Major power loss ! whats up ?
mattyboy199 Mar 3, 2008
  1. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    Seems the car has begun to lose boost or power it judders under heavy throttle but when light throttle is applied its fine ish. The car is remapped & the sound of the turbo cant be heard as much as before nor is the DV when opened. I m pretty sure its a lose or split hose but i m not sure where to start, has anyone else had similar problems.
    All coil packs & MAF are new within 3months.
  2. jojo
    28,945
    3,600
    Despite these still being relatively new, I still recommend disconnecting the MAF for a drive to see what happens, as it's showing the symptoms of a knackered MAF.
  3. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Sorry to say it but in an ideal world you need to get it on Vag.com. Could be running lean maybe? However I agree with Jojo to do the MAF to eliminate that again. Also worth having a good hunt around for any splits off the DV or the N249.
  4. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    im having a similar problem, got the diagnostics done which didnt show anything but going to take it to cannock VW this weekend to get it on vagcom and get it sorted through and through
  5. mattyboy199
    1,889
    29
    when removing the MAF what should i expect ? things to be normal again or different charactistics ?
  6. jojo
    28,945
    3,600
    It should run smoothly with out the hesitance, but running lower power, like 50BHP missing, but it should still boost a go well if it's been remapped. If it's still hesitating and pulling back, then you can replug it and look elsewhere - at least you have eliminated the MAF from your problem.
  7. mattyboy199
    1,889
    29
    right i tried that & i dont think its the MAF, i did forget to mention that the engine management light isnt on & that the exhasut occasionally pops ! ;-(
  8. mikey_abz
    mikey_abz 2007 Audi S3
    39
    I had a similar problem to that with a volvo 480 turbo i had a few years ago! when accelerating hard it would judder slightly and make a popping noise(misfire) revs but it wasnt constant. at slow speeds and normal acceleration it was fine, I traced it to the dump valve being replaced to an forge atmospheric DV. when it was replace back to oem(recirc) it was fine. just a thought.
    Mike
  9. mattyboy199
    1,889
    29
    Thanks Mikey,
    I changed to the standard bosch DV this evening after work & it seemed to improve the whole situation although the judder is still there it picked up better than it did. I think my DV is leaking big time !
  10. mattyboy199
    1,889
    29
    Still down on power its getting looked at tomorra fingers crossed
  11. S3 Rav
    2,825
    30
    matt iv had a very similar problem to you and think it may be my dump valve. i have the 007p. gna get it looked at at midlands VW and hopefully be running on full steam again!
  12. mattyboy199
    1,889
    29
    got my car checked out yesterday there was a number of fault codes listed all to do with the turbo system but it couldnt possibly be all them - all at once. Seems as though theres a pipe collaspe similar to the TIP infact its right next to it turns 180 degrees. Being replaced on tuesday thank god !
