Main bearings... What's this?
Omniquito Sep 30, 2012
  1. Omniquito
    Omniquito Member
    55
    Hi guys,
    As a continuation of chasing an oil pressure issue i dropped the sump, changed the gauze and pump and was inspecting the bottom end and came across something i am not sure what it is?
    The centre main has a "tang" like thing each side of the cap and they have quite a bit of movement in them (as far as the recess in the cap lets them move anyway).
    I assume these are normal but is being able to move them normal or does it point to a possible shell issue and loss of pressure that way?
    I dont want to just undo the cap as the bolts are £9 each!
    Also, if i was to replace this, can you do both upper and lower shells without removing the crank? Ie. insert the upper and spin it into place?
    Thanks, Neil.
  2. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    just take the dam bolts out and look!! lol.
  3. badger5
    9,556
    2,028
    thrust washers
  4. Andrew@A.L.D
    3,879
    617
    Thrust washer, its a bearing for side to side movement
    Don't remove the bolt as there stretch bolt and will need to be replaced if removed
  5. Omniquito
    Omniquito Member
    55
    Think I will leave the bearings alone and seal it back up with a new pump and gauze then... See what happens!
    Thanks chaps
  6. aragorn
    18,544
    865
    You've roasted the engine twice with low oil pressure from a blocked pickup, and your not going to bother checking the main bearings even though theres an obviously discolored cap?
