MAF readings are low....is this correct?
g10chy Jan 11, 2011
  1. g10chy
    g10chy Member
    155
    I had a MAF error few weeks back which was cleared and has not returned since. Is a reading of 10.7g/s at 3k revs standstill correct? Or is my MAF on it's way out?
    Cheers,
    Chris
  2. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    u need to go for a spirited drive. try to get max revs 6500ish in 3rd gear. ull get proper readings then. too hard to compare revving on ur drive like.
  3. g10chy
    g10chy Member
    155
    Theses are some of my readings from 4k to 6k full load. How do these look?
    RPM Inj. On Timing Mass Flow g/s
    4440 150.4 143.28
    4840 155.6 144.86
    5240 149.6 147.06
    5560 142.1 152.33
    5880 133.8 144.83
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    You need to do the readings to redline to be honest mate. Up to 6K isn't really that helpful.
    Considering that though, the readings are low, even at 6K for a remapped car.
    3rd gear, 3K to redline will give a good reading of the airflow - then post them up.
  5. g10chy
    g10chy Member
    155
    OK cheers Welly. I will try and borrow my mates cable overnight so I can get some proper runs logged and uploaded.
    Could it be that I simply have a sh!te remap? As my boost pressures seemed abit low also averaging between 17-20 psi with WOT!
  6. Welly
    10,696
    127
    Well, it's a bit hard to say. The values are low. You are making around 190 bhp at the best point of the values you posted.
    Could be a dying MAF, could be the map... But it would have to be an epicially bad map, as looking at what you posted before, it will struggle to make standard power.
  7. g10chy
    g10chy Member
    155
    Welly - Could I email you the full log which has group 115 and 002 for the quick test run i performed for you to cast your eye over a bit more? Quite worried i've not been reaching its potential for quite sometime now :(
  8. Welly
    10,696
    127
    Yep, no problem, I'll PM you my email address.
  9. g10chy
    g10chy Member
    155
    Cheers man. I have just sent you the log.
  10. Prawn
    11,413
    3,302
    Those airflow figures sound really low to me. especially for a mapped S3!
    Even without going to the redline, here's a tiny extract from the one log I could find on my work PC.
    This is a ko3S turbo too, not a ko4.
    RPM Airflow (g/s)
    4120 150.07
    5080 173.75
    5840 186.39
    6560 187.15
    So that's just an A3, and at 5000rpm it's making almost 20g/s more than you're mapped S3! something big time wrong there.....
  11. Welly
    10,696
    127
    OK, looking at that log, the airflow does look to be down, but it's difficult to be sure because it never gets to redline, and all the bursts of acceleration are short.
    If you can, go out again and log block 002, 020 and 115. Timing pull (020) is a useful block to log because it gives you a better insight as to what is going on.
    Try, again if you can, to do a several full runs in 3rd (or 4th if you are brave enough) from 3K all the way to 7K. Nice log logs are easier to gets useful info from.
  12. Welly
    10,696
    127
    Agreed, mapped S3s should be expecting 200 g/s or close to.
  13. Welly
    10,696
    127
    Again, here is a brief excerpt from one of my very old Stage 1 REVO logs:
    Code:
    	RPM	Inj. On Time	Mass Flow
    TIME
    STAMP	 /min	 ms	 g/s
    165.28	5600	19.27	194.69
    166.48	5840	18.86	199.25
    167.68	6080	18.04	198.92
    168.98	6320	16.81	194.42
    170.29	6520	16.4	189.42
    171.49	6680	15.99	191.64
    I have sent you the whole log for comparison.
  14. g10chy
    g10chy Member
    155
    Welly - Nice one for looking...I am borriowing my mates cable tonight so I will get some better runs logged. The roads were too busy this lunch to get any decent runs!!
    Will be in touch later.
    Cheers,
    Chris
  15. Welly
    10,696
    127
    As per my email back mate, with standard S3 210 log attached for your reference.
  16. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    I still want to know why I got 186 from a standard car.
  17. superkarl
    superkarl MAN OF STEEL
    9,405
    2,378
    There was a hurricane that day that was blowing into your maf for a brief moment.
    Just a guess like
  18. Breezey
    Breezey Member
    453
    I got 181 from my standard S3, yours must be running that little bit better.
  19. g10chy
    g10chy Member
    155
    Welly - I have just done a run in 3rd from 3k to redline....not looking good :sadlike: I have sent you the full log but the max MAF reading im getting is 159.5g/s!!!
    Im also getting a few Idle Stabilization figures which im guessing is not good also?
    Any ideas whats wrong?
    Cheers,
    Chris
  20. badger5
    9,404
    1,944
    tired maf... most likely
  21. Welly
    10,696
    127
    Lots of timing pull on the logs as well though. Not horrendous, but seeing 6s.
  22. aragorn
    18,025
    721
    If the maf's tired wouldnt the fuelling be all over the shop though?
    Running lean will cause timing pull?
  23. Welly
    10,696
    127
    Yep, it's got dodgy MAF written all over it....
  24. g10chy
    g10chy Member
    155
    OK nice one guys!
    Will the below part be OK or should I get and OEM one direct from Audi?
    HTML:
    http://www.eurocarparts.com/ecp/c/Audi_S3_1.8_2001/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-sensor/?434440150&1&a413bd08cf642550236330dbb8c7f97fc7dcaf12&AFME
  25. Welly
    10,696
    127
    That one should be OK, as long as it's a genuine Bosch unit it will be fine. Check that with them beforehand.
    EDIT: Is does distinctly say 'Bosch' on the listing, so should be fine...
  26. JD09
    3,096
    46
    I'm going to log again tonight and see what mine is now getting.
  27. badger5
    9,404
    1,944
    it wont be helping the fuel trims... but if wideband car it will still be controlled by lambda
  28. badger5
    9,404
    1,944
    yes.. seen it a lot
  29. g10chy
    g10chy Member
    155
    Getting my mate at Audi order me a new MAF....Discounted parts :thumbsup:
    Will then do another log to see if the MAF readings have improved!!! Fingers crossed
  30. Welly
    10,696
    127
    Good luck dude, hope it sorts it for you. Should unlock some power for you.... :thumbsup:
  31. g10chy
    g10chy Member
    155
    Just fitted the new MAF and performed a new run feels alot better!!
    How do I get the results from Excel into the post without losing the formatting?
    Cheers,
    Chris
  32. Welly
    10,696
    127
    Chris, as per my email reply, there is still a little extra timing pull than is ideal. 6s are generally considered to be the limit of safe with regard to timing pull.
    I would take your top hoses off to check for oil inside - excess oil in the charge system can often cause higher than average timing pull figures. If there is a lot of oil, clean out as best as you can and then re log. Then keep an eye on the amount of oil in the charge system.
    I notice that it is only under heavy load in high gear, so you may want to avoid doing this too much until resolved. Ideally the timing wants to be backed down a little bit. Who mapped it?
    MAF readings are much better - a massive improvement. I would imagine there is an improvement on the road as well?
    Nice work - glad that the MAF problem has gone.
