7,6,ERROR,,,,,,,,,,
    ,45.66,13.7,77.7,6,ERROR,,,,,,,,,,
    ,45.96,13.7,77.7,6,ERROR,,,,,,,,,,
    ,46.26,13.7,77.7,6,ERROR,,,,,,,,,,
    ,46.56,13.7,77.7,6,ERROR,,,,,,,,,,
    ,46.86,13.7,77.7,6,ERROR,,,,,,,,,,
    ,47.17,13.7,77.7,6,ERROR,,,,,,,,,,
    ,47.47,13.7,77.7,6,ERROR,,,,,,,,,,
    ,47.77,13.7,77.7,6,ERROR,,,,,,,,,,
    ,48.07,13.7,77.7,6,ERROR,,,,,,,,,,
    ,48.37,13.7,77.7,6,ERROR,,,,,,,,,,
    ,48.72,13.7,77.7,6,ERROR,,,,,,,,,,
    ,49.08,13.7,77.7,6,ERROR,,,,,,,,,,
    ,49.38,13.7,77.7,6,ERROR,,,,,,,,,,
    ,49.68,13.7,77.7,6,ERROR,,,,,,,,,,
    ,49.98,13.7,77.7,6,ERROR,,,,,,,,,,
    ,50.30,13.7,77.7,6,ERROR,,,,,,,,,,
    ,50.59,13.7,77.7,6,ERROR,,,,,,,,,,
    ,50.89,13.7,77.7,6,ERROR,,,,,,,,,,
    ,51.19,13.7,77.7,6,ERROR,,,,,,,,,,
    ,51.49,13.7,77.7,6,ERROR,,,,,,,,,,
    ,51.81,13.7,77.7,6,ERROR,,,,,,,,,,
    ,52.10,13.7,77.7,6,ERROR,,,,,,,,,,
    ,52.45,13.7,77.7,6,ERROR,,,,,,,,,,
    ,52.80,13.7,77.3,6,ERROR,,,,,,,,,,
    ,53.10,13.7,77.3,6,ERROR,,,,,,,,,,
    ,53.42,13.7,77.7,6,ERROR,,,,,,,,,,
    ,53.78,13.7,77.3,6,ERROR,,,,,,,,,,
    ,54.11,13.7,77.3,6,ERROR,,,,,,,,,,
    ,54.41,13.7,77.3,6,ERROR,,,,,,,,,,
    ,54.71,13.7,77.3,6,ERROR,,,,,,,,,,
    ,55.01,13.7,77.3,6,ERROR,,,,,,,,,,
    ,55.31,13.7,77.3,6,ERROR,,,,,,,,,,
    ,55.61,13.7,77.3,6,ERROR,,,,,,,,,,
    ,55.92,13.7,77.3,6,ERROR,,,,,,,,,,
    ,56.22,13.7,77.3,6,ERROR,,,,,,,,,,
    ,56.52,13.7,77.3,6,ERROR,,,,,,,,,,
    ,56.82,13.7,77.3,6,ERROR,,,,,,,,,,
    ,57.12,13.7,77.3,6,ERROR,,,,,,,,,,
    ,57.42,13.7,77.3,6,ERROR,,,,,,,,,,
    ,57.73,13.7,77.3,6,ERROR,,,,,,,,,,
    ,58.03,13.7,77.3,6,ERROR,,,,,,,,,,
    ,58.33,13.7,77.3,6,ERROR,,,,,,,,,,
    ,58.63,13.7,77.3,6,ERROR,,,,,,,,,,
    ,58.93,13.7,77.3,6,ERROR,,,,,,,,,,
    ,59.23,13.7,74.6,6,ERROR,,,,,,,,,,
    ,59.54,13.7,74.6,6,ERROR,,,,,,,,,,
    ,59.84,13.7,74.6,6,ERROR,,,,,,,,,,
    ,60.14,13.7,74.6,6,ERROR,,,,,,,,,,
    ,60.44,13.7,74.6,6,ERROR,,,,,,,,,,
    ,60.74,13.7,74.6,6,ERROR,,,,,,,,,,
    ,61.05,13.7,74.6,6,ERROR,,,,,,,,,,
    ,61.35,13.7,74.6,6,ERROR,,,,,,,,,,
    ,61.65,13.7,74.6,6,ERROR,,,,,,,,,,
    ,61.95,13.7,74.6,6,ERROR,,,,,,,,,,
    ,62.25,13.7,74.2,6,ERROR,,,,,,,,,,
    ,62.55,13.7,74.6,6,ERROR,,,,,,,,,,
    ,62.86,13.7,74.6,6,ERROR,,,,,,,,,,
    ,63.16,13.7,74.2,6,ERROR,,,,,,,,,,
    ,63.46,13.7,74.2,6,ERROR,,,,,,,,,,
    ,63.76,13.7,74.6,6,ERROR,,,,,,,,,,
    ,64.06,13.7,74.6,6,ERROR,,,,,,,,,,
    ,64.36,13.7,74.6,6,ERROR,,,,,,,,,,
    ,64.67,13.7,74.6,6,ERROR,,,,,,,,,,
    ,64.97,13.7,74.6,6,ERROR,,,,,,,,,,
    ,65.27,13.7,74.6,6,ERROR,,,,,,,,,,
    ,65.57,13.7,74.2,6,ERROR,,,,,,,,,,
    ,65.87,13.7,74.6,6,ERROR,,,,,,,,,,
    ,66.17,13.7,74.2,6,ERROR,,,,,,,,,,
    ,66.48,13.7,74.6,6,ERROR,,,,,,,,,,
    ,66.78,13.7,74.6,6,ERROR,,,,,,,,,,
    ,67.08,13.7,74.6,6,ERROR,,,,,,,,,,
    ,67.38,13.7,74.6,6,ERROR,,,,,,,,,,
    ,67.68,13.7,74.6,6,ERROR,,,,,,,,,,
    ,67.98,13.7,74.6,6,ERROR,,,,,,,,,,
    ,68.29,13.7,74.2,6,ERROR,,,,,,,,,,
    ,68.59,13.7,74.6,6,ERROR,,,,,,,,,,
    ,68.89,13.7,74.6,6,ERROR,,,,,,,,,,
    ,69.19,13.7,74.6,6,ERROR,,,,,,,,,,
    ,69.49,13.7,74.2,6,ERROR,,,,,,,,,,
    ,69.80,13.7,74.2,6,ERROR,,,,,,,,,,
    ,70.10,13.7,74.6,6,ERROR,,,,,,,,,,
    ,70.40,13.7,74.6,6,ERROR,,,,,,,,,,
    ,70.70,13.7,74.2,6,ERROR,,,,,,,,,,
    ,71.00,13.7,74.2,6,ERROR,,,,,,,,,,
    ,71.30,13.7,74.6,6,ERROR,,,,,,,,,,
    ,71.61,13.7,74.6,6,ERROR,,,,,,,,,,
    ,71.91,13.7,74.2,6,ERROR,,,,,,,,,,
    ,72.21,13.7,74.2,6,ERROR,,,,,,,,,,
    ,72.51,13.7,74.6,6,ERROR,,,,,,,,,,
    ,72.81,13.7,74.6,6,ERROR,,,,,,,,,,
    ,73.11,13.7,74.6,6,ERROR,,,,,,,,,,
    ,73.42,13.7,74.6,6,ERROR,,,,,,,,,,
    ,73.72,13.7,74.6,6,ERROR,,,,,,,,,,
    ,74.02,13.7,74.6,6,ERROR,,,,,,,,,,
    ,74.32,13.7,74.6,6,ERROR,,,,,,,,,,
    ,74.62,13.7,74.6,6,ERROR,,,,,,,,,,
    ,74.92,13.7,74.6,6,ERROR,,,,,,,,,,
    ,75.23,13.7,74.6,6,ERROR,,,,,,,,,,
    ,75.53,13.7,74.6,6,ERROR,,,,,,,,,,
    ,75.83,13.7,74.6,6,ERROR,,,,,,,,,,
    ,76.14,13.7,74.6,6,ERROR,,,,,,,,,,
  29. <tuffty/>
    20,829
    3,670
    I think my eyes are bleeding after attempting to read that formatted the way it is... lol
  30. CarbonBlack
    CarbonBlack Member
    Sorry mate, I tried to do it on my phone but it wouldn't work right so I had to do it on the Laptop with 'copy' & 'paste' & that's how it came out lol
    can you not 'see' anything in there that stands out as f**ked?
  31. <tuffty/>
    20,829
    3,670
    Your computer skills!!.... :)
    I'll try and have a read through again when I have some eyesight back mate...
  32. CarbonBlack
    CarbonBlack Member
    Most of my 'skills' if that's what you could call them lol have gone right down hill!!!! I went to type on the Laptop & what with shorthand text messaging + having predictive text etc on the Phone it's messed me right up hahahahahaha
  33. CarbonBlack
    CarbonBlack Member
    The guy that came today only rolled up in a RS5!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  34. @udi A3
    1,794
    190
    Cant read that sorry
  35. CarbonBlack
    CarbonBlack Member
    How do you lot get it up here then lol?!
  36. CarbonBlack
    CarbonBlack Member
    I think I'm getting there lol. Are those Log's readable now ;) :)
  37. dartmin
    dartmin New Member VCDS Map User
    25
    Yea they are readable now - just popped on to see if you needed a hand getting them there :)
  38. CarbonBlack
    CarbonBlack Member
    Hahahahah cheers mate, just to sort the Adaption Log now lol
  39. dartmin
    25
    Try this
    it can then be renamed to .csv to be read easier
  40. CarbonBlack
    CarbonBlack Member
    Hahaha my phone downloaded & then said 'cannot open file' lol I didn't even understand the '.csv' bit anyway lol
    Think I'm going to attempt the Coil Pack Harness madness tomorrow, wish me luck :(
    <tuffty/> likes this.
