MAF sensor Part number? anyone know?
MrCoont Jun 26, 2006
  1. MrCoont
    MrCoont New Member
    Car is an A3 1.8T X reg
    many thanks
    Dave
  2. AL_B
    AL_B Active Member
    1,589
    15
    Hi mate,
    I don't have the parts CD with me at work, but you should be able to track it down via the Bosch web-site.
    http://www.bosch-automotive.com/ecat-online
    If you have a pop-up blocker switched on, you'll need to switch it off for this site, as it fires up other windows.
    You could also try GSF, as they stock the genuine Bosch items too.
    AL
  3. MrCoont
    MrCoont New Member
    thanks Al :D
  4. MrCoont
    MrCoont New Member
    ook. any idea what the engine code is for a 2000 (x reg) A3 1.8T ??
    AJQ
    APP
    ARY
    AUQ
    thanks
  5. AL_B
    AL_B Active Member
    1,589
    15
    Sorry mate. No idea.
    Someone else might know. But you should be able to see it...its stamped on the engine, left hand side I think. You may have to remove the engine cover.
    AL
  6. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Just in case you haven't got your hands dirty yet... You can also get your engine code from your Vehicle Data Sticker(s) - you should have two.
    One is normally stuck to the inside front-cover of your service record; the other is normally stuck inside the spare-wheel well in the boot (most likely rear-right corner (in effect nearest your right-knee as you peer into the boot)).
    Regards,
    Rob.
  7. MrCoont
    MrCoont New Member
    thks rob! will check that out tonight
