Map lights and RNS-E aerial
1animal1 Feb 4, 2011
  1. 1animal1
    9,978
    Hiya matey...can you price me up the double aerial plug that plugs into the RNS-E sat navs - also after the map reading lights to fit a 2009 8P S3 (no sunroof) 3 door
    cheers
    Tim
  2. 1animal1
    9,978
    and these too please :)
    fan washer jets - 5M0 955 986 9B9
    Cup holder - 8P0 862 534C 5PR
    Diversity antenna - 000 098 652A fakra cable
    000 098 692 Male FAKRA adaptor
    8P4 035 225B Upper amp
    8P4 035 225 Lower amp
    1C0 973 119B three pin connector
    000 979 009 repair wires
    Tyre sensor switch (double DIN) - 8P0 927 121 A
    plug 4D0 971 636 A
    2x wires 000 979 009
    ABS wire 000 979 131
  3. stoke_audi
    stoke_audi Active Member
    2,243
    19
    is the sat nav connector a blue double one?
    Dave
  4. 1animal1
    9,978
  5. stoke_audi
    2,243
    19
    Prices as follows:
    double aerial plug £2.32
    map reading lights £77.96
    fan washer jets - 5M0 955 986 A 9B9 £14.76
    Cup holder - 8P0 862 534C 5PR £29.33
    Diversity antenna - 000 098 652A fakra cable £13.18
    000 098 692 Male FAKRA adaptor £15.24
    8P4 035 225B Upper amp £18.85
    8P4 035 225 Lower amp £107.42
    1C0 973 119B three pin connector £2.02
    000 979 009 E repair wires £2.04
    Tyre sensor switch (double DIN) - 8P0 927 121 A 5PR £11.86
    plug 4D0 971 636 A £3.04
    2x wires 000 979 009 E £2.04 each
    ABS wire 000 979 131 E £2.04
    All inc vat
    Dave
  6. 1animal1
    9,978
    Dave, can you prep an order for me please mate
    2x fan washer jets - 5M0 955 986 A 9B9 £14.76
    000 098 652 fakra cable 1metre cable (shorter than the above quoted item)
    2x 1C0 973 119B three pin connector £2.02
    3x 000 979 009 E repair wires £2.04
    I'll give you a call Thurs for payment
    cheers
    Tim
  7. stoke_audi
    2,243
    19
    ORDERED
    DAVE
  8. 1animal1
    9,978
    Cheers Dave, can you price up the multimedia 32 pin plug that goes into the RNS-E and also the ambient lighting module for the 8P S3...cheers
  9. 1animal1
    9,978
    oh and can you price this AMI interface along with any required cables for an ipod (if not included) 8P0 057 785
  10. 1animal1
    9,978
    Dave?
  11. stoke_audi
    2,243
    19
    here
    trying to catch up
    think your parts are here,
    what are the other 2 bits you are eqnuiring about
    Dave
  12. 1animal1
    9,978
    As above mate, the ambient light module which fits into the map light section, the multimedia 32 pin plug that fits into the RNS-E and the AMI system which i think is part number 8P0 057 785.....
    Will give you a ring tomorrow mate
  13. 1animal1
    9,978
    Dave!!! After the s3 decal for the engine cover if you can do separately :)
  14. 1animal1
    9,978
    Dave, can you price for the S3 decal on the exngine cover, and also thanks for the above parts - partly my fault though, the switch above is for the 2006-2008 cars and so is a different design...can i return the button i have for the correct tyre deflation switch for a 2009 car
  15. stoke_audi
    2,243
    19
    did Richard sort this for you.
    Dave
  16. 1animal1
    9,978
    yeah he ordered the new button and i posted out by recorded the sent part on Tuesday? can you confirm that you have it mate...i put a note in ref yourself and explaining the situation......
    ON another note, is it possible to give me the part numbers for the electric folding mirrors for an 8P3 S3.....folding and the folding and dimming mirrors and the door control switch, also the rear view dimming mirror and loom along with new auto light switch.....feel free to price too mate as im trying to get the expensive bits elsewhere, i will be getting the easier parts from you such as the controls....
    cheers
    Tim (feel free to say no mate as thats a little bit of a list i have there)
  17. 1animal1
    9,978
    Dave you are a legend...i had the switch this morning, one question though, it appears to be a new style switch which is good, but its one of the middle buttons so assume its for a MY10/11? mine only has one blanking plug and thats to the far right of the centre dash, and the switch is an end switch which is a different design....... can you check that there isnt an end version?
    if it is the right one then ill need the parts to remove the coin tray and replace with the buttons
  18. stoke_audi
    2,243
    19
    pm me your chassis number again
    will go through list of parts
    Dave
  19. stoke_audi
    2,243
    19
    Has Richard already sorted this out?
    Dave
  20. 1animal1
    9,978
    na nothing yet Dave.....
  21. 1animal1
    9,978
    he's sorted the new switch but not the price list im after
  22. stoke_audi
    2,243
    19
    so you need prices for the following
    correct?
    Dave
  23. 1animal1
    9,978
    yes please if thats ok fella, be very much appreciated :)
    I need the part numbers for the mirrors (both dimming and none) - I actually would ideally just like to convert mine to electric folding if poss but will be looking to source these cheaply.....can i reuse the mirror covers?
    the rest such as Dimming rear view mirror, light/wiper sensor and looms, folding mirror controls for door card, auto lights control with auto switch and any other bits you think id need for this installation (whats obvious on ETKA)
    cheers mate
  24. stoke_audi
    2,243
    19
    is it ok to try and look and this at the weeekend,
    when got more of a quite moment to have a good look at it?
    Dave
  25. 1animal1
    9,978
    course mate, no rush
  26. stoke_audi
    2,243
    19
    bump
    reminder for myself!
  27. stoke_audi
    2,243
    19
    dimming 4F0857535AH + 4F0857536AH
    none 4F0857535AE + 4F0857536AE
    I actually would ideally just like to convert mine to electric folding if poss but will be looking to source these cheaply.....can i reuse the mirror covers? Yes no difference
    the rest such as Dimming rear view mirror, light/wiper sensor 8K0955559A + 4F0907671A and loom (comes as part of full interior loom
    trim 8P3959558 B 7PE
    optic 8P0919173C
    Wiring and control unit should be same
    not to sure what you need for this
    Dave
  28. 1animal1
    9,978
    cheers Dave, very much appreciated.... can i have the prices please :)
    I have listed everything here, along with additional items required.....
    -Electric mirrors
    -folding mirror controls for door card,
    optic 8P0919173C - whats the optic?
    -Auto lights control with auto switch
    -Light and wiper sensor 8K0955559A + 4F0907671A
    -Auto dimming rear view mirror - black (along with wiring cover that leads to head lining)
    thanks as always
    Tim
