Manifold/exhaust blowing
kelk11 Mar 30, 2011
  1. kelk11
    kelk11 Member
    112
    Over the last few weeks my car has started making a blowing noise around the turbo and manifold area, can't really pin point as there doesnt seem any room for a good poke around but the smell of fumes confirms there is a leak. Is there any common failures? Gaskets etc which may be the problem? finally anywhere around West Yorkshire I can take it to get repaired?
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    s3 or a3?
  3. kelk11
    kelk11 Member
    112
    S3
  4. <tuffty/>
    21,886
    4,205
    Typically its the gasket from the mani to the turbo that goes but it could also be due to a cracked manifold... replacement gasket can be done easily...
  5. kelk11
    kelk11 Member
    112
    Fingers crossed on it been the gasket! You got a rough idea on how much it will cost?
  6. s3dave
    10,110
    736
    £10 ish on ebay, maybe cheaper at audi
  7. kelk11
    kelk11 Member
    112
    What about fitting, how long will it take as I havent the ability to do it myself :(
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Easily?? lol, those bolts are tight....
  9. Welly
    10,696
    130
    Shouldn't take long mate, charge pipe off, bolts out, old gasket slips out, new one in, bolts back in, charge pipe back on.
    Thats it.
  10. <tuffty/>
    21,886
    4,205
    Relatively.... :)
  11. kelk11
    kelk11 Member
    112
    Have tried to have a poke around but can't see anything as I don't have any tools. Phoned around a few garages but none to be polite can be ***** with the work involved and seem to cringe as soon as I say manifold. Any recommendations on garages to replace the gasket or anyone off here able to do it, willing to pay. Live in west Yorkshire, thanks
  12. DavidW
    DavidW Member
    211
    If it's the gasket it's an hours work tops, most garages should be able to sort itif you aren't confident of doing it youself. Whereabouts in West Yorks?
  13. kelk11
    kelk11 Member
    112
    Between Huddersfield and Leeds, id give it a bash myself just don't have the tools required.
  14. DavidW
    DavidW Member
    211
    A basic socket set or spanners will do it, you'll just need a socket for the three bolts that secure the manifold to the turbo. It can be done with a multioint socket but I think the proper bit is an E10 female Torx type.
    Halfords | Halfords Female Torx Socket 10E 3/8" Drive
  15. Andrew@A.L.D
    3,879
    617
    If i wasn't busy all the time then i would do it
