MAP Sensor location??
Slinequattro Oct 11, 2011
  1. Slinequattro
    Slinequattro New Member
    13
    hi lads
    could anyone point me in the right direction to find the MAP sensor on a 05plate 2.0tdi quattro?
    regards
    Andrew
  2. cloughy
    cloughy Member
    515
  3. Slinequattro
    13
    mmm... I've been told to change the map sensor, I've got the part ready to change but not sure where to look...
  4. cloughy
    cloughy Member
    515
    what's the part number you've got?
  5. cooky19
    cooky19 Shiny S line Quattro
    31
    Hi Mate the Map sensor is located below the oil filter housing on the turbo pipe you will have to remove the air intake top cover situated at front of the air filter housing, then you need to remove the ducting which is U shaped once this is removed you will be able to see the MAP sensor which is secured by two screws be careful removing the screws so that you dont drop them as they tend to roll under the engine on the engine undertray and are very hard to retrieve without removing the undertray. Hope this helps Cheers
