manual / auto gearboxes
205man Jul 25, 2010
  1. 205man
    205man Active Member
    1,071
    13
    apart from the obvious that one has a clutch and other torque convertor, is the rest of the drive system basically the same?, and are all the seperate sections individually sealed, ie the front drive has its on oil supply, the rear diff its own, the centre its own etc etc,
    reason i ask is that my front drive has a small leak and wondered if it a seperate sealed unit from rest of auto system, from what i can see / looked up it is but just wanted to check before before i checked the oil level
  2. Broken Byzan
    13,235
    464
    Yes the box, whichever type is sealed and lubed on it's own. You can check ATF from the engine bay can't you?
  3. adamss24
    adamss24 Well-Known Member
    4,552
    392
    The centre diff is integrall to the gearbox on quattros so its shares its oil supply with the box. Rear diff is seperate...
