Main dealer - Diagnostics check
AudiA3JJ Jan 10, 2014
  1. AudiA3JJ
    AudiA3JJ Active Member
    249
    34
    Just looking for bit of advice, I've have a juddering issue in higher revs and I'm looking to get the car in to Audi for a £96 diagnostics check. The girl on the phone said they don't just plug it in they will find the problem, just wondered if anyone else has used this and is the Audi check worth the extra over me paying some one with vagcom to just read the ecu? ... I'm not stealer savvy. Cheers
  2. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    I'd ask someone with VCDS to scan it for a few beer tokens so you have a rough idea of what's causing the issue then take it from there.
    Juddering issue when you put your foot down at high revs? Could be misfiring and a scan with VCDS would tell you if it was one of the coils that need replacing as this is a pretty common fault.
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Ask a VCDS equipped forum member to do the initial test...
    Where do you live?
    AudiA3JJ likes this.
  4. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro saloon s tronic
    1,511
    387
    Well you arent wrong..they will find the issue...and they will charge you the labour for finding the issue, and then find plenty of other issues they would like to fix and ask you those too along with the original issue.
    Robbery.
  5. AudiA3JJ
    249
    34
    So far anyone available with vcds wants £20 which is cheap I know but just wondered if I should just take plunge and pay extra £80 for Audi's technicians advice etc. It is the problematic bkd engine, its gotta be injectors, loom or maybe EGR valve.. Had similar issue on old car and that turned out to be the EGR.
  6. leeds2592
    1,399
    222
    Where abouts are you based?
    If you're anywhere near Leeds, drop me a PM.
  7. AudiA3JJ
    249
    34
    That's what I'm worried about with Audi. I'm in Leeds
  8. leeds2592
    1,399
    222
    That's true, Audi are robbing buggers!
