So I picked up my new 1.4COD s-tronic last Friday, after trading in my 1.4 122 manual.
Still getting to grips with some of the quirks of the s-tronic, but generally really pleased with it, especially in manual mode.
However.... There seems to be a big difference in the way standard (not adaptive) cruise control works on descents between the two gearboxes. On the manual, if you went down hill and set the cruise control it would use the brakes to maintain speed - this was brilliant and meant you could quite reliably use it to manage speed through safety cameras etc.
On the s-tronic it appears that no brakes are used, instead it attempts to use engine braking by changing down gears as you go down hill. This seems so far to be much worse at maintaining speed! For example, I set it at 40mph on a hill with a 30 limit at the bottom. I wasn't even half way down the hill and the car had downshifted twice yet still hit 50! This meant a significant hard brake at the end to get to down to 30 in time.
I tried flicking the lever into manual mode, yet this time there was no engine braking either (as it wouldn't downshift without instruction from me) so the problem was even worse.
All in all I much prefer the cruise control in the manual system as it's far more reliable and predictable.
Has anyone else noticed this and do you think it'd be possible to enable the braking feature through VCDS?
