Major lag in between gear changes on S3
James.B8 Feb 2, 2018
  1. James.B8
    James.B8 Well-Known Member Audi S3 Black Edition S3 Saloon Mystic Blue
    759
    736
    93
    This has happened on a couple of occasions recently but tonight was worse than ever trying to over take and in the end I had to back off (no thanks to the car speeding up to try and stop me getting passed:rage:wasnt even a “fast” car) as the lag was so bad I just couldn’t build speed.
    This is when I’m in individual or dynamic with the gearbox in “S” and plant my foot down from around 20-35mph so usually in the low gears. Pretty sure it’s from 2nd to 3rd but I build speed and when it comes to changing up a gear the car completely drops back almost jolting me forwards that’s how aggressive this lag is. Once it’s done this it’s fine and will change into higher gears as normal.
    I’ll be taking the car into Audi but just wondering if anyone’s experienced this before or what it could be?
    The car is an Audi S3 Saloon s-tronic 65 plate.
    Thanks in advance :)
  2. DrMal
    DrMal Active Member Team Navarra TFSI Owners Group Audi S3 quattro DSG
    111
    149
    43
    Yes, I get that occasionally on overtaking and on one occasion it was bloody dangerous. It doesn't seem to matter what overall mode the car is in. I'll nudge the gearbox into 'S', kickdown and at that point the sequence of events is a bit vague (I'm concentrating on overtaking), but there's a change down, a long period of high revs (maybe other way round), and then eventually the power comes in.
    It's happened on perhaps 1 in 4 or 1 in 5 times I've gone for a fast overtaking manoeuvre. I'm guessing the s-tronic gear selection strategy gets confused, but whatever the cause, it's not good.
    James.B8 likes this.
  3. richard skilbeck
    richard skilbeck Member
    42
    21
    'Nudge gearbox into ' S '?
  4. DrMal
    111
    149
    43
    With s-tronic in D, pull/nudge/flick the drive select lever towards you to change the mode to S.
    richard skilbeck likes this.
  5. richard skilbeck
    42
    21
    Ah right I believe as I always drive in Dynamic I am automatically in S mode. Forgot I could do that to be fair.
  6. richard skilbeck
    42
    21
    Mine does this also but not very often for it to be an issue, be interested in a resolution.
  7. James.B8
    759
    736
    93
    Yeah it’s not safe is it!! I tested it again today on an empty road but it didn’t happen so really not sure what it could be.
    Something is definitely not right so I’ll try book it into Audi when I’ve got a moment then post the results if they find anything to hopefully give anyone else who has this an answer.
  8. vamos
    vamos Active Member
    109
    97
    Traction control ?
  9. DrMal
    111
    149
    43
    No, the traction control light doesn't come on. It feels like the box is requesting a specific engine speed for the gear it wants but it's not getting it straight away, maybe because there's a kickdown in progress. I don't know, it's weird, disconcerting and sometimes dangerous.
  10. James.B8
    759
    736
    93
    Yeah plus one mines the same as this really. Don’t think it’s anything to do with traction
  11. Tom.H
    Tom.H Well-Known Member Audi S3 Black Edition s tronic Team Ara Blue
    2,343
    3,881
    Driving in dynamic and S is sh*t on the road. Holds on to the gears too long, where you'd be in 6th in D you'll be in 3rd in S
    jassyo06 likes this.
  12. James.B8
    759
    736
    93
    Yeah only really good for overtaking or giving it the full beans
  13. Lehn
    Lehn Well-Known Member Team Daytona Audi S3 DSG
    318
    302
    Just a quick question for us non UKs, when is the car from? Just trying to specify if this is a 6 speed or a 7 speed auto problem :hi:
  14. DrMal
    111
    149
    43
    Mine is MY2017, seven speed DSG.
  15. James.B8
    759
    736
    93
    Must be both as mines a pre facelift so 6 speed
  16. 4K
    4K Well-Known Member Team Glacier Audi S3 DSG
    608
    357
    So not sure if this is the same thing or not, but my PFL S3 has just hit 32K miles and sounds like it's having similar issues.
    Essentially, it's now very jerky/lumpy on acceleration/deceleration in S mode with quite a great deal of lag/loss of torque forcing me to push on harder.
    D seems ok and fairly smooth, except for the horrific lag between the throttle/gearbox/ECU which has been there since day one, necessitating going into S mode for overtakes etc (one of the main reasons I regret buying this car).
    Are you experiencing the same? What mileage has yours done?
  17. James.B8
    759
    736
    93
    I wouldn’t necessarily say jerky or lumpy just very laggy and possibly lack of torque. Occasionally feels down on power too.
    D is fine for me to be honest just when I’m in S mode.
    I’ve just done 24k
  18. DrMal
    111
    149
    43
    No, it's not turbo lag (which is pretty constant unless it's already on boost), this is a significantly longer delay, probably 3-5 seconds, during which time it feels like a loss of torque. I've only noticed it while in S-mode. Mileage: 4k
  19. 4K
    608
    357
    Sounds similar, all of us have it in S mode.
  20. steve111b
    steve111b Member
    It is likely that your engine is going into protection mode. This causes a fuel cut which is dramatic. A less dramatic lag could be an electrical problem. I have had both. The electrical problem may only occur when the engine has another separate problem that produces the protection mode.
    Also, there seems to be some confusion about how the DSG shifts. If you are not familiar with its operation you may believe there is lag when the DSG is simply doing what you tell it to.
    My DSG was in an 8P and never produced any codes. Not sure if a dealer is going to do much unless you can demonstrate the problem. I did a lot of testing and eventually got the car to buck (from a fuel cut) at least a dozen times with a technician (not from a dealer) in the passenger seat. This was not enough to find the problem. Good luck.
  21. DrMal
    111
    149
    43
    Having worked in powertrain automotive, I don't think it's either of these, at least not in my case. It's not a loss of power and it doesn't present like an electrical fault would (too repeatable in how it presents itself). My suspicion is it's some unintended interaction between the engine strategies and gearbox strategies, which is why it won't show up via OBD and there's no freeze frame. It probably never showed up under pre-production testing, or at least not enough to be deemed significant.
    amb66 and James.B8 like this.
  22. 4K
    608
    357
    You can reset the DSG memory through VCDS. That might do the trick.
  23. steve111b
    steve111b Member
    The car I am driving now has the 7 speed, but I am not sure how it works. For the 6 speed I followed a bunch of rules that I made up and I felt the box worked well. So for the 6 speed the car can only go immediately into a gear that has been preselected. In Sport the highest gear is 5th with 4th preselected, which means when you hit the throttle the DSG instantly goes into fourth.
    However, if you are in Drive, slam it into Sport and floor it you have asked the box to do something it is not designed to do. That is because when you are in Drive the box is in 6th with 5th preselected. You need to go into Sport and give it a few seconds for the box to go into 5th and preselect 4th.
    Now comes the messy part. Let us say you are in Sport (5th) and you want the maximum available power. You floor the throttle and the box instantly goes into 4th, but now the box is busy getting 3rd from the instant you floored it. It is in 4th for about a second and then selects 3rd when it becomes available. However, when you look back with 20/20 hindsight the 1 second that the car was in 4th seems like lag since there is not a surge forward in 4th. The surge forward only happens when 3rd is engaged. So why not go from 5th directly into 3rd? No can do because both of these gears are on same (odd) shaft.
    And another thing, do not use the paddles for any of this. Using the paddles reverts the box back to the Drive preselects. 4th is never preselected when using Drive.
  24. Matt Titanium
    Matt Titanium Well-Known Member Team Navarra Audi S3 Manual
    235
    329
    This was my experience over six weeks with an S3 with STronic. The box was often confused, the car response all a bit fly by wire and laggy. Floor it from stand still, great. Every day driving, often annoying.
    Perhaps 1200 miles wasn't long enough work out all the "rules" or master the "technique".
    4K likes this.
  25. 4K
    608
    357
    Was that a 7 speed or 6?
  26. Matt Titanium
    235
    329
    6. I've never tried a 7
  27. vamos
    vamos Active Member
    109
    97
    I can believe dropping it into s mode while simultaneously flooring it would confuse the hell out of the dsg.
    I usually put it into s mode and wait a few seconds for the box to select the gear for the speed I’m at. Then I floor the hell out of it.
  28. 4K
    608
    357
    Just had a software update on mine today and it's rectified quite a few of these issues.
    James.B8 and richard skilbeck like this.
  29. James.B8
    759
    736
    93
    Was this done free of charge by Audi?
  30. Richierich37
    Richierich37 Well-Known Member Team Navarra Team V6 Audi S3 Audi A5 S-line owners group DSG
    173
    370
    Our 2016 FL S3 does exactly the same unfortunately! It’s as if the DSG box initially selects the wrong gear then changes its mind causing the car to pause before accelerating away. Pretty dangerous and has prevented me from wanting to over take on a few occasions. Now I just sit at 40 mph and try to get 300 miles out a tank. #wasteofafastcarformenow
    4K likes this.
  31. Boj27
    Boj27 Member
    64
    15
    I too get this but I have a golf 7r. 6 speed dsg. It’s like the throttle cuts for maybe 1/2 a second for me and it jolts me forward like you wouldn’t believe. Only seems to be when in sport. I think it’s the most apparent when I drop it into sport and then floor it and engage kickdown. Kind of want a Dsg tcu Map to see if this resolves the issues or not. On another note, I’m not sure if this issue has only started happening since I fit my jb4, does anyone have a jb1 or jb4 to confirm?
    I think the best thing to do would be to use manual mode.
  32. Lehn
    318
    302
    Just to be 100% sure, is this what you're experiencing? For me it sounds like what you guys are describing are a lot worse than that.
    Audi's answer:
    amb66 likes this.
  33. 4K
    608
    357
    Of course. Mine's still under warranty. Think the S-Tronic memory was reset too. Mine is PFL though. There was a bulletin out on the gearbox.
  34. mikemod
    mikemod Well-Known Member Team Tango Audi S3
    500
    719
    93
    In 12 years of driving DSG/S Tronic cars I have used "S" mode about three times to try it and always found it never did what I wanted so I never use it.
    "D" mode in traffic, manual mode everywhere else. :racer:
    gringosteve likes this.
  35. 4K
    608
    357
    I would've got rid of the S3 by now if I could/would only drive it in 'D' mode. S is the only fun thing about this car, other than that it's pretty soulless. D mode has all the Drive-By-Wire lag between the gearbox and throttle that makes hard acceleration/overtakes near impossible and painful.
    oli356 likes this.
  36. DrMal
    111
    149
    43
    Had my first oil change service yesterday (Perth Audi, about £50 cheaper than Edinburgh and great service). Mentioned this on book-in. Didn't expect anything to come of it, but interestingly they reported that they'd replicated it on a test drive, no fault found and escalated to Audi Germany. I take it with a slight pinch of salt and doubt Ingolstadt will do anything, but at least something got logged.
    keenu and James.B8 like this.
  37. James.B8
    759
    736
    93
    That’s good to hear. Mines a PFL also
  38. mikemod
    500
    719
    93
    That's why I said I only use D mode in traffic, hardly much point in S mode when sitting in a queue.
    I find the car in manual is the best mode when wanting to have a but of fun, never really saw the point of S
    Tom.H likes this.
  39. ictus_duplo2
    ictus_duplo2 New Member Audi S3 Navarra Blue Classic Manual
    Used Perth when visiting my Mum as was cheaper than Glasgow and the person I spoke to actually knew what they were talking about. Will use again.
    DrMal likes this.
  40. MaxBoostMRC
    MaxBoostMRC New Member
    My S3 Saloon use to do it then MRC remapped the gearbox and never happened since.
