maf readings to bhp conversion
djdougalno1 Oct 17, 2010
  1. djdougalno1
    djdougalno1 Member
    189
    hi anyone know how to do the conversion from maf readings to bhp cheers
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
    i think i have seen 0.8 metioned before
  3. Prawn
    11,455
    3,353
    to convert MAF readings into approximate BHP figures divide the g/s value by 0.8, or multiply is by 1.25, both give the same result.
    120 g/s divided by 0.8 gives 150bhp for a standard A3. 160g/s or there abouts for a mapped A3
    168 g/s divided by 0.8 gives 210 bhp for a standard S3. 200g/s or there abouts for a mapped S3
    You usually won't see those exact figures of course, but that's the ball park you're after
  4. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    1.25
    When my car was down on a bit of power and done a couple dyno runs on my liquid gauge i was getting 258bhp. My air readings were 208g/s. 208 x 1.25 = 260. So not far off really!
  5. dannyh
    dannyh Nogaro S3
    788
    12
    when do you collect the G/S value, will it increse and decrese ad you put your foot down, at which point do you take the figure??,
    I have been speaking to my mechanic (as in one of my threads i cant decide if my car is mapped or not) and he said he thinks he has some software that can measure this. I can probably use this to work out if it is mapped or not
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Ideally 3rd gear to the redline ...if safe to do so of course.
  7. dannyh
    dannyh Nogaro S3
    788
    12
    is this correct, i think i can hit 90 in 3rd so i will have to take it to the motoway lol
  8. badger5
    9,427
    1,974
    if logging, look at 115 and 003 and you will see what boost (unless its an agu) and what airflow.
    std 150bhp airflow is 120g/s, 210/225bhp is 180g/s as a guide
  9. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    I still need to buy the VCDS upgrade... You can't log half the required blocks with just the lite version :(
  10. dannyh
    dannyh Nogaro S3
    788
    12
    Thanks, my mechanic has a scanner, not VAG COM so we will have to see if it gives MAF reedings and btw mine is AGU
  11. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    You can do the air flow logging though dude. Doesn't the shareware give you up to block 025?
    Anyway, either /0.8 or x1.25 your g/s figure gives an estimated BHP output.
  12. Welly
    10,696
    127
    Scanners don't normally do logging mate, they tend to just read/clear fault codes...
  13. Prawn
    11,455
    3,353
    I'm fairly sure the liquid gauge uses airflow to calculate bhp anyway, so no wonder they were similar numbers!
  14. dannyh
    dannyh Nogaro S3
    788
    12
    he said his scanner offers Live Data, we are going for i spin tomorrow to get the figures, i havent told him the full extent of the test lol, he doesnt know we will be at the redline in third lol,
    is it the peak figure i am looking for???
  15. metricspaces
    metricspaces Member
    661
    Yep, take the max g/s value from a run up to the redline.
  16. dannyh
    dannyh Nogaro S3
    788
    12
    in third gear????/
    i can hit 90 in third
  17. Prawn
    11,455
    3,353
    You can hit over 90 in 3rd mate. Rev limiter in 3rd is over 100mph
  18. dannyh
    dannyh Nogaro S3
    788
    12
    is that how fast i need to go for the test?????
  19. dannyh
    dannyh Nogaro S3
    788
    12
    also, if you can hit 100 in 3rd why is the top speed 135??
  20. Welly
    10,696
    127
    No-one is going to say yes and encourage you to go 90+ on a public road matey....
    However, on a private track, then yes, 7200 in third FTW!
  21. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    motorway juction should be fine to do ur "77mph" lol if ur lucky enough to be close.
    i have a m1 junction 13-14 running accross the backend of milton keynes so thats a good place for me
  22. Prawn
    11,455
    3,353
    The limiting factor in top speed is power not gear ratios. In theory, if you could get to 7200rpm in 5th gear you'd be doing about 180mph, but the power simply isn't there.
    I managed to get my stage 2 agu to 6600rpm in top on the kerpen autobahn, which was 163 according to the satnav
  23. S3KO4
    S3KO4 Member
    850
    I think you are referring to the 5 speed box to get 100mph out of 3rd. the 6 speed is a lot shorter ratio, good speed there but what was it showing on the dash? I bet over 165! I was once in a fully stripped A3 with K04 that reached way below the clock. if only the head permitted, there was still tones of torque coming from the engine which I think would have taken it over 170mph
  24. badger5
    9,427
    1,974
    easier said than done..
    IHI'd back in 2003, 320bhp, seat ibiza @ bruntingthorpe 2 mile straight, 160mph was its gps timed Vmax. speedo was off the clock.
    I did a Vmax day with pistonheads back then, and what a crack it was.. ickle seat ibiza going side by side and head to head with proper fast cars, and M3, M5's loosing in a rolling start and slower terminal.. funny as :)
  25. Welly
    10,696
    127
    Cos I bet that didn't make you smile at all..... Much. :thumbsup:
  26. Prawn
    11,455
    3,353
    I was indeed refering to the A3 5 speed box, as DannyH who asked the question has a 150bhp 5 speed A3 :)
    Speedo on the A3 was well off the clock on 6600rpm, showing roughly 170 indicated speed, 163 on the satnav
  27. dannyh
    dannyh Nogaro S3
    788
    12
    Weel guys i wen out last night and got my data.
    firstly whe i was driving the G/S value incresed when i let of the accelarator,
    well i diddnt hit 7500 but i took it to 7000 in third and i recorded 127.5g/s
    so..
    117.5 x 1.25 = 146.88 so 147bhp
    is this normal, i am guessing so
    however when i let off to change gear i recorded 124g/s
    why does it increse when i let off.
    any way conclusion..... Remap Time
  28. s3dave
    10,110
    736
    it may have over revved when you put the clutch down
  29. badger5
    9,427
    1,974
    that airflow matches cars which I see and dyno at around 150bhp, so looks normal for stock car
    Remap time now then :)
  30. dannyh
    dannyh Nogaro S3
    788
    12
    yes just booked it in, cant wait lol
