MAF related weirdness advice please.
vrbob Jun 12, 2013
  1. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Hi peeps,
    Not posted in a while as the car has been running fine for a while so just been lurking :)
    Anyway car developed a problem yesterday and i need a little help. Drove the car to work (20 odd miles) no probs at all, parked up as norm and did my days work. finished work came out jumped in the car and headed home. Pootling along i noticed the car seemed a bit sluggish, and as my journey progressed and i tried to join the motorway the car just wouldnt go at all.
    I managed to keep it going (no lights on the dash) and nursed it home as was only another 5 miles or so. Got it on the driveway and i just couldnt get it to rev and if left it cant idle and cuts out sounding horrible.
    Scanned the car and had 2 codes which were random misfire on cylinders 1 and 3 so my first thought was its a coilpack gone. So cleared the codes and then tried to start the car again to see if any codes came back or the car worked any better. Car still wont run but no codes came back either. So on a whim i disconnected the MAF sensor and hey presto car starts and runs fine (TCS light on as expected) It idles ok and i can rev it fine too.
    So as i had only put the MAF on the car last year i got on the phone to ECP (who i got the MAF from) and they agreed to swap it out under warranty. My dad went down and got me the new one today so when i got home from work i have installed it onto the car. I cleared fault codes and started the car and it lasted 2 secs and cuts out :( jumped out disconnected MAF again and the car runs fine again. Scanned for codes (MAF still disconnected) and get 2 codes : MAF signal too low and engine control module which i think is just cos the MAF is not physically connected to the car.
    So my question is did i get another duff MAF or is there something else i should be looking for?
  2. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    vrbob likes this.
  3. vrbob
    2,375
    171
    Thanks mate :)
    I was pretty sure it is gonna be the MAF again but just wanted to check with the experts as such. The MAF i had on the car was a recon one from ECP and it had been running fine for a good 10 months. But of course this means nothing really as we all know stuff does sometimes just break.
    I knew the Bosch MAF`s from ECP are all recon units and i did remember someone saying they had more than one faulty in a row (google search found nothing lol) so thanks for the link.
    Gonna try 1 more from ECP 2moro as they are ordering one in for me and see how that goes and if the same again i will bite said bullet and get one from Audi and ask for a refund from ECP.
  4. kwistof
    2,434
    535
    No worries mate,
    Hope you get it all sorted.
    Try calling TPS as they can usually give a bit of discount if you have a price to match with them :)
  5. vrbob
    2,375
    171
    Yeah TPS will be my first call if the ECP one does not do the trick.
    Looks like i paid about £100 for the one form ECP and got £30 for my old one in exchange. So refund should be in the £70 range if thats the case. Anyone have any ideas as to what TPS charge for a new OEM bosch MAF?
    Also what grounds do i have with ECP in regards to proving their new recon MAF is still the fault so i can get a refund if necessary? is it just that with it connected car runs like a dog and disconnected its fine?
  6. vrbob
    2,375
    171
    *bump*
    Spoke to ECP today who are blaming the issue on my car with the remap and saying their MAF is not at fault. They said they will swap out once more for another MAF but if it does not work I cannot exchange it or ask for a refund.
    So am gonna goto TPS and buy a brand new Bosch MAF from them and then once that fixes the car (fingers crossed) I will go back to ECP and demand a refund.
    So before I kick off at ECP is there anything else I can check to make sure it is the MAF that's duff?
    Symptoms are as before with MAF connected car wont run at all if I unplug MAF the car runs fine (but has the TCS etc lights on the dash)
  7. vrbob
    2,375
    171
    Gave up with ECP they got annoying,
    So took the MAF i got from them to TPS as they too do the exchange service. So paid £119.16 :( and handed over the dodgy MAF (they knock off £60 for the old MAF).
    Got home put the new MAF on and hey presto car is back up and running :) It did stutter a little on first start with the MAF connected so i turned off and made sure all codes had been cleared with VCDS. Started it back up again and sounded much better so quick run round the block proves its all good and accelerates as expected.
    Idle also seems a bit more solid than it was so hoping thats my MAF woes over for now.
    s3dave likes this.
  8. calico101
    calico101 New Member
    17
    I have the exact same problem with my car . Have tried two new MAFs supplied by Badger 5 so i now they are genuine ones. I have taken the maff housing apart and noticed all my connecting plugs are splayed open No 2 plug the worst which i think is the 12v battery power which could explain my fault code 16486 . Iam going to put new connectors on first see if this makes any difference and then re check the wiring alll the way again .
  9. vrbob
    2,375
    171
    Yeah my next stage was wiring if the new MAF did not fix the issue.
    Whilst i had the car apart i did undo the MAF connector and removed the plastic shielding that covers the wires and made sure all the wires were in good condition and all my pins looked good too.
    I was most happy now that its back together and running so good luck to you and sorting your issue
  10. calico101
    17
    Yeah .hopefully new connectors will work . Shocking really that it seems to be a lottery if you get a good Maf.
