MAF SENSOR READINGS...VAG-COM?
vw754 Mar 18, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,321
    58
    Ive been told a may have a faulty MAF ,although i have power,i dont have economy.
    A4 tid 130 (awx engine) only does 24.6 m.p.g !!!! :wtf: ive replaced temp sensor,ive heard a fault maf will give wrong readings (although will still work)
    How can i check the readings via vag-com?
    and what are good readings and what are bad?
    Unless theres another reason its heavy on diesel!
    16.00 pounds it used,it did 94.6 miles town driving @ 91.9 pence per litre.
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    Measuring block Group 02 or 03 should display the MAF reading. If you are using a full recent version of VAG-COM, it should suggest the range of typical in spec values.
  3. vw754
    2,321
    58
    thanks.
  4. vw754
    2,321
    58
    hope you guys can tell me if these are good or bad maf readings.
    Tuesday,21,March,2006,12:10:51
    038 906 019 FP,,1.9l R4 EDC 0000SG 1467,
    ,Group A:,'003,,,,Group B:, Not Running,,,,Group C:, Not Running
    ,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,,,,,,,,,
    ,TIME,790-870,230-310,210-350,40-75%,TIME,,,,,TIME,,,,
    Marker,STAMP, /min, mg/str, mg/str, %,STAMP,,,,,STAMP,,,,
    ,0.01,1848,850.0,1117.2,4.8,,,,,,,,,,
    ,0.35,1890,850.0,1131.9,4.8,,,,,,,,,,
    ,0.69,1932,850.0,1117.2,4.8,,,,,,,,,,
    ,1.03,1974,850.0,1146.6,4.8,,,,,,,,,,
    ,1.36,2016,850.0,1161.3,4.8,,,,,,,,,,
    ,1.70,2058,850.0,1166.2,4.8,,,,,,,,,,
    ,2.04,2100,850.0,1185.8,4.8,,,,,,,,,,
    ,2.38,2163,850.0,1151.5,4.8,,,,,,,,,,
    ,2.73,2205,850.0,1146.6,4.8,,,,,,,,,,
    ,3.08,2163,240.0,563.5,51.0,,,,,,,,,,
    ,3.44,2205,245.0,583.1,4.8,,,,,,,,,,
    ,3.80,2184,240.0,563.5,4.8,,,,,,,,,,
    ,4.16,2121,235.0,553.7,4.8,,,,,,,,,,
    ,4.52,2058,235.0,529.2,4.8,,,,,,,,,,
    ,4.88,2037,230.0,529.2,4.8,,,,,,,,,,
    ,5.24,1995,230.0,519.4,4.8,,,,,,,,,,
    ,5.60,1953,230.0,524.3,4.8,,,,,,,,,,
    ,5.95,1890,230.0,514.5,4.8,,,,,,,,,,
    ,6.31,1827,230.0,499.8,4.8,,,,,,,,,,
    ,6.67,1785,230.0,504.7,4.8,,,,,,,,,,
    ,7.03,1743,230.0,490.0,4.8,,,,,,,,,,
    ,7.39,1701,230.0,494.9,4.8,,,,,,,,,,
    ,7.75,1680,235.0,490.0,4.8,,,,,,,,,,
    ,8.11,1659,235.0,490.0,4.8,,,,,,,,,,
    Tuesday,21,March,2006,12:13:56
    ,0.01,2394,795.0,1038.8,4.8,,,,,,,,,,
    ,0.38,2436,725.0,965.3,31.9,,,,,,,,,,
    ,0.74,2499,665.0,779.1,40.2,,,,,,,,,,
    ,1.10,2520,425.0,690.9,60.2,,,,,,,,,,
    ,1.46,2541,475.0,578.2,67.3,,,,,,,,,,
    ,1.82,2562,400.0,504.7,73.7,,,,,,,,,,
    ,2.18,2583,400.0,450.8,77.3,,,,,,,,,,
    ,2.54,2604,360.0,416.5,81.3,,,,,,,,,,
    ,2.90,2625,370.0,382.2,81.7,,,,,,,,,,
    ,3.25,2646,355.0,347.9,81.7,,,,,,,,,,
    ,3.60,2625,325.0,333.2,81.3,,,,,,,,,,
    ,3.96,2667,320.0,303.8,84.5,,,,,,,,,,
    ,4.31,2688,630.0,475.3,4.8,,,,,,,,,,
    ,4.65,2667,285.0,534.1,4.8,,,,,,,,,,
    Tuesday,21,March,2006,12:20:39
    ,0.01,2373,525.0,632.1,84.5,,,,,,,,,,
    ,0.37,2394,505.0,583.1,84.5,,,,,,,,,,
    ,0.72,2394,510.0,558.6,84.5,,,,,,,,,,
    ,1.06,2394,505.0,519.4,84.5,,,,,,,,,,
    ,1.41,2415,625.0,646.8,4.8,,,,,,,,,,
    ,1.76,2436,600.0,788.9,35.5,,,,,,,,,,
    ,2.12,2457,595.0,803.6,53.4,,,,,,,,,,
    ,2.47,2457,575.0,739.9,63.4,,,,,,,,,,
    ,2.82,2478,585.0,720.3,73.7,,,,,,,,,,
    ,3.17,2499,565.0,686.0,78.1,,,,,,,,,,
    ,3.52,2520,550.0,656.6,84.5,,,,,,,,,,
    ,3.87,2520,550.0,632.1,84.5,,,,,,,,,,
    ,4.21,2541,560.0,612.5,84.5,,,,,,,,,,
    ,4.55,2541,560.0,588.0,84.5,,,,,,,,,,
    ,4.89,2562,610.0,583.1,83.7,,,,,,,,,,
    ,5.22,2583,690.0,759.5,4.8,,,,,,,,,,
    ,5.57,2604,735.0,916.3,30.7,,,,,,,,,,
    ,5.91,2646,735.0,984.9,36.7,,,,,,,,,,
    ,6.25,2667,735.0,882.0,46.2,,,,,,,,,,
    ,6.59,2709,715.0,808.5,53.8,,,,,,,,,,
    ,6.93,2709,715.0,769.3,57.4,,,,,,,,,,
    ,7.27,2730,715.0,744.8,60.2,,,,,,,,,,
    ,7.61,2772,715.0,754.6,63.0,,,,,,,,,,
    ,7.95,2793,715.0,730.1,64.1,,,,,,,,,,
    ,8.29,2814,710.0,725.2,66.5,,,,,,,,,,
    ,8.63,2835,610.0,666.4,72.1,,,,,,,,,,
    ,8.96,2856,585.0,612.5,74.1,,,,,,,,,,
    ,9.30,2856,570.0,583.1,76.1,,,,,,,,,,
    ,9.66,2877,550.0,529.2,77.3,,,,,,,,,,
    ,10.01,2898,540.0,504.7,75.7,,,,,,,,,,
    ,10.37,2898,555.0,499.8,72.9,,,,,,,,,,
    ,10.73,2919,550.0,494.9,67.7,,,,,,,,,,
    ,11.09,2940,550.0,480.2,62.6,,,,,,,,,,
    ,11.45,2940,540.0,485.1,57.0,,,,,,,,,,
    ,11.80,2961,555.0,490.0,51.8,,,,,,,,,,
    ,12.15,2961,555.0,539.0,50.2,,,,,,,,,,
    ,12.51,2982,570.0,573.3,51.4,,,,,,,,,,
    ,12.88,2982,560.0,607.6,53.0,,,,,,,,,,
    ,13.24,2982,560.0,588.0,56.6,,,,,,,,,,
    ,13.59,3003,610.0,568.4,58.2,,,,,,,,,,
    ,13.95,3024,805.0,906.5,4.8,,,,,,,,,,
    ,14.31,3066,810.0,1249.5,4.8,,,,,,,,,,
    ,14.67,3066,535.0,710.5,4.8,,,,,,,,,,
    ,15.02,3087,425.0,612.5,4.8,,,,,,,,,,
    ,15.38,3045,350.0,602.7,4.8,,,,,,,,,,
    ,15.74,3066,355.0,548.8,47.8,,,,,,,,,,
    ,16.10,3045,355.0,480.2,58.6,,,,,,,,,,
    ,16.45,3066,370.0,436.1,59.4,,,,,,,,,,
    ,16.81,3045,365.0,445.9,63.8,,,,,,,,,,
    ,17.17,3045,365.0,387.1,66.1,,,,,,,,,,
    ,17.53,3045,365.0,362.6,68.1,,,,,,,,,,
    ,17.89,3045,365.0,357.7,68.1,,,,,,,,,,
    ,18.25,3024,365.0,338.1,67.3,,,,,,,,,,
    ,18.60,3024,410.0,347.9,4.8,,,,,,,,,,
    ,18.95,3045,620.0,759.5,23.5,,,,,,,,,,
    ,19.30,3045,725.0,950.6,31.1,,,,,,,,,,
    ,19.65,3066,740.0,867.3,40.2,,,,,,,,,,
    ,20.00,3087,790.0,980.0,4.8,,,,,,,,,,
    ,20.34,3087,505.0,744.8,4.8,,,,,,,,,,
    ,20.70,3108,430.0,597.8,4.8,,,,,,,,,,
    ,21.05,3108,560.0,661.5,4.8,,,,,,,,,,
    ,21.40,3108,615.0,725.2,4.8,,,,,,,,,,
    ,21.74,3129,750.0,857.5,4.8,,,,,,,,,,
    ,22.09,3150,785.0,980.0,4.8,,,,,,,,,,
    ,22.44,3171,800.0,945.7,4.8,,,,,,,,,,
    ,22.79,3192,805.0,945.7,4.8,,,,,,,,,,
    ,23.12,3213,805.0,935.9,4.8,,,,,,,,,,
    ,23.47,3234,805.0,940.8,4.8,,,,,,,,,,
    ,23.81,3255,805.0,926.1,4.8,,,,,,,,,,
    ,24.15,3276,805.0,911.4,4.8,,,,,,,,,,
    ,24.49,3297,790.0,886.9,4.8,,,,,,,,,,
    ,24.83,3318,795.0,867.3,4.8,,,,,,,,,,
    ,25.16,3339,805.0,891.8,4.8,,,,,,,,,,
    ,25.50,3360,805.0,896.7,4.8,,,,,,,,,,
    ,25.84,3381,805.0,891.8,4.8,,,,,,,,,,
    ,26.18,3402,805.0,882.0,4.8,,,,,,,,,,
    ,26.51,3423,800.0,867.3,4.8,,,,,,,,,,
    ,26.85,3423,795.0,857.5,4.8,,,,,,,,,,
    ,27.19,3444,795.0,857.5,4.8,,,,,,,,,,
    ,27.53,3465,795.0,833.0,4.8,,,,,,,,,,
    ,27.88,3486,800.0,833.0,4.8,,,,,,,,,,
    ,28.23,3486,790.0,833.0,4.8,,,,,,,,,,
    ,28.58,3507,795.0,803.6,4.8,,,,,,,,,,
    ,28.94,3507,800.0,803.6,4.8,,,,,,,,,,
    ,29.30,3507,795.0,788.9,4.8,,,,,,,,,,
    ,29.65,3528,800.0,793.8,4.8,,,,,,,,,,
    ,30.00,3528,835.0,886.9,4.8,,,,,,,,,,
    ,30.36,3549,835.0,1004.5,4.8,,,,,,,,,,
    ,30.72,3570,840.0,916.3,4.8,,,,,,,,,,
    ,31.08,3591,845.0,965.3,4.8,,,,,,,,,,
    ,31.43,3612,845.0,994.7,4.8,,,,,,,,,,
    ,31.79,3633,845.0,989.8,4.8,,,,,,,,,,
    ,32.14,3633,850.0,994.7,4.8,,,,,,,,,,
    ,32.50,3654,850.0,965.3,4.8,,,,,,,,,,
    ,32.86,3675,850.0,960.4,4.8,,,,,,,,,,
    ,33.22,3675,850.0,984.9,4.8,,,,,,,,,,
    ,33.58,3696,850.0,999.6,4.8,,,,,,,,,,
  5. Sebastian
    Sebastian Member
    286
    The peak values are OK, but the graph itself looks a little bit erratic.
  6. vw754
    2,321
    58
    im lost:crying: what does this mean? im not very good with these things,now cars starting to hesitate in the morning, when i put my foot down i get hesitataton,puff of black smoke,and then it go's.
    Ive replaced the maf with a new one from audi,problems not gone though(long starting,heavy fuel consumption)
    oh and readings taken while driving in 4th gear at 3 an half thousand rpm.
