make my a3 tdi handle ??
welshd1k Mar 22, 2014
  1. welshd1k
    welshd1k Member
    150
    I thoght it was just tyres but I assume not just put new rubber on her as she was sat on filthy cheap tyres so put some general something or others on 95 a corner . And we'll I'm still dissapointed with the handling of I'm honest . My last car a 07 skoda superb bog standard Tdi 100 handled better and seemed to hold the road better at speed in the twisties yes it was more boaty but it never slid out on me on a certain length of road I drive daily .
    Yes the a3 is faster but the handling shocks me in a straight line and some slight bends she feels glued but in tighter stuff just feels naff ? Is this just me or ?
    How should I go about getting her to feel better ? Lower it ? Nee bushes ? Anti roll bars ?.
    Any ideas btw she is a 04 Tdi 140.on 18" with 225. 45 rubber
  2. Sidhu88
    Sidhu88 Active Member
    808
    76
    given the fact you don't even know what tyres you've just put on is probably the beginning of your problems. New tyres need to be worn in anyway, if you've worn them in and you still have problems then maybe they're just cheap tyres again. A good set of 18" boots aint cheap. Also depending on the spec of the car you might have a suspension set up designed for comfort as opposed to handling. My car has an s-line set up and is bumpy as a mother. Aside from the lack of steering feel i've never had an issue
  3. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Good tyres
    Check suspension & bushes, replace/ upgrade anything worn
    Full 4 wheel alignment
    Upgrade rear ARB
    Whiteline Anti lift kit
    Done
  4. welshd1k
    welshd1k Member
    150
    tyres are general alitmax uhp's ist a tdi 140 sport . so im guessing should be stiff ish ?
    thinking about poly bushing the front and the anti lift kit /
  5. warren_S5
    7,210
    2,488
    Tyres are so/so, but nothing to write home about. Rear ARB will make biggest difference along with WALK.
  6. Westy
    Westy Well-Known Member
    17,443
    1,105
    Can the rear arb from the Mk5 golf R32 be used on the A3 like the old mk4 one could on the 8L?
  7. warren_S5
    7,210
    2,488
    Somthing rings a bell that this is possible
    Westy likes this.
  8. Westy
    17,443
    1,105
  9. warren_S5
    7,210
    2,488
    So Sharan is the thickest, suppose it carries greatest weight and higher centre of gravity.
  10. mcg
    mcg New Member
    15
    Think the real question is... daily drive + sliding = :uhm:
  11. welshd1k
    welshd1k Member
    150
    What's so odd about that I lve in rural Wales with some very nice driving roads I drive daily
  12. s3_trev
    s3_trev Northern Ireland Gold Supporter Team Brill Red Audi S3
    1,864
    646
    Pretty much this. Although I would upgrade rather than replace suspension. Would probably go for lowering springs and a good set of dampers (like Bilstein B8s). Coilovers would probably be overkill in this.
    Also dont forget to make sure your tyre pressures are correct as this is very important.
    c_w likes this.
  13. c_w
    c_w Well-Known Member
    1,169
    91
    The poor damping makes the car feel out of control more than anything else IMO. S-Line springs with B8 damper would be a nice road setup. Finished off with uprated anti roll bars.
