mass air flow issue
m19lte May 24, 2013
  1. m19lte
    m19lte Member
    123
    Hi folks, my esp light has come on and vagcom won't clear the fault !
    It's a 2002 s3 8l (recently put a 06 bam engine in on amk ecu) vagcom fault code is coming up with : 16486 - mass air flow sensor (G70) signal too low P0102 -35-00
    Any ideas ? As I've only 12 or so month ago replaced the maf for a new genuine unit, anybody know what configuration of the wires/plug ? To church the voltage so-on ? Cheers
  2. Gops
    3,198
    666
    Check your wiring, the plug might have broken plastics, it happened to mine!
  3. m19lte
    m19lte Member
    123
    Yea I have mate, as it happens the red sort of retaining clip inside the connector had broken up !?! But it doesn't foul the connector in any way !and it still plugs in fine, what did u do ? Did u just replace the sensor ?
  4. slowcoach3
    slowcoach3 Active Member
    862
    106
    43
    I'm having the exact same issue, can't for the life of me work out what the problem is, just gone through every bit of wiring i can find and every earth point. Doing my head in. If you find the answer tell me and i'll tell you if i get there first lol :)
  5. m19lte
    m19lte Member
    123
    No worries bud will do ;-)
  6. badger5
    9,577
    2,039
    and the maf is "ok"?
  7. slowcoach3
    862
    106
    43
    Yes for both. Although personally as soon as my maf is plugged in it cuts out, did the same with a brand new genuine bosch maf as well. Pretty stuck!
  8. darren t
    darren t Member
    568
    You erasing the maf fault before puting new maf on?do you get the fault code before you start car or after?
  9. slowcoach3
    862
    106
    43
    Fault code is cleared before sticking the new maf on,start the car code comes back, clear the code, try and drive and as soon as the revs drop car cuts out.
    Sorry to the op if this is a hijack but hopefully it'll all be relevant :)
  10. slowcoach3
    862
    106
    43
    Thats me sorted!! I got fecked off and dissasembled the 4 pin plug that connects to the maf, connected the spade end pins inside the plug directly to the relevant pins in the maf plug itself and bingo!! Off to tps to pick up a new plug :) Hope this helps and you get it sorted quickly mate
  11. m19lte
    m19lte Member
    123
    Sorry folks only just seen this, been really busy. What I ideally want to know is what voltage should the maf plug be kicking out ? As I want to check the voltage first-to see if there's a break in the wire soon.
    If the voltage is fine then I will replace the maf.
    Nice one slowcoach 3, pleased for you, do you have a part no or description for the plug ?
  12. m19lte
    m19lte Member
    123
    Oh n don't be sorry, it is all relevant ;-)
  13. slowcoach3
    862
    106
    43
    I have an etka print out but not to hand, i'll stick it up tomorrow, has all part numbers on it :) Sorry don't kbow voltages, electrics is not a strong point of mine!
  14. m19lte
    m19lte Member
    123
    Great stuff cheers pal
  15. badger5
    9,577
    2,039
  16. m19lte
    m19lte Member
    123
    Cheers Bill just what I needed, thanks
  17. calico101
    calico101 New Member
    17
    Any news on this M19lte
