major power loss 1.9TDI 130
seany26 Mar 3, 2010
  1. seany26
    seany26 Member
    109
    A FRIEND FONED ABOUT A POWER LOSS ON A 2003 1.9TDI 130 IN ALL GEARS BELLOW 2200 REVS OR SO, SO I HEADED DOWN AND STUCK THE GOOD OLD VAG-COM ON IT, PULLED UP MAF AND BOOST PRESSURE COMPENSATION. SO I CHANGED THE MAF SENSOR AND CLEARED THE FAULT CODES, STILL TO FIND THE POWER LOSS WAS THEIR AND REALLY BAD, AND NO FAULT CODES BEING READ NOW. RELATING TO THE BOOST PRESSURE COMPENSATION I THOUGHT ID CHANGE OVER THE BOOST PRESSURE SENSOR FROM MY OWN CAR (SAME CAR) STILL TO FIND NO DIFFERENCE!
    THEIR IS NO BLACK SMOKE POORING OUT OF THE BACK SO ITS REALY GOT ME.
    THEIR WAS ALSO FAULTY BRAKE SWITCH SO I CHANGED IT FOR ONE LAST STAB BUT NOTHING
    ANY1 EXPERIENCED ANYTHING LIKE THIS OR SHED ANY LIGHT ON SUMFING ELSE TO CHECK.
    PS THIS SEAMS TO BE A VERY GOOD FORUM, READ ALOT OF INTRESTING POSTS
  2. BILKO1
    BILKO1 Member
    301
    As you have vagcom take it for a drive and log the boost pressure.
  3. Andy101
    Andy101 Active Member Team Ibis Audi A6 Audi Avant Owner Group Black Edition
    249
    44
    I had this exact this problem on my 1.9TDi. It turned out to be a faulty O Ring in the Turbo.
  4. scott b
    scott b Active Member VCDS Map User
    1,254
    my mate has the passat with the same engine, he used to lose boost all together, turn ignition off and on whilst driving, boost came back. but ended up needing a turbo.
    check for air leaks
  5. seany26
    seany26 Member
    109
    ok ill give a few of these a check out 2nite if i get round 2 it, and post back
  6. seany26
    seany26 Member
    109
    had vag com hooked up but i could not find an address for the live data on the boost pressure?
  7. paul20v
    paul20v Audi fanatic
    1,113
    Theres a few common issues ,
    N75 valve
    Maf
    vac pipes split of come off
    Map sensor (often overlooked )
    and last but not least Turbo as the variable veins get sooted up.
  8. seany26
    seany26 Member
    109
    yea i think its the variable veins myself, behaviour is as if they are getting stuck if that makes any sence.
    the map sensor is the only1 I aint located were is it, if possible could you get pics.
  9. BILKO1
    BILKO1 Member
    301
    Maf sensor is in the plastic inlet pipe as for Vagcom boost pressure reading addresses check out the rosstech wiki i'm sure thats where i found it.
  10. Marc1
    Marc1 Member
    728
    Map sensor is connected to the intercooler iirc.
  11. paul20v
    1,113
    MAP sensor is on the right at the back of the engine on the top of the plastic inlet pipe easy to see and fit ,if you need a pic i can sort one out tommorow if it will help :)
  12. Marc1
    Marc1 Member
    728
    Oh yeah, that's what I meant lalala on the intercooler pipe at the back on the nearside, whoops!
