Magnecor plug leads?
Zonda_ Apr 30, 2010
  1. Zonda_
    Zonda_ Member
    66
    My A3 1.8t is badly in need of a service and is misfiring. I've used Magnecor on other cars but can't find them listed for the A3 1.8t. Has anyone used them or can anyone recommend similar. Will be replacing plugs too if anyone has any recommendations.
  2. badger5
    9,575
    2,038
    you have coil on plugs no leads...
    where do you think you will be putting the leads from and too?
    there's a reason they're not listed
  3. Zonda_
    Zonda_ Member
    66
    Ah, never had a car that didn't have leads, I just assumed! So what's likely to be causing the misfire then, I lost about half power last night then on the way home it cut out for a second then came back.
  4. badger5
    9,575
    2,038
    coil packs... they are shocking things for failing..
    other common parts which can fail being MAF (mass air flow) meter
    misfire usually under load (boost) when they start to fail, and once popped they drop that cylinder.
    check your plug gaps.. If too large (0.7mm ideal) then the extra gap the spark has to jump, can cause an older, more frail coil to "pop"
    £25-£30 per coil pack - beware of non OE parts
    good luck
  5. Zonda_
    Zonda_ Member
    66
    That's what's happening, it feels like it's running on 3 and down on power when you go to accelerate.
  6. badger5
    9,575
    2,038
    coil pack gone.. sounds like to me
    sound like a scooby now too?
    unplug the injectors one by one to determin which one has failed.. my advise is replace all 4 @ same time
  7. Zonda_
    Zonda_ Member
    66
    What is a good make to go for? Europarts list 4 different ones.
  8. badger5
    9,575
    2,038
    I personally only use Oe coil packs
  9. Matt82
    Matt82 Active Member
    2,365
    thats what i said a tried i was poking fun at after he had a few fail. with his car, his coil packs were all sparking on idle so you didnt notice a difference when unplugged individually but pack was misfiring like a mofo
  10. Matt82
    2,365
    OE are made by BERU id expect
  11. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    The OE ones are BERU, the OE spec ones from Euro come in a VAG box and are made by BERU :)
    Change all 4 and forget about it :)
  12. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Hitachi I believe dude, well my OE ones are.
  13. A3Tom
    3,504
    14
    hmmmm, interesting. Mine have the 4 rings on the top and also BERU?
  14. DavidW
    DavidW Member
    211
    When I replaced one earlier this year it had Pulse written on the top I think. The older ones all say Bremi and are a slightly different part number.
  15. aragorn
    18,577
    868
    It might also be the ignition amplifier if its an earlier engine. Early motors had a seperate ignition amp, and a "dumb" coil. Later engines have a combined amp and coil on each plug.
  16. Zonda_
    Zonda_ Member
    66
    Annoyingly the problem has vanished now. I wonder if it will have recorded any faults on the VAG COM?
  17. mattyboy199
    mattyboy199 Well-Known Member
    1,890
    29
    i m sure oem coil packs are still made by bosch
  18. 1animal1
    9,978
    regardless you wont get the newest version from Euro, what ever difference it makes the dealers are always that one part number ahead and cost approx £2-3 more...get ya hand in ya pocket :)
