MAF poll
jojo Nov 11, 2007
Have you changed your MAF sensor?
  1. Nope, still original one.
    63 vote(s)
    60.6%
  2. Yup, I've changed it once.
    32 vote(s)
    30.8%
  3. I've had to change it twice or more!
    9 vote(s)
    8.7%
  1. jojo
    28,934
    3,587
    Simple really, with it being a common problem with A3/S3 engines, have you had to changed the MAF(Airflow) sensor on your car?
  2. A3_Turbo
    A3_Turbo Swaying towards IHI....
    1,464
    I havnt changed mine, what are the symptons of needing a new one?
  3. madvw
    madvw Active Member
    2,489
    not yet, not even after 5 years.
    Saying that, its on the list to do, together with DV, and coolant temperature sensor. None are displaying any problems so far though.
  4. jojo
    28,934
    3,587
    Poor running, like uneven power delivery, **** fuel consumption and it feels like the power is being held back under full throttle!
    It's very noticeable on petrol engines, diesel cars seem to just run lower power when the MAF goes.
  5. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    I changed my original one when I had the car mapped. Didn't need it, but you never know.
  6. HTC
    HTC Active Member
    3,428
    9
    170000 miles on the original. A record?
  7. fingermouse
    fingermouse thats me
    4,004
    112
    ffs jojo ive just voted that I havn`t changed min eso if it goes faulty soon Im going to blame you :p
  8. Shifty
    Shifty Avvve it!
    49
    i replaced mine but found out later i was toooo quick jumping to conclusions...poor running wasnt due to maf...but rather a leaking head gasket and a cracked cylinder head ;( but they are common on vw/audi's
  9. T11OM F
    T11OM F Fearon
    151
    Sounds like i need to change mine.....
    how much are they?
  10. jojo
    28,934
    3,587
    :sorry:
  11. jojo
    28,934
    3,587
    Around £80 exchange with your old one at your local stealer, or £55 for a new sensor part from a local motor factors like GSF or ECP. Most people think that the factory £80 one is the best option for quality and longivity(sp?)
  12. grathies
    grathies More Points Than Portsmouth FC
    1,343
    Having worked for VW in the past Ive seen loads of the replacement sensors fail
    Cant remember the number but last time I spoke to my mates at the dealers they said that its in line next for being bought down inline with the other ones in the range that are £60 for the unit and actually no longer and exchange
    Oh and I found about 4 reciepts for them with my cars when I got it lol
  13. Bellic
    Bellic Member
    265
    im thinking of changing mine for dealer one as sometimes my car is not always performing well seem slow in rev range and fuel consumtion is not great , also when idleing sometimes see the rev need wander up and down slightly almost like a little misfire could this be the maf? or lambda sensor cause this?
  14. Shifty
    Shifty Avvve it!
    49
    thats could be either or both..sorry...i know that aint helpful, the maf gauges the amount of air, lamba gauges gases
  15. shineydave
    shineydave Member
    920
    pull the plug off the MAF, that'll cause the ECU to use a set of pre-programmed values instead of the MAF signal, if it runs better it's the MAF at fault
  16. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    Would be interesting to find out also how many people who have had one fail, Whether or not they have uprated filter/cone etc????? (not hi-jacking I just think we would see a interesting set of results!!)
    :icon_thumright:
  17. grathies
    1,343
    "Induction" kit type filters that bolt onto the MAF seem to have caused alot of trouble when I worked for the dealers, had people replacing them all the time, guess its to do with flow ratios etc
  18. ash_pearce
    ash_pearce Member VCDS Map User
    321
    My maf is working fine however i would recommend giving it a clean. I found a guide on here somewhere, failrly straight forward anyway you just need a anti tamper torx bit to remove the sensor from the housing. Bought a can of contact cleaner from maplins for £3.99 gave it a good blast was suprised how much muck comes off despite a new air filter in place. I'm hoping this will if anything extend the life of mine.
  19. Dani_B19
    9,336
    391
    But cant that also ruin the MAF by cleaning it!
  20. vanilla_ice
    vanilla_ice Active Member
    713
    I used brake cleaner and instantly got better MPG and power was back where it should be :D
    ICE
  21. jojo
    28,934
    3,587
    You have to becareful with cleaning the MAF as the element in then is so delicate, blasting them with a cleaner is not the best method, spraying towards the element and letting the chemicals do it's job is ok, but don aim the spray directly at full force towards it, as that can damage it.
  22. reptor245
    reptor245 Active Member
    1,168
    61.29% have changed theres? im shocked. Its the first thing people on here say change when someones got a running problem. SHOCKED..lol
  23. jojo
    28,934
    3,587
    No, it's 61.29%(at the time of posting) of people who are still running the original MAF sensor without changing yet.
  24. reptor245
    1,168
    yeah ment "Havent" changed theres. typo.
  25. bhavin1986
    bhavin1986 BBP
    464
    I get poor fuel consumption. Around 28-30mpg. And its only a 1.6. I've had the thermostat replaced, temp sender replaced, throttle body cleaned, but the fuel consumption is still poor. Could this be the issue?
  26. Jurassic Pork
    Jurassic Pork New Member
    9
    had a vagcom run on my car on Weds, found out i need a new one
  27. landopanda
    landopanda Member
    143
    Great! voted no. vag commed this week.... need a new one! i blame this poll :shrug:
