Major grinding squeeking
Gstar51 May 25, 2013
  1. Gstar51
    Gstar51 Member
    79
    Just had a major grinding crunch squeeking from front end. Not quite sure what it is. Nothing to do with engine as it does it when free wheeling. Any ideas pls?
  2. krisavant
    krisavant Active Member
    449
    61
    Clutch down?
  3. Gstar51
    Gstar51 Member
    79
    No clutch down. Doing it when the engine is off and the handbrake off. Just pushing it down the road?????
    Just got fresh mot today too.
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    Could be some **** stuck in the brakes
  5. Gstar51
    Gstar51 Member
    79
    Result
    Yeah found the *******.
    Bolt holding the bearing assembly on has come loose and hit the drive shaft. New bolt from audi 2.95
  6. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Lucky you found it in time...could've been a major incident!
