Make this a sticky
macattax Feb 7, 2007
  1. macattax
    macattax Member
    455
    I found this a while back because the "my audi" page doesnt work anymore.
    It is a decoder to translate the options found on the data sticker found in the wheel well in the boot.
    Basically you enter all the option codes eg. 1BE and then press decode.
    It will then tell you what it means so for this example 1BE = sports suspension/shock absorption.
    I hope this will help everone on the audi forum.
    http://igorweb.org/equidec/
    On a seperate note I have a code that is C1L which translates to alloy wheels 7Jx16, offset 45. Does this mean I have 18" rims?
    The tyre code is H6V= 245/45 R 18 Y.
    Its strange because in my opinion they dont look like 18" rims but I am no expert at all.
    Have fun
  2. docurley
    4,071
    86
    Well the rims must be 18" if the tyres say 18 as this is the size of the tyre 45 is the profile and 245 the width of the tyre.
    But if you are running on 45's you have too large a profile for your car the wider the tyre the larger the profile as I was advised by my tyre company.
  3. Sinny71
    Sinny71 S55 LKS
    779
    I may be wrong but the tyre sizes and profiles work like this
    e.g. 235/45 x 17
    width=235mm
    profile=45% of the width
    diameter=17 inches
    So as docurley mentions above, the wider the tyre, the bigger the profile.
    You seem to have mentioned 1 code saying 7jx16" wheels but another saying 18" tyres :uhm: :uhm: What do the tyres say on them ??
  4. Biglockie
    Biglockie Aye you know it makes sense
    1,032
    I remember being told something like that.
  5. macattax
    macattax Member
    455
    The tyres say 205/55zr16.
    So the tyre details on the data sticker must have been a mistake.
    But the offset should be right at 45 yeah?
  6. Sinny71
    Sinny71 S55 LKS
    779
    It sounds like a mistake. I'd guess that the data re the wheels though is probably correct.
    I'm not sure of the offset but I'm sure one of the B5 guys can help.
  7. macattax
    macattax Member
    455
    AAHH it was human error on my part. Tyre code should have been H6U instead of H6V but to be honest the U and the V on the data sticker look the same.
  8. macattax
    macattax Member
    455
    Ok here is my data sticker decoded just to show you how it comes out.
    X2B = national sales program Great Britain
    B0A = component parts set without country-specific design requirement
    C1L = cast alloy wheels 7J x 16 five-arm style, offset 45
    G0C = 5-speed manual transmission
    H6U = tires 205/55 R 16 91W
    J1P = battery 220 A (44 Ah)
    M9L = 4-cylinder gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2, base engine is T8B/T8C
    Q1D = sports front seats
    0JE = weight category front axle weight range 5
    1AC = anti-lock brake system (ABS)
    1Q3 = mass damper for steering wheel, XXHz
    2PV = leather trimmed sports steering wheel
    5RV = outer right rear view mirror: non-spherical
    5SJ = outer left rear view mirror: convex
    T8B = components for, base engine, unit 058.D
    0YD = weight category rear axle weight range 4
    3S0 = without roof rails/roof load rack
    4VE = two 3-point seat belts and one static lap belt in third row of seats
    0G1 = gearshift lever
    8VD = radio-controlled clock
    8GD = alternator 90A
    8RN = eight speakers (active)
    1KD = disc brakes, rear
    1LB = disc brakes, front
    3FA = without roof insert (standard roof)
    8 speakers (active) wtf? I only see two speakers in front driver and passenger door near the storage pocket (also there are speaker looking things around the door handle on each door in the front?) and 2 in the back window shelf.
    Where are the other speakers?
  9. Sinny71
    Sinny71 S55 LKS
    779
    This was mine done a while back, takes forever to put the damn codes in though.
    E0A = no special edition
    7A0 = without CD changer/CD player
    4UE = airbag for driver and front seat passenger
    6XD = outer rear view mirrors: powered, heated
    6TS = outer right rear view mirror: non-spherical, large viewing field
    J1D = battery 380 A (72 Ah)
    5MA = decorative inserts
    7X0 = without park distance control
    4R5 = power windows with comfort operation andcircuit breaker, mechanical window regulators rear
    F0A = no special purpose vehicle, standard equipment
    8GU = alternator 140A
    0YJ = weight category rear axle weight range 9
    0JG = weight category front axle weight range 7
    T9J = components for, base engine, unit 038.K
    3NZ = rear seat bench unsplit, backrest split folding
    8JK = ellipsoidal headlight for driving on the left
    U1B = instrument insert with mph speedometer, clock, tachometer and trip odometer
    1N1 = power steering
    8Q1 = headlight-range adjustment
    9Q3 = multi-function indicator, without on-board computer and check control
    8Z5 = engine cooling system, type 1
    D3E = 4-cylinder turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3, base engine is T9J/TG0
    7Q0 = without navigation device
    C1X = alloy wheels 7 1/2J x 17 five-arm spider style, offset 45
    7K0 = without tire pressure warning light
    4X3 = side airbag front with curtain airbag
    2K7 = reinforced bumpers
    6R2 = leather gearshift boot
    3L3 = manual height adjustment for front seats
    4KC = side and rear windows tinted
    3Y0 = without roll-up sun screen
    4K4 = radio remote controlled central locking operated from inside and separate trunk release
    5D1 = carrier frequency 433.92 MHz
    1SA = without additional engine guard
    0GZ = emissions concept EU 3
    4GP = windshield tinted with sun band and viewing window for vehicle identification number.
    Speaker wise, my A4 has 10 speakers. 2 in each door (one next to the handle), a sub in the boot and 1 speaker mid dash.
  10. macattax
    macattax Member
    455
    I have quite a few things that you have listed but its not on my data sticker eg
    6XD= outer rear view mirrors: powered, heated
    1N1 = power steering etc etc
    I have a 6cd changer but thats not listed either but I am the 3rd owner so maybe the second owner who I know bought it from an audi dealer may have asked for a few more options to be added to it before he bought it off them.
    Also I have the light package.
    But maybe Audi became more specific with data stickers in later models after 99.5 and listed every single detail.
    Where is the sub located so I can check if I have one?
  11. Nessy
    Nessy VW + Audi mad
    937
    89
    I too have quite a few things on my A4 Avant that aren't listed on the sticker eg 6 disc CD player in boot, think that when Audi decided what equipment their UK models had some of the equipment was just bunched together as 'GB specification' on the code list, and I'm sure there is a code with that name as it is one of the codes on my data sticker......
    I did find a while back a site which listed every single VAG option code as an alpha-numeric listing and it runs to 240-odd pages on the computer monitor!
    As a file its about 6mb in size, so for a text-only file its quite huge!
    As far as I'm aware only the Avants had a sub and its located underneath the nearside luggage compartment; have never seen it but have felt it in action!
  12. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    Tell that to the new 911 owners!
    295/30/19 on the rear
    if you increase the profile with width you will be using range rover tyres.....
    I have 245/40's
  13. Rich
    Rich Rollin on boost mother hubbards
    373
    7A1 = CD changer preparation
    4UF = drivers and front passenger airbag with front passenger airbag deactivation
    5MF = decorative aluminum inserts "strips quartz"
    4R2 = power windows front, mechanical window regulators rear
    0L2 = electric throttle actuation
    8GL = alternator 120A
    T6V = components for, base engine, unit 06B.A
    3ND = rear seat bench/backrest, unfolding
    V1D = code not found :-(
    9Q2 = multi-function indicator/on-board computer with check control
    MW8 = 4-cylinder gasoline engine 1.8 L/110 kW 20V turbo, base engine is T0L/T16/T6V/T63
    7G0 = without humidity sensor
    7KP = code not found :-(
    4X1 = side airbag front
    2K1 = reinforced bumpers
    0GG = emissions concept EU 4
  14. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    LOL :)
  15. Rich
    373
    :D~! More coming soon! (not stickers) !
