Map light units - B7 A4 and 8P2 the same?
JPK May 27, 2013
  1. JPK
    JPK Active Member
    303
    See title. They look the same..
  2. audicruiser
    audicruiser Audi Heaven
    1,865
    They aren't. The mounting screws are in a different place for the roof.
  3. JPK
    JPK Active Member
    303
    Thank you. As long as the faceplate is the same I should be able to make a hybrid with my existing unit to get map lights + ambient.
  4. Boon
    Boon Active Member
    441
    59
    The backs are different but the covers are almost/if not identical.
    I have replaced my cover and all internals (map and ambient lights) from an original A4 B7 light set. The colour is a tiny bit off but not that noticeable
    There isn't any holes for the interior ultrasonic sensor that faces towards the gearstick though, so I just drilled a hole for it...
    And I also had to enlarge the holes for the map light switches in a few places - literally half a millimetre or so as the switches where just catching and not turning off properly.
    All in all cost about £17 :)
    You'll need to dissemble both the A4 and A3 versions to swop the components over, but is simply plug and play - there is a thread on here somewhere...
