Making a front fog wiring loom
voteforpedro Jan 5, 2009
  1. voteforpedro
    voteforpedro Member
    632
    My car doesn't have fogs in the headlights and there's no wiring behind the fog switch blank, so I guess there's no loom for it. :)
    I made a loom for my Mk3 Golf. The positive pins on the back of the fogs splice together then pushed into a multiplug above the radiator as the loom from plug to dashboard was already there. The negative pins spliced together then went to the negative terminal on the battery using a spade terminal. Then I just bought a new headlight switch with front fog function and it worked.
    I suppose it's not so easy on the A4 as there's probably no wiring for it at all on mine.
    So... positive pins go where? I'm not too fussed about them not switching on/off with the headlights. I've got a switch and the fogs are on order. :)
  2. aragorn
    18,608
    871
    theres probably a relay that will fit in the main fusebox which switches the load, that relay will likely take its power from the headlights, so they will work as expected.
    On our 96 the front fogs turn on automatically with the rears, or, independantly if the headlights are on, ie you can only have front and rear, or just front.
    I'd imagine if you look at the wiring diagram in the haynes it shouldnt be too hard to work out, but it might be easier if you get the front fog switch plug and some of the loom from a breaking car to allow you to make the connections.
