Major electrical woes.
S3 GAZ Mar 7, 2012
  1. S3 GAZ
    S3 GAZ Member
    381
    17
    Car is 2004 1.9tdi Quattro sport 130bhp.
    i was driving along today when the yellow traction control triangle appeared on the dash, car was driving fine so thought il scan it when i get home. Got to a junction and went to indicate but nothing happened. interior lights started flashing, hazard triangle started to flicker and nothing worked
    no window wipers or washer jets
    no headlights,
    no indicators
    no electric windows
    no central locking.
    when i pressed brake there was a clicking sound also but brake lights worked.
    some things still function properly like sidelights, rns-e/radio, dis, all dials work ok.
    odd thing is when i removed key from ignition the dash stays illuminated and the rns-e stays on.
    i have run a scan but has not revealed anything.
    i am thinking convenience module. passenger footwell is bone dry as i have removed drain plugs in battery tray.
    any ideas :(
  2. quattrojames
    14,050
    578
    Any water leaks around the ECU box?
  3. S3 GAZ
    S3 GAZ Member
    381
    17
    had a look but all seems fine at ecu. is there a electrical control unit. lots of clicking coming from behind steering wheel whist hazard triangle is simultaneously flickering,
  4. quattrojames
    14,050
    578
    And nothing on a genuine VCDS scan? Odd.
  5. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,241
    180
    How does it start in cold weather?
  6. S3 GAZ
    S3 GAZ Member
    381
    17
    Meant to say Car is 2004 1.9tdi Quattro sport 130bhp
    Funnily enough its stars like a dog in cold damp mornings. I have posted in the thread relating to this about the grey smoke on startup that quickly dissapears as soon as the car has been running for a few mins. Is there a connection between the electrical issues and poor starting.
    Re Quattrojames it was a vcds lite scan not genuine cable so can't rely on it to be honest. Il get it scanned properly ASAP.
  7. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    May be an idea to check all earth points.
    I would expect there to be an earth point behind the dash/foot-well, may be worth taking them off, rubbing down slightly and re-installing - do the same for the "-" connection on the battery also.
    I had similar issues on my Ibiza Cupra, however it threw up a lot of fault codes - turned out it was an earth point for the ECU.
  8. S3 GAZ
    S3 GAZ Member
    381
    17
    Thanks Alex. Il check all earth points.
  9. swarcup
    swarcup Well-Known Member
    1,326
    40
    Sorry this maybe a bit vague but ive read before about a power distibution module they can cause all sorts of electrical issues when they go, sure its behind the dash area aswell
  10. S3 GAZ
    S3 GAZ Member
    381
    17
    Well went out this afternoon after not touching the car since last night and all the electrics are working perfectly. None of the symptoms I encountered yesterday have reappeared.
    I took the car out for about 40mins and the electrics were spot on. I wonder if it's had one of those 24hr bugs that make u phone in sick ;)
    Bloody electrics do my nut in. I'm sure it won't be the last I have trouble with them but fingers crossed it was a little gremlin that's rectified of its own accord.
    Thanks for help guys.
  11. AlexGSi2000
    1,464
    199
    Ah thats good news - could have been damp somwhere....
  12. AudiLeon
    2,241
    180
    I'm pointing towards the battery.
  13. S3 GAZ
    S3 GAZ Member
    381
    17
    Thinking that myself mate. It was replaced just before I bought the car. It's an RAC branded one don't know how they are.
    Is that why you were asking about the cold starts
    I'm running a fair bit of kit in it. Rnse and head mounted DVD player for my bambino which was incidentally playing the smurffs at the time. Maybe too much juice required and battery is on its last legs.
  14. boytrigg
    boytrigg Member
    107
    im having the exact same problems you have but mine haven't dissapered lol did you find out what it was in the end ?
  15. S3 GAZ
    S3 GAZ Member
    381
    17
    Just been reading your thread mate. Its never returned in that guise.
    I have since had some electrical starting issues caused by water in the ECU box that corroded some wiring and flung up all manner of dash lights
  16. boytrigg
    boytrigg Member
    107
    cheers for the reply man il need to check the box out the morro lift the carpets up aswell make sure there dry underneath its raining pretty heavy right now so will no in the morning if waters getting in somwhere haha
  17. S3 GAZ
    S3 GAZ Member
    381
    17
    Have you checked your battery. When its a bit low on charge it will put the dash lights on ABS, BRAKE etc
  18. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    I had this problem before christmas and it turned out moisture had gotten into one of the control modules under the dashboard (lower right behind steering wheel) it was a replacement job for me unfortunately
